| [QVTO] Set contents not remembered between init and end [message #86053] |
Mon, 07 July 2008 11:52  |
Originally posted by: koen.yskout.cs.kuleuven.be
Apparently, when using a set as result, it (or at least its contents) is
not remembered between the init and end section, as shown in the sample
program attached. I suspect this is a bug?
Kind regards,
Koen
modeltype UML uses uml("http://www.eclipse.org/uml2/2.1.0/UML");
transformation demo();
main() {
map class_test();
map set_test();
mapping class_test() : UML::Class
init {
result := object Class { name := 'TestClass'; };
log('class_test_init', result)
end {
log('class_test_end', result);
/* got the class back, as expected */
mapping set_test() : Set(UML::Class)
init {
result := Set { object Class { name := 'TestClass'; }};
log('set_test_init', result);
end {
log('set_test_end', result);
/* got [], but expected set with one class */
| Re: [QVTO] Set contents not remembered between init and end [message #86069 is a reply to message #86053] |
Mon, 07 July 2008 13:17  |
Hi Koen,
Right, that's definitely a bug. I've created bugzilla CR for it:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=239831
Thank you for sample posted!
Sergey.
Koen Yskout wrote:
> Kind regards,
> Koen
> main() {
> map class_test();
> map set_test();
> init {
> end {
> init {
> end {
FUDForum. Page generated in 0.03778 seconds
