jextract error => DTLJ failure? [message #7675] |
Sat, 22 November 2008 18:40  |
WInXP; IBM JVM:
java version "1.5.0"
Java(TM) 2 Runtime Environment, Standard Edition (build
pwi32dev-20070511 (SR5))
IBM J9 VM (build 2.3, J2RE 1.5.0 IBM J9 2.3 Windows XP x86-32
j9vmwi3223-20070426 (JIT enabled)
J9VM - 20070420_12448_lHdSMR
JIT - 20070419_1806_r8
GC - 200704_19)
JCL - 20070511
Rather often when running "jextract" (from that JVM) to create the zip
necessary for DTLJ, jextract reports (these are all the cases):
could not read J9Class (464 bytes) at 059B5E68
could not read J9Class (480 bytes) at 05C03E68
could not read J9Class (456 bytes) at 063EAE60
could not read J9Class (464 bytes) at 05BC6E90
could not read J9Class (456 bytes) at 05687E88
could not read J9Class (464 bytes) at 05CEAE90
What's up with that?
I also often have the result that MAT+DTLJ reports no memory usage by
anyone except the class-loaders; if that bogus report occurs, it has
always (so far) been the case that one of the above errors in jextract
had occurred. (But some of the jextract errors did not seem to lead to
DTLJ errors.)
any ideas?
thanks,
Paul
Re: jextract error => DTFJ failure? [message #7778 is a reply to message #7718] |
Mon, 24 November 2008 21:34  |
Andrew Johnson wrote:
> I suggest you try using the latest IBM VM.
> We haven't done much testing with back levels of the VM and dumps from
> old VMs won't have accurate GC root support, so GC roots will be guessed
> and some may be missing and some bogus roots may be found with dumps
> from old VMs.
> This is why we say to use IBM JDK 1.4.2 SR12, 5.0 SR8a and 6.0 SR2 or
> later.
OK, that seemed to do the trick, thanks. (I should have paid more
attention to the SR level and its importance.) Now I have as follows,
and the MAT + DTLJ seems to be working reliably:
pwi32devifx-20081023a (SR8a + IZ34138))
j9vmwi3223ifx-20080811 (JIT enabled)
J9VM - 20080809_21892_lHdSMr
JIT - 20080620_1845_r8
GC - 200806_19)
JCL - 20081016a
thanks,
Paul
FUDForum. Page generated in 0.02847 seconds
