Home » Archived » Visual Editor (VE) » Trouble creating an SWT application visual class with 3.1 M6
Trouble creating an SWT application visual class with 3.1 M6 [message #85408] Sat, 02 April 2005 16:54 Go to next message
Originally posted by: lesliesoftware.yahoo.com
I just downloaded 3.1M6 and, using the update manager, installed VE. I
guess my first question is should it work? I was able to create a Swing
visual class and that worked fine.
When I tried to craete an SWT application I recived an error saying
"Creation of element failed. See error log for more details." Attached
is the error log entry.
Ian
!ENTRY org.eclipse.jdt.ui 4 10001 2005-04-02 16:47:26.562
!MESSAGE Internal Error
!STACK 0
java.lang.reflect.InvocationTargetException
at org.eclipse.jface.operation.ModalContext.run(ModalContext.ja va:327)
at org.eclipse.jface.wizard.WizardDialog.run(WizardDialog.java: 830)
org.eclipse.jdt.internal.ui.wizards.NewElementWizard.perform Finish(NewElementWizard.java:130)
org.eclipse.ve.internal.java.codegen.wizards.NewVisualClassC reationWizard.performFinish(NewVisualClassCreationWizard.jav a:407)
org.eclipse.jface.wizard.WizardDialog.finishPressed(WizardDi alog.java:676)
org.eclipse.jface.wizard.WizardDialog.buttonPressed(WizardDi alog.java:349)
at org.eclipse.jface.dialogs.Dialog$2.widgetSelected(Dialog.jav a:556)
org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:89)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :82)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:842)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:2894)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2527)
at org.eclipse.jface.window.Window.runEventLoop(Window.java:803 )
at org.eclipse.jface.window.Window.open(Window.java:781)
at org.eclipse.ui.actions.NewWizardAction.run(NewWizardAction.j ava:181)
at org.eclipse.jface.action.Action.runWithEvent(Action.java:996 )
org.eclipse.jface.action.ActionContributionItem.handleWidget Selection(ActionContributionItem.java:538)
org.eclipse.jface.action.ActionContributionItem.access$2(Act ionContributionItem.java:488)
org.eclipse.jface.action.ActionContributionItem$5.handleEven t(ActionContributionItem.java:400)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1570)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1534)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:306)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:143)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:103)
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:228)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:344)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:156)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:315 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:268)
at org.eclipse.core.launcher.Main.run(Main.java:942)
at org.eclipse.core.launcher.Main.main(Main.java:926)
Caused by: java.lang.NullPointerException
org.eclipse.jdt.internal.core.JavaProject.getResolvedClasspa th(JavaProject.java:2050)
org.eclipse.jdt.internal.core.ClasspathEntry.validateClasspa th(ClasspathEntry.java:1101)
org.eclipse.jdt.internal.core.SetClasspathOperation.verify(S etClasspathOperation.java:820)
org.eclipse.jdt.internal.core.JavaModelOperation.runOperatio n(JavaModelOperation.java:760)
org.eclipse.jdt.internal.core.JavaProject.setRawClasspath(Ja vaProject.java:2739)
org.eclipse.jdt.internal.core.JavaProject.setRawClasspath(Ja vaProject.java:2755)
org.eclipse.ve.internal.java.codegen.wizards.NewVisualClassC reationWizard.verifyProjectClassPath(NewVisualClassCreationW izard.java:345)
org.eclipse.ve.internal.java.codegen.wizards.NewVisualClassC reationWizard.finishPage(NewVisualClassCreationWizard.java:3 06)
org.eclipse.jdt.internal.ui.wizards.NewElementWizard$2.run(N ewElementWizard.java:114)
org.eclipse.jdt.internal.core.BatchOperation.executeOperatio n(BatchOperation.java:34)
org.eclipse.jdt.internal.core.JavaModelOperation.run(JavaMod elOperation.java:710)
at org.eclipse.core.internal.resources.Workspace.run(Workspace. java:1714)
at org.eclipse.jdt.core.JavaCore.run(JavaCore.java:3665)
org.eclipse.jdt.internal.ui.actions.WorkbenchRunnableAdapter .run(WorkbenchRunnableAdapter.java:87)
org.eclipse.jface.operation.ModalContext$ModalContextThread. run(ModalContext.java:113)
Root exception:
Re: Trouble creating an SWT application visual class with 3.1 M6 [message #85427 is a reply to message #85408] Sun, 03 April 2005 09:32 Go to previous messageGo to next message
I tried upgrading EMF and VE to the latest I could find. I am using:
Eclipse: 3.1.0 I20050401-1645
EMF: 2.0.2.R200503151315 200503151315
GEF: 3.0 200408311615
VE: 1.0.2.1 200409191449
And I still see the problem.
