Home » Language IDEs » ServerTools (WTP) » WSDL Issues - Namespaces
| WSDL Issues - Namespaces [message #85882] |
Tue, 22 March 2005 15:34  |
I'm having some issues with a WSDL file I'm using. Eclipse/webtools seems
to be ignoring the namespace prefix within the wsdl file when I bring it
into eclipse. I can successfully invoke the webservice via the Web
Services Explorer. But it inserts its own prefix instead of what is
defined in the WSDL file. It uses "q0" instead of what is in the WSDL.
I'm having the same problem with the IBM WSAD version except it is using
"p2" as the prefix and ignoring what is in the WSDL file.
This is the error that I get when trying to create a web service from the
wsdl.
IWAB0380E Errors were encountered while validating XML schemas.
XSD: The location '' has not been resolved
XSD: Element reference
'http://sn000046/PgnServiceRequest/publish#createTicket' is unresolved
XSD: Element reference 'http://sn000046/PgnServiceRequest/publish#status'
is unresolved
IWAB0381I
file:/c:/ide/workspace/CreateRequest/WebContent/wsdl/PgnServ iceRequest_publishPort0.wsdl
was successfully opened.
Here is the WSDL I used. Is there something in the WSDL that is causing
this problem. I'm not having any issues getting it to work with .Net. I
sure would like it better in Java though.
<wsdl:definitions name="PgnServiceRequest_publish"
targetNamespace="http://sn000046/PgnServiceRequest/publish/"
xmlns:webM="http://www.webMethods.com/noNamespace/"
xmlns:soap="http://schemas.xmlsoap.org/wsdl/soap/"
xmlns:mime="http://schemas.xmlsoap.org/wsdl/mime/"
xmlns:tns="http://sn000046/PgnServiceRequest/publish/"
xmlns:wsdl="http://schemas.xmlsoap.org/wsdl/"
xmlns:http="http://schemas.xmlsoap.org/wsdl/http/"
xmlns:wsdns1="http://sn000046/PgnServiceRequest/publish"
xmlns:xsd="http://www.w3.org/2001/XMLSchema">
<wsdl:types>
<xsd:schema xmlns:xsd="http://www.w3.org/2001/XMLSchema"
targetNamespace="http://sn000046/PgnServiceRequest/publish"
xmlns:ti="http://sn000046/PgnServiceRequest/publish">
<xsd:element name="firstname" type="xsd:string"/>
<xsd:element name="lastname" type="xsd:string"/>
<xsd:element name="employeenumber" type="xsd:string"/>
<xsd:element name="problemcode" type="xsd:string"/>
<xsd:element name="problemdescription" type="xsd:string"/>
<xsd:element name="contact" type="xsd:string"/>
<xsd:element name="createTicket">
<xsd:complexType>
<xsd:sequence>
<xsd:element ref="ti:firstname"/>
<xsd:element ref="ti:lastname"/>
<xsd:element ref="ti:employeenumber"/>
<xsd:element ref="ti:problemcode"/>
<xsd:element ref="ti:problemdescription"/>
<xsd:element ref="ti:contact"/>
</xsd:sequence>
</xsd:complexType>
</xsd:element>
<xsd:element name="success" type="xsd:string"/>
<xsd:element name="status">
<xsd:complexType>
<xsd:sequence>
<xsd:element ref="ti:success"/>
</xsd:sequence>
</xsd:complexType>
</xsd:element>
</xsd:schema>
targetNamespace="http://localhost/PgnServiceRequest/publish/createTicket"
xmlns:tns="http://localhost/PgnServiceRequest/publish/createTicket"
<xsd:import
namespace="http://sn000046/PgnServiceRequest/publish"/>
<xsd:complexType name="createTicket">
<xsd:sequence>
<xsd:element ref="ti:createTicket"/>
<xsd:any processContents="lax"/>
</xsd:sequence>
<xsd:anyAttribute processContents="lax"/>
</xsd:complexType>
<xsd:complexType name="status">
<xsd:sequence>
