Home » Modeling » BPEL Designer » re: Should BPEL Designer work with Eclipse 3.3?
re: Should BPEL Designer work with Eclipse 3.3? [message #7726] Sat, 12 May 2007 15:53 Go to next message
Originally posted by: doug14.pacbell.net
I had it working a while back with Eclipse 3.2.
But I've started over with 3.3 but BPEL Designer will not install from the
update site.
WST Server Core (1.5.2.v200610070620------1G955G6C6L) requires feature
"org.eclipse.rcp (3.2.0)", or equivalent.
I can't seem to find this....appears to be a 3.2 thing?
any thoughts would be appreciated....
Re: Should BPEL Designer work with Eclipse 3.3? [message #7745 is a reply to message #7726] Sat, 12 May 2007 16:15 Go to previous messageGo to next message
more info....checking my plugin details, I see that I have rcp
I have the plugin org.eclipse.rcp 3.2.0 v20060605
this makes more sense ...that Eclpse 3.3 has this.
But why doesn't the update manager see it?
"Doug Goldie" <doug14@pacbell.net> wrote in message
news:f255u4$vp1$1@build.eclipse.org...
> update site.
Re: Should BPEL Designer work with Eclipse 3.3? [message #7829 is a reply to message #7726] Wed, 16 May 2007 20:51 Go to previous message
I haven't tried the 3.3 train yet. Not sure what the problem is ... but
I'l cc the list perhaps someone there has a smarter answer.
-m
Doug Goldie wrote:
> update site.
Previous Topic:BPEL assign problem
Next Topic:Two question about the src code and the .bpelex file
Current Time: Fri Nov 07 01:13:23 EST 2025
Powered by FUDForum. Page generated in 0.02965 seconds