Ian
Re: Trouble creating an SWT application visual class with 3.1 M6 [message #85440 is a reply to message #85427] Sun, 03 April 2005 10:08 Go to previous messageGo to next message
Originally posted by: myersj.gmail.com
Ian,
VE 1.0.X does not run on Eclipse 3.1. Try the latest VE 1.1 Integration
build
( http://download.eclipse.org/tools/ve/downloads/drops/I-I2005 0318-200503181537/index.html)
and the requirements listed on that page or use Eclipse 3.0.2.
Hope this helps,
- Jeff
> Ian
Re: Trouble creating an SWT application visual class with 3.1 M6 [message #85471 is a reply to message #85440] Mon, 04 April 2005 06:37 Go to previous messageGo to next message
> build
<snip>
Thanks for the reply. Unfortunatly that version of VE with the matching
GEF and EMF does not work with M6. To be sure I deleted my first 3.1
install and started over with just the versions suggested on the web page.
I still get the same error.
I look forward to the next integration version of VE. In the mean time my
Java 5 work will have to be sans VE.
Thanks again,
Ian
Re: Trouble creating an SWT application visual class with 3.1 M6 [message #85537 is a reply to message #85471] Mon, 04 April 2005 13:51 Go to previous messageGo to next message
Visual Editor 1.0.2 works with eclipse 3.1M4, but no newer milestone of
eclipse (3.1M5, 3.1M6).
For me, the Java 5 support in M4 is sufficient. I only have problems with
static imports (text completion throws NullPointerException, when a static
import is used).
I am using the following packages:
- eclipse-SDK-3.1M4-win32.zip
- emf-sdo-runtime-2.0.1.zip
- GEF-runtime-3.0.1.zip
- VE-runtime-1.0.2.zip
Kind regards
Stefan
Re: Trouble creating an SWT application visual class with 3.1 M6 [message #85807 is a reply to message #85537] Wed, 06 April 2005 11:18 Go to previous message
We are trying to get a M6 based build going...
M6 has move everything in a plugin to be a single .jar, removed some API from M5 (not sure if to call them APIs, as they
were not in 3.0.x), and changed the build process.... This have thrown a few wrenches to VE M1 timing... from building
correctly, to launch the target VM with proper access to the swt .dll (which is not loose anymore, it is inside the swt
plugin's jar). As a matter of fact, the (Eclipse) launch SWT application does not work in M6 for the same reason.
Moving everything into a single .jar is a good thing overall for maintenance/deployment/performance/signature-signing
etc.; but it brings many skeletons out :-(
Re: Trouble creating an SWT application visual class with 3.1 M6 [message #606224 is a reply to message #85408] Sun, 03 April 2005 09:32 Go to previous message
Ian
Re: Trouble creating an SWT application visual class with 3.1 M6 [message #606227 is a reply to message #85427] Sun, 03 April 2005 10:08 Go to previous message
Ian,
build
Hope this helps,
- Jeff
> Ian
Re: Trouble creating an SWT application visual class with 3.1 M6 [message #606231 is a reply to message #85440] Mon, 04 April 2005 06:37 Go to previous message
> build
<snip>
Thanks again,
Ian
Re: Trouble creating an SWT application visual class with 3.1 M6 [message #606238 is a reply to message #85471] Mon, 04 April 2005 13:51 Go to previous message
import is used).
Kind regards
Stefan
Re: Trouble creating an SWT application visual class with 3.1 M6 [message #606278 is a reply to message #85537] Wed, 06 April 2005 11:18 Go to previous message
Previous Topic:Cannot get VE editor menus to show up in 3.0.2
Next Topic:Trouble running VE with Eclipse 3.0.2
Current Time: Fri Nov 07 16:48:23 EST 2025
Powered by FUDForum. Page generated in 0.05326 seconds