<xsd:element ref="ti:status"/>
</xsd:sequence>
</xsd:complexType>
</xsd:schema>
</wsdl:types>
<wsdl:message name="createTicket">
<wsdl:part name="createTicket" element="wsdns1:createTicket"/>
</wsdl:message>
<wsdl:message name="createTicketOutput">
<wsdl:part name="status" element="wsdns1:status"/>
</wsdl:message>
<wsdl:portType name="PgnServiceRequest_publishPortType">
<wsdl:operation name="createTicket">
<wsdl:input message="tns:createTicket"/>
<wsdl:output message="tns:createTicketOutput"/>
</wsdl:operation>
</wsdl:portType>
<wsdl:binding name="PgnServiceRequest_publishBinding"
type="tns:PgnServiceRequest_publishPortType">
<soap:binding style="document"
transport="http://schemas.xmlsoap.org/soap/http"/>
<soap:operation soapAction=""/>
<wsdl:input>
<soap:body use="literal"/>
</wsdl:input>
<wsdl:output>
</wsdl:output>
</wsdl:operation>
</wsdl:binding>
<wsdl:service name="PgnServiceRequest_publishService">
<wsdl:port name="PgnServiceRequest_publishPort0"
binding="tns:PgnServiceRequest_publishBinding">
<soap:address location="http://sn000046:9999/soap/default"/>
</wsdl:port>
</wsdl:service>
</wsdl:definitions>
thanks for any suggestions.
| Re: WSDL Issues - Namespaces [message #86506 is a reply to message #85882] |
Wed, 23 March 2005 14:03   |
Hi Mark,
prefix is just a pointer to the namespace declaration, as far as I know, the
name of the prefix does not matter as long as it points to the same
namespace. For example,
<ti:firstname xmlns:ti="http://sn000046/PgnServiceRequest/publish"/>
<q0:firstname xmlns:q0="http://sn000046/PgnServiceRequest/publish"/>
Is there any reason why the prefix in the SOAP message must match the prefix
used in the WSDL file? Any namespace aware XML parser should handle this
correctly.
As for the error messages:
> is unresolved
> IWAB0381I
They are harmless and have nothing to do with the prefix issue you mention
above. The technical answer to the error message is... The Web Services
Explorer uses the XSD parser to parse the <xsd:schema>...</xsd:schema>
elements defined in the WSDL file. The XSD parser can only parse one
<xsd:schema/> element at a time. If you take a look at the WSDL file below,
there are two <xsd:schema/> elements in it. Therefore, the Explorer needs to
run the XSD parser twice. The problem is that the XSD parser does not allow
you to store any meta information about other <xsd:schema/> elements, it
only knows about the <xsd:schema/> element that it is currently parsing.
What this means is that if the two <xsd:schema/> elements have references to
each other, the XSD parser does not know about such reference and will
therefore throw an warning/error back to the caller (the Explorer) saying
you have an unresolvable reference. This is not true because the Explorer
knows that there are two <xsd:schema/> elements, and the Explorer has some
custom logic to handle this situation... However, when the Explorer receives
a warning/error from the XSD parser, there's no way to tell whether they are
legitimate error messages or they are really limitation mentioned above. The
decision was to leave the message in because we don't want to suppress any
legitimate errors by accident. Hope this helps.
Jeff
"Mark Griffin" <mark.griffin@pgnmail.com> wrote in message
news:a8f751a66736e401f04b361119729d65$1@www.eclipse.org...
> wsdl.
