J2EE project in top-down tutorial not created properly [message #85068] |
Fri, 18 March 2005 15:06  |
Originally posted by: chandan.mathur.lmco.com
My Config: eclipse 3.1 M5a, Tomcat 4.1, JDK 1.4.2_07, WTP + Web service
jars all on Windows XP. Everything other than Windows is a fresh
installation.
JRE and server runtime have been configured as per online docs.
Running the top-down web service tutorial:
http://www.eclipse.org/webtools/jst/components/ws/tutorials/ TopDownWebService.html
Failure occurs in the set up section, step 6.
I get an error dialog titled "Save problems" and the message is: "Save
could not be completed. Some related files meay have already been saved.
Reason: Connection timed out: connect"
I click OK to ack the error dialog. The project shows an error. In the
'Problems' pane I see the following error:
CHKJ3000E: WAR Validation Failed:
org.eclipse.jst.j2ee.commonarchivecore.internal.exception.De ploymentDescriptorLoadException:
WEB-INF/web.xml AreaProject
I also noticed that the /AreaProject/WebContent/WEB-INF/web.xml file is
completely blank.
Any ideas as to what is going on here and how to fix it?
Thanks in advance.
Re: J2EE project in top-down tutorial not created properly [message #85099 is a reply to message #85068] |
Fri, 18 March 2005 18:00  |
The problem was associated with firewall settings in my office. Fixed.
> installation.
> completely blank.
> Thanks in advance.
FUDForum. Page generated in 0.06486 seconds
