Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » Trouble using 'embedded' annotation
Trouble using 'embedded' annotation [message #85254] Tue, 29 May 2007 17:25 Go to next message
Hi All,
I'm still having trouble making embedded objects work. I'm trying to get
VSPDate and VSPDateTime to appear in the table for my Network object which
extends the Persistent object. I see other simple fields from Persistent
show up. However the embeded columns from lastUpdateDateTime and
versionCreateDate do not appear in the database.
Thanks for any suggestions,
Jason Henriksen
<p:persistence-mapping xmlns:p="http://www.eclipse.org/emft/teneo"
xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xsi:schemaLocation="http://www.eclipse.org/emft/teneo
persistence-mapping-hibernate.xsd ">
<p:epackage namespace-uri="http://vsp.com/">
<!-- ignore the transport classes -->
<p:eclass name="CreateType"><p:transient /></p:eclass>
<p:eclass name="CreateResponseType"><p:transient /></p:eclass>
<p:eclass name="DeleteType"><p:transient /></p:eclass>
<p:eclass name="DeleteResponseType"><p:transient /></p:eclass>
<!-- make vspdate embeddable -->
<p:eclass name="VSPDateTime"> <p:embeddable/> </p:eclass>
<p:eclass name="VSPDate"> <p:embeddable/> </p:eclass>
<!-- embed the dates -->
<p:eclass name="Persistent">
<p:property name="lastUpdateDateTime">
<p:embedded/>
</p:property>
<p:property name="versionCreateDate">
<p:embedded/>
</p:property>
</p:eclass>
</p:epackage>
</p:persistence-mapping>
Re: Trouble using 'embedded' annotation [message #85271 is a reply to message #85254] Tue, 29 May 2007 17:41 Go to previous messageGo to next message
Hi Jason,
How does the resulting hbm look like (hbDataStore.getMappingXML())?
gr. Martin
Jason Henriksen wrote:
> Hi All,
> Jason Henriksen
> <p:embedded/>
> </p:property>
> <p:embedded/>
> </p:property>
> </p:eclass>
> </p:epackage>
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: Trouble using 'embedded' annotation [message #85286 is a reply to message #85271] Tue, 29 May 2007 18:24 Go to previous messageGo to next message
<!DOCTYPE hibernate-mapping PUBLIC "-//Hibernate/Hibernate Mapping DTD
3.0//EN" "http://hibernate.sourceforge.net/hibernate-mapping-3.0.dtd">
<!-- Generated by Teneo on Tue May 29 14:10:18 PDT 2007 -->
<hibernate-mapping>
<class name="com.vsp.bl.base.impl.RootObjectImpl" entity-name="RootObject"
abstract="false" lazy="false" discriminator-value="RootObject"
table="`rootobject`">
<meta attribute="eclassName">RootObject</meta>
<meta attribute="epackage">http://vsp.com/</meta>
<id type="long" name="e_id" column="e_id"
access=" org.eclipse.emf.teneo.hibernate.mapping.identifier.Identifie rPropert
yHandler">
<meta attribute="syntheticId">true</meta>
<generator class="native"/>
</id>
<discriminator column="`dtype`" type="string"/>
<version name="e_version" column="e_version"
access=" org.eclipse.emf.teneo.hibernate.mapping.property.VersionProp ertyHand
ler">
<meta attribute="syntheticVersion">true</meta>
</version>
<property name="empty" lazy="false" insert="true" update="true"
not-null="false" unique="false" type="boolean">
<column not-null="false" unique="false" name="`empty`"/>
</property>
</class>
<subclass name="com.vsp.bl.base.impl.BusinessKeyImpl"
entity-name="BusinessKey" abstract="false" lazy="false" extends="RootObject"
discriminator-value="BusinessKey">
<meta attribute="eclassName">BusinessKey</meta>
</subclass>
<subclass name="com.vsp.bl.base.impl.PersistentImpl"
entity-name="Persistent" abstract="false" lazy="false" extends="RootObject"
discriminator-value="Persistent">
<meta attribute="eclassName">Persistent</meta>
<component name="lastUpdateDateTime"
class="com.vsp.bl.base.impl.VSPDateTimeImpl"/>
<property name="lastUpdateId" lazy="false" insert="true" update="true"
not-null="false" unique="false" type="java.lang.String">
<column not-null="false" unique="false" name="`lastupdateid`"/>
</property>
<property name="lockCount" lazy="false" insert="true" update="true"
not-null="false" unique="false" type="int">
<column not-null="false" unique="false" name="`lockcount`"/>
</property>
<component name="versionCreateDate"
class="com.vsp.bl.base.impl.VSPDateImpl"/>
</subclass>
<subclass name="com.vsp.bl.base.impl.EntityImpl" entity-name="Entity"
abstract="false" lazy="false" extends="Persistent"
discriminator-value="Entity">
<meta attribute="eclassName">Entity</meta>
<many-to-one name="businessKey" entity-name="BusinessKey" cascade="all"
lazy="false" insert="true" update="true" not-null="false">
name="`businesskey_businesskey_e_id`"/>
</many-to-one>
<many-to-one name="uuid" entity-name="UUID" cascade="all" lazy="false"
<column not-null="false" unique="false" name="`uuid_uuid_e_id`"/>
</many-to-one>
<property name="businessTransactionId" lazy="false" insert="true"
update="true" not-null="false" unique="false" type="int">
<column not-null="false" unique="false" name="`businesstransactionid`"/>
</property>
<property name="version" lazy="false" insert="true" update="true"
<column not-null="false" unique="false" name="`version`"/>
</property>
</subclass>
<subclass name="com.vsp.bl.base.impl.NetworkImpl" entity-name="Network"
abstract="false" lazy="false" extends="Entity"
discriminator-value="Network">
<meta attribute="eclassName">Network</meta>
<property name="description" lazy="false" insert="true" update="true"
<column not-null="false" unique="false" name="`description`"/>
</property>
<property name="name" lazy="false" insert="true" update="true"
<column not-null="false" unique="false" name="`name`"/>
</property>
</subclass>
<class name="com.vsp.bl.base.impl.UUIDImpl" entity-name="UUID"
abstract="false" lazy="false" discriminator-value="UUID" table="`uuid`">
<meta attribute="eclassName">UUID</meta>
yHandler">
</id>
ler">
</version>
<property name="uuidImpl" lazy="false" insert="true" update="true"
not-null="true" unique="false" type="java.math.BigInteger">
<column not-null="true" unique="false" name="`uuidimpl`"/>
</property>
</class>
</hibernate-mapping>
"Martin Taal" <mtaal@elver.org> wrote in message
news:f3i6lq$6a0$1@build.eclipse.org...
