Home » Archived » BIRT » How to set colspan of a cell in table via the graphical editor?
How to set colspan of a cell in table via the graphical editor? [message #85543] Sun, 30 October 2005 01:44 Go to next message
Originally posted by: pcasey.earthlink.net
I want to lay out a table something like:
GROUP TITLE -------------------------------------- END OF ROW
COLUMN A | COLUMN B | COLUMN C
There's an analogous example in the sample reports (the classic cars
example):
http://www.eclipse.org/birt/examples/solution/ProductCatalog .html
Where the "Model Description" cell has a colspan of 3.
If I pull up the XML of the sample, it's obvious that the way to make a cell
span 3 columns is, unsurprisingly to add the attribute colSpan="3" to the
cell.
I can't for the life of me figure out how to do this via the graphical
editor though. Can anyone point me in the right direction as to how to do
this?
--- Pat
Re: How to set colspan of a cell in table via the graphical editor? [message #85588 is a reply to message #85543] Sun, 30 October 2005 11:51 Go to previous messageGo to next message
In case anyone else runs into this:
Select the cell you want to extend to a colspan > 1. Shit->click on the cell
to its right. Right click on "merge".
Re: How to set colspan of a cell in table via the graphical editor? [message #85665 is a reply to message #85543] Mon, 31 October 2005 04:37 Go to previous message
Hi, Patrick
You can merge cells by context menu action.
Try to select the cells you want to merge and right click on them
Thenks
Qiangsheng
"Patrick Casey" <pcasey@earthlink.net> д
Previous Topic:Rotate text
Next Topic:How to Repeat a Chart per Group
Current Time: Sat Jul 12 07:56:42 EDT 2025
Powered by FUDForum. Page generated in 0.03211 seconds
