Home » Archived » Test and Performance Tools Platform (TPTP) » Causes for custom rule not appearing???
Causes for custom rule not appearing??? [message #85387] Tue, 17 October 2006 08:59 Go to next message
Originally posted by: matthew.gregory.us.michelin.com
I know this is a terrible question, but I'm grasping at straws on this
one. I've created a rule (a template), added it to my plugin.xml, etc,
but it will not appear in the rules list. I've messed with just about
every setting I can think of, deleted my workspace, compared my plugin.xml
to a known working one, added other templates which work fine, and even
added this rule class to a different plugin project (in a different
workspace) which worked fine.
Has anyone run into anything like this? Or any advice on things to look
at which could cause this behavior? Does anyone know the Eclipse
class(es) which read(s) the plugin.xml and performs whatever validation
necessary?
Thank you
matt.
Re: Causes for custom rule not appearing??? [message #85477 is a reply to message #85387] Tue, 17 October 2006 11:09 Go to previous messageGo to next message
How do I spell releif? J-A-V-A-1-.-4
Don't know what the problem was, but in order to get my rule to display I
had to "enable project specific settings" (in project properties) and
change my compiler compliance setting from 5.0 to 1.4
Re: Causes for custom rule not appearing??? [message #85510 is a reply to message #85477] Tue, 17 October 2006 20:06 Go to previous messageGo to next message
Originally posted by: s_gutz.ca.ibm.com
We have no specific support for Java 5 yet.
Steve
> I had to "enable project specific settings" (in project properties) and
Re: Causes for custom rule not appearing??? [message #85538 is a reply to message #85510] Wed, 18 October 2006 09:13 Go to previous messageGo to next message
That's ok, neither do we. I must have failed to change it when I created
the project. But thank you for the confirmation.
Re: Causes for custom rule not appearing??? [message #85612 is a reply to message #85510] Thu, 19 October 2006 11:04 Go to previous message
Hi Steve,
According to our JRE/OS support statement, we're supposed to be compliant
with both 1.4 and 5:
http://www.eclipse.org/tptp/home/project_info/releaseinfo/4. 2/support.html#Workbench
"Steve Gutz" <s_gutz@ca.ibm.com> wrote in message
news:eh3r6e$vnn$1@utils.eclipse.org...
> Steve
Previous Topic:Testing Plugin
Next Topic:Zipping test asset files make them impossible to share on CVS/SVN
Current Time: Sun Jul 27 08:43:23 EDT 2025
Powered by FUDForum. Page generated in 0.02904 seconds