> is unresolved
> IWAB0381I
> <wsdl:types>
> <xsd:complexType>
> <xsd:sequence>
> </xsd:sequence>
> </xsd:complexType>
> </xsd:element>
> <xsd:complexType>
> <xsd:sequence>
> </xsd:sequence>
> </xsd:complexType>
> </xsd:element>
> </xsd:schema>
> <xsd:import
> <xsd:sequence>
> </xsd:sequence>
> </xsd:complexType>
> <xsd:sequence>
> </xsd:sequence>
> </xsd:complexType>
> </xsd:schema>
> </wsdl:types>
> </wsdl:message>
> </wsdl:message>
> </wsdl:operation>
> </wsdl:portType>
> <wsdl:input>
> </wsdl:input>
> <wsdl:output>
> </wsdl:output>
> </wsdl:operation>
> </wsdl:binding>
> </wsdl:port>
> </wsdl:service>
> </wsdl:definitions>
| Re: WSDL Issues - Namespaces [message #86660 is a reply to message #86506] |
Wed, 23 March 2005 20:41   |
Thanks Jeff, this helps. It's causing a minor problem in the product I'm
using to parse the soap messages with. I'm querying on the element but
I'm not supplying the prefix. When a prefix shows up it causes the query
to fail. The difference being firstname versus q0:firstname or in
websphere's case p2:firstname . I can work around this I believe, but
I'm curious as to why the products would not just use what is defined in
the WSDL document.
I confess I'm pretty much a novice at this stage in working with soap
and wsdl. Is it possible that this could cause problems when multiple
clients(various technologies) are accessing a web services interface and
all send their own version of the prefix? ie the soap message may
contain two firstname elements that are namespace qualified but the
particular web service may be interested in only a certain one. Would
it not need to know how to find that element? Sorry if this is a basic
question.
markg
Jeff Liu wrote:
> Hi Mark,
> correctly.
>>is unresolved
>>IWAB0381I
> Jeff
>>wsdl.
>>is unresolved
>>IWAB0381I
>><?xml version="1.0" encoding="UTF-8"?>
>><wsdl:types>
>> <xsd:complexType>
>> <xsd:sequence>
>> </xsd:sequence>
>> </xsd:complexType>
>> </xsd:element>
>> <xsd:complexType>
>> <xsd:sequence>
>> </xsd:sequence>
>> </xsd:complexType>
>> </xsd:element>
>> </xsd:schema>
>> <xsd:import
>> <xsd:sequence>
>> </xsd:sequence>
>> </xsd:complexType>
>> <xsd:sequence>
>> </xsd:sequence>
>> </xsd:complexType>
>> </xsd:schema>
>></wsdl:types>
>></wsdl:message>
>></wsdl:message>
>></wsdl:operation>
>></wsdl:portType>
>><wsdl:input>
>></wsdl:input>
>><wsdl:output>
>></wsdl:output>
>></wsdl:operation>
>></wsdl:binding>
>></wsdl:port>
>></wsdl:service>
>></wsdl:definitions>
| Re: WSDL Issues - Namespaces [message #86996 is a reply to message #86660] |
Thu, 24 March 2005 14:05   |
--------------7663F748B8962C5FFD0C05DC
Content-Type: text/plain; charset=us-ascii
Mark,
there are no basic questions when it comes to Schema. The short answer to your question is
that the value of the prefix itself is not significant outside of the document within which it
is used. It's the namespace bound to the prefix that matters. Since the WSDL and the SOAP
documents are distinct from one another, they are free to use whatever prefixes they want
independent of each other.
From the W3C Namespaces in XML 1.1 spec [1]: "Note that the prefix functions only as a
placeholder for a namespace name. Applications SHOULD use the namespace name, not the prefix,
in constructing names whose scope extends beyond the containing document."
[1] http://www.w3.org/TR/xml-names11/
Cheers - CB.
> the WSDL document.
> question.
> markg
> Jeff Liu wrote:
> > Hi Mark,
> > correctly.
> >>is unresolved
> >>IWAB0381I
> > Thanks,
> > Jeff
> >>wsdl.