> Hi Jason,
> gr. Martin
> > Hi All,
get
which
Persistent
> > Jason Henriksen
> > <?xml version="1.0" encoding="UTF-8"?>
> > <p:embedded/>
> > </p:property>
> > <p:embedded/>
> > </p:property>
> > </p:eclass>
> > </p:epackage>
> The Netherlands
Re: Trouble using 'embedded' annotation [message #85302 is a reply to message #85286] Tue, 29 May 2007 23:40 Go to previous messageGo to next message
They are embedded (see the component tag) but the embedded types do not seem to have any properties.
How does the ecore of the embedded (embeddable) types look like?
gr. Martin
> <hibernate-mapping>
> yHandler">
> </id>
> ler">
> </version>
> </property>
> </class>
> </subclass>
> </property>
> </property>
> </subclass>
> </many-to-one>
> </many-to-one>
> </property>
> </property>
> </subclass>
> </property>
> </property>
> </subclass>
> yHandler">
> </id>
> ler">
> </version>
> </property>
> </class>
>> Hi Jason,
>> gr. Martin
>>> Hi All,
> get
> which
> Persistent
>>> Jason Henriksen
>>> <p:embedded/>
>>> </p:property>
>>> <p:embedded/>
>>> </p:property>
>>> </p:eclass>
>>> </p:epackage>
>> The Netherlands
The Netherlands
Re: Trouble using 'embedded' annotation [message #85353 is a reply to message #85302] Wed, 30 May 2007 19:04 Go to previous message
Right you are. Somehow that definition information got lost from my XSD
model. *sigh*
Sorry for the useless post.
Jason
Re: Trouble using 'embedded' annotation [message #606817 is a reply to message #85254] Tue, 29 May 2007 17:41 Go to previous message
Hi Jason,
gr. Martin
> Hi All,
> Jason Henriksen
> <p:embedded/>
> </p:property>
> <p:embedded/>
> </p:property>
> </p:eclass>
> </p:epackage>
The Netherlands
Re: Trouble using 'embedded' annotation [message #606821 is a reply to message #85271] Tue, 29 May 2007 18:24 Go to previous message
<hibernate-mapping>
yHandler">
</id>
ler">
</version>
</property>
</class>
</subclass>
</property>
</property>
</subclass>
</many-to-one>
</many-to-one>
</property>
</property>
</subclass>
</property>
</property>
</subclass>
yHandler">
</id>
ler">
</version>
</property>
</class>
> Hi Jason,
> gr. Martin
> > Hi All,
get
which
Persistent
> > Jason Henriksen
> > <p:embedded/>
> > </p:property>
> > <p:embedded/>
> > </p:property>
> > </p:eclass>
> > </p:epackage>
> The Netherlands
Re: Trouble using 'embedded' annotation [message #606825 is a reply to message #85286] Tue, 29 May 2007 23:40 Go to previous message
gr. Martin
> <hibernate-mapping>
> yHandler">
> </id>
> ler">
> </version>
> </property>
> </class>
> </subclass>
> </property>
> </property>
> </subclass>
> </many-to-one>
> </many-to-one>
> </property>
> </property>
> </subclass>
> </property>
> </property>
> </subclass>
> yHandler">
> </id>
> ler">
> </version>
> </property>
> </class>
>> Hi Jason,
>> gr. Martin
>>> Hi All,
> get
> which
> Persistent
>>> Jason Henriksen
>>> <p:embedded/>
>>> </p:property>
>>> <p:embedded/>
>>> </p:property>
>>> </p:eclass>
>>> </p:epackage>
>> The Netherlands
The Netherlands
Re: Trouble using 'embedded' annotation [message #606834 is a reply to message #85302] Wed, 30 May 2007 19:04 Go to previous message
model. *sigh*
Jason
Previous Topic:[Teneo] Cannot override EntityMapper
Next Topic:[Teneo] Cannot override EntityMapper
Current Time: Sun Jul 27 12:34:17 EDT 2025
Powered by FUDForum. Page generated in 0.07590 seconds