> >>is unresolved
> >>IWAB0381I
> >><wsdl:types>
> >> <xsd:complexType>
> >> <xsd:sequence>
> >> </xsd:sequence>
> >> </xsd:complexType>
> >> </xsd:element>
> >> <xsd:complexType>
> >> <xsd:sequence>
> >> </xsd:sequence>
> >> </xsd:complexType>
> >> </xsd:element>
> >> </xsd:schema>
> >> <xsd:import
> >> <xsd:sequence>
> >> </xsd:sequence>
> >> </xsd:complexType>
> >> <xsd:sequence>
> >> </xsd:sequence>
> >> </xsd:complexType>
> >> </xsd:schema>
> >></wsdl:types>
> >></wsdl:message>
> >></wsdl:message>
> >></wsdl:operation>
> >></wsdl:portType>
> >><wsdl:input>
> >></wsdl:input>
> >><wsdl:output>
> >></wsdl:output>
> >></wsdl:operation>
> >></wsdl:binding>
> >></wsdl:port>
> >></wsdl:service>
> >></wsdl:definitions>
Content-Type: text/html; charset=us-ascii
<!doctype html public "-//w3c//dtd html 4.0 transitional//en">
<html>
Mark,
<br>there are no basic questions when it comes to Schema. The short answer
to your question is that the value of the prefix itself is not significant
outside of the document within which it is used. It's the namespace bound
to the prefix that matters. Since the WSDL and the SOAP documents are distinct
from one another, they are free to use whatever prefixes they want independent
of each other.
<p>From the W3C Namespaces in XML 1.1 spec [1]: "Note that the prefix functions
only as a placeholder for a namespace name. Applications SHOULD use the
namespace name, not the prefix, in constructing names whose scope extends
<p>[1] <A HREF="http://www.w3.org/TR/xml-names11/">http://www.w3.org/TR/xml-names11/</A>
<p>Cheers - CB.
<p>Griffin wrote:
<blockquote TYPE=CITE>Thanks Jeff, this helps. It's causing a minor problem
in the product I'm
<br>using to parse the soap messages with. I'm querying on the element
but
<br>I'm not supplying the prefix. When a prefix shows up it causes the
query
<br>to fail. The difference being firstname versus q0:firstname or in
<br>websphere's case p2:firstname . I can work around this I believe,
but
<br>I'm curious as to why the products would not just use what is defined
in
<br>the WSDL document.
<p>I confess I'm pretty much a novice at this stage in working with soap
<br>and wsdl. Is it possible that this could cause problems when
multiple
<br>clients(various technologies) are accessing a web services interface
and
<br>all send their own version of the prefix? ie the soap message
may
<br>contain two firstname elements that are namespace qualified but the
<br>particular web service may be interested in only a certain one.
Would
<br>it not need to know how to find that element? Sorry if this is a basic
<br>question.
<p>markg
<p>Jeff Liu wrote:
<br>> Hi Mark,
<br>>
<br>> prefix is just a pointer to the namespace declaration, as far as
I know, the
<br>> name of the prefix does not matter as long as it points to the same
<br>> namespace. For example,
<br>>
<br>> <ti:firstname xmlns:ti="<a href="http://sn000046/PgnServiceRequest/publish" /">http://sn000046/PgnServiceRequest/publish"/</a>>
<br>>
<br>> <q0:firstname xmlns:q0="<a href="http://sn000046/PgnServiceRequest/publish" /">http://sn000046/PgnServiceRequest/publish"/</a>>
<br>>
<br>> Is there any reason why the prefix in the SOAP message must match
the prefix
<br>> used in the WSDL file? Any namespace aware XML parser should handle
this
<br>> correctly.
<br>>
<br>> As for the error messages:
<br>>
<br>>
<br>>>IWAB0380E Errors were encountered while validating XML schemas.
<br>>>XSD: The location '' has not been resolved
<br>>>XSD: Element reference
<br>>>'<a href="http://sn000046/PgnServiceRequest/publish#createTicket">http://sn000046/PgnServiceRequest/publish#createTicket</a>'
is unresolved
<br>>>XSD: Element reference '<a href="http://sn000046/PgnServiceRequest/publish#status">http://sn000046/PgnServiceRequest/publish#status</a>'
<br>>>is unresolved
<br>>>IWAB0381I
<br>>>
<br>>
<br>> <a href=" file:/c:/ide/workspace/CreateRequest/WebContent/wsdl/PgnServ iceRequest_publishPort0.wsdl "> file:/c:/ide/workspace/CreateRequest/WebContent/wsdl/PgnServ iceRequest_publishPort0.wsdl </a>
<br>>
<br>>>was successfully opened.
<br>>
<br>>
<br>> They are harmless and have nothing to do with the prefix issue you
mention
<br>> above. The technical answer to the error message is... The Web Services
<br>> Explorer uses the XSD parser to parse the <xsd:schema>...</xsd:schema>
<br>> elements defined in the WSDL file. The XSD parser can only parse
one
<br>> <xsd:schema/> element at a time. If you take a look at the WSDL
file below,
<br>> there are two <xsd:schema/> elements in it. Therefore, the Explorer
needs to
<br>> run the XSD parser twice. The problem is that the XSD parser does
not allow
<br>> you to store any meta information about other <xsd:schema/> elements,
it
<br>> only knows about the <xsd:schema/> element that it is currently
parsing.
<br>> What this means is that if the two <xsd:schema/> elements have
references to
<br>> each other, the XSD parser does not know about such reference and
will
<br>> therefore throw an warning/error back to the caller (the Explorer)
saying
<br>> you have an unresolvable reference. This is not true because the
Explorer
<br>> knows that there are two <xsd:schema/> elements, and the Explorer
has some
<br>> custom logic to handle this situation... However, when the Explorer
receives
<br>> a warning/error from the XSD parser, there's no way to tell whether
they are
<br>> legitimate error messages or they are really limitation mentioned
above. The
<br>> decision was to leave the message in because we don't want to suppress
any
<br>> legitimate errors by accident. Hope this helps.
<br>>
<br>> Thanks,
<br>>
<br>> Jeff
<br>>
<br>> "Mark Griffin" <mark.griffin@pgnmail.com> wrote in message
<br>> <a href="news:a8f751a66736e401f04b361119729d65$1@www.eclipse.org">news:a8f751a66736e401f04b361119729d65$1@www.eclipse.org</a>...
<br>>
<br>>>I'm having some issues with a WSDL file I'm using. Eclipse/webtools
seems
<br>>>to be ignoring the namespace prefix within the wsdl file when I bring
it
<br>>>into eclipse. I can successfully invoke the webservice via
the Web
<br>>>Services Explorer. But it inserts its own prefix instead of what
is
<br>>>defined in the WSDL file. It uses "q0" instead of what is in
the WSDL.
<br>>>I'm having the same problem with the IBM WSAD version except it is
using
<br>>>"p2" as the prefix and ignoring what is in the WSDL file.
<br>>>
<br>>>This is the error that I get when trying to create a web service
from the
<br>>>wsdl.
<br>>>
is unresolved
<br>>>is unresolved
<br>>>IWAB0381I
<br>>>
<br>>
<br>>
<br>>>
<br>>>Here is the WSDL I used. Is there something in the WSDL that
is causing
<br>>>this problem. I'm not having any issues getting it to work with .Net.
I
<br>>>sure would like it better in Java though.
<br>>>
<br>>>
<br>>>
<br>>><?xml version="1.0" encoding="UTF-8"?>
<br>>><wsdl:definitions name="PgnServiceRequest_publish"
<br>>>targetNamespace="<a href="http://sn000046/PgnServiceRequest/publish/">http://sn000046/PgnServiceRequest/publish/</a>"
<br>>>xmlns:webM="<a href="http://www.webMethods.com/noNamespace/">http://www.webMethods.com/noNamespace/</a>"
<br>>>xmlns:soap="<a href="http://schemas.xmlsoap.org/wsdl/soap/">http://schemas.xmlsoap.org/wsdl/soap/</a>"
<br>>>xmlns:mime="<a href="http://schemas.xmlsoap.org/wsdl/mime/">http://schemas.xmlsoap.org/wsdl/mime/</a>"
<br>>>xmlns:tns="<a href="http://sn000046/PgnServiceRequest/publish/">http://sn000046/PgnServiceRequest/publish/</a>"
<br>>>xmlns:wsdl="<a href="http://schemas.xmlsoap.org/wsdl/">http://schemas.xmlsoap.org/wsdl/</a>"
<br>>>xmlns:http="<a href="http://schemas.xmlsoap.org/wsdl/http/">http://schemas.xmlsoap.org/wsdl/http/</a>"
<br>>>xmlns:wsdns1="<a href="http://sn000046/PgnServiceRequest/publish">http://sn000046/PgnServiceRequest/publish</a>"
<br>>>xmlns:xsd="<a href="http://www.w3.org/2001/XMLSchema">http://www.w3.org/2001/XMLSchema</a>">
<br>>><wsdl:types>
<br>>> <xsd:schema xmlns:xsd="<a href="http://www.w3.org/2001/XMLSchema">http://www.w3.org/2001/XMLSchema</a>"
<br>>>targetNamespace="<a href="http://sn000046/PgnServiceRequest/publish">http://sn000046/PgnServiceRequest/publish</a>"
<br>>>xmlns:ti="<a href="http://sn000046/PgnServiceRequest/publish">http://sn000046/PgnServiceRequest/publish</a>">
<br>>> <xsd:element
<br>>> <xsd:element
<br>>> <xsd:element
<br>>> <xsd:element
<br>>> <xsd:element
<br>>> <xsd:element
<br>>> <xsd:element
<br>>>
<xsd:complexType>
<br>>>
<xsd:sequence>
<br>>>
<br>>>
<br>>>
<br>>>
<br>>>
<br>>>
<br>>>
</xsd:sequence>
<br>>>
</xsd:complexType>
<br>>> </xsd:element>
<br>>> <xsd:element
<br>>> <xsd:element
name="status">
<br>>>
<xsd:complexType>
<br>>>
<xsd:sequence>
<br>>>
<br>>>
</xsd:sequence>
<br>>>
</xsd:complexType>
<br>>> </xsd:schema>
<br>>>
<br>>>targetNamespace="<a href="http://localhost/PgnServiceRequest/publish/createTicket">http://localhost/PgnServiceRequest/publish/createTicket</a>"
<br>>>xmlns:tns="<a href="http://localhost/PgnServiceRequest/publish/createTicket">http://localhost/PgnServiceRequest/publish/createTicket</a>"
<br>>> <xsd:import
<br>>>namespace="<a href="http://sn000046/PgnServiceRequest/publish" /">http://sn000046/PgnServiceRequest/publish"/</a>>
<br>>> <xsd:complexType
<br>>>
<xsd:sequence>
<br>>>
<br>>>
<br>>>
</xsd:sequence>
<br>>>
<br>>> </xsd:complexType>
name="status">
<br>>>
<xsd:sequence>
<br>>>
<br>>>
<br>>>
</xsd:sequence>
<br>>>
<br>>>
<br>>></wsdl:types>
<br>>>
<br>>><wsdl:message name="createTicket">
<br>>><wsdl:part name="createTicket" element="wsdns1:createTicket"/>
<br>>></wsdl:message>
<br>>>
<br>>><wsdl:message name="createTicketOutput">
<br>>><wsdl:part name="status" element="wsdns1:status"/>
<br>>><wsdl:portType name="PgnServiceRequest_publishPortType">
<br>>><wsdl:operation name="createTicket">
<br>>><wsdl:input message="tns:createTicket"/>
<br>>><wsdl:output message="tns:createTicketOutput"/>
<br>>></wsdl:operation>
<br>>></wsdl:portType>
<br>>><wsdl:binding name="PgnServiceRequest_publishBinding"
<br>>>type="tns:PgnServiceRequest_publishPortType">
<br>>><soap:binding style="document"
<br>>>transport="<a href="http://schemas.xmlsoap.org/soap/http" /">http://schemas.xmlsoap.org/soap/http"/</a>>
<br>>><soap:operation soapAction=""/>
<br>>><wsdl:input>
<br>>><soap:body use="literal"/>
<br>>></wsdl:input>
<br>>><wsdl:output>
<br>>></wsdl:output>
<br>>></wsdl:binding>
<br>>><wsdl:service name="PgnServiceRequest_publishService">
<br>>><wsdl:port name="PgnServiceRequest_publishPort0"
<br>>>binding="tns:PgnServiceRequest_publishBinding">
<br>>><soap:address location="<a href="http://sn000046:9999/soap/default" /">http://sn000046:9999/soap/default"/</a>>
<br>>></wsdl:port>
<br>>></wsdl:service>
<br>>></wsdl:definitions>
<br>>>
<br>>>thanks for any suggestions.
<br>>>
<br>>
<br>>
<br>></blockquote>
</html>
--------------7663F748B8962C5FFD0C05DC--
| Re: WSDL Issues - Namespaces [message #87058 is a reply to message #86996] |
Thu, 24 March 2005 14:32  |
Thanks Chris. This is starting to make more sense.
I got around the prefix issue by using a wildcard in the xql query for
my interface.
Thanks again for the quick response it really helped me understand this
namespace structure.
markg
Chris Brealey wrote:
> Mark,
> significant outside of the document within which it is used. It's the
> prefixes they want independent of each other.
> functions only as a placeholder for a namespace name. Applications
> SHOULD use the namespace name, not the prefix, in constructing names
> Cheers - CB.
>> the WSDL document.
>> question.
>> markg
>> Jeff Liu wrote:
>> > Hi Mark,
>> know, the
>> <http://sn000046/PgnServiceRequest/publish>>
>> the prefix
>> this
>> > correctly.
>> >>is unresolved
>> >>IWAB0381I
>> mention
>> below,
>> needs to
>> not allow
>> elements, it
>> parsing.
>> references to
>> saying
>> Explorer
>> has some
>> receives
>> they are
>> above. The
>> suppress any
>> > Thanks,
>> > Jeff
>> seems
>> bring it
>> using
>> from the
>> >>wsdl.
>> >>is unresolved
>> >>IWAB0381I
>> causing
>> >><wsdl:types>
>> >> <xsd:complexType>
>> >> <xsd:sequence>
>> >> </xsd:sequence>
>> >> </xsd:complexType>
>> >> </xsd:element>
>> >> <xsd:complexType>
>> >> <xsd:sequence>
>> >> </xsd:sequence>
>> >> </xsd:complexType>
>> >> </xsd:element>
>> >> </xsd:schema>
>> >> <xsd:import
>> >> <xsd:sequence>
>> >> </xsd:sequence>
>> >> </xsd:complexType>
>> >> <xsd:sequence>
>> >> </xsd:sequence>
>> >> </xsd:complexType>
>> >> </xsd:schema>
>> >></wsdl:types>
>> >></wsdl:message>
>> >></wsdl:message>
>> >></wsdl:operation>
>> >></wsdl:portType>
>> <http://schemas.xmlsoap.org/soap/http>>
>> >><wsdl:input>
>> >></wsdl:input>
>> >><wsdl:output>
>> >></wsdl:output>
>> >></wsdl:operation>
>> >></wsdl:binding>
>> <http://sn000046:9999/soap/default>>
>> >></wsdl:port>
>> >></wsdl:service>
>> >></wsdl:definitions>
Current Time: Thu Nov 20 20:21:52 EST 2025
Powered by FUDForum. Page generated in 0.06181 seconds
