| J2EE project in top-down tutorial not created properly [message #85068] | Fri, 18 March 2005 15:06  |  |
| Eclipse User  |  |  |  |  | Originally posted by: chandan.mathur.lmco.com
 My Config: eclipse 3.1 M5a, Tomcat 4.1, JDK 1.4.2_07, WTP + Web service
 jars all on Windows XP.  Everything other than Windows is a fresh
 installation.
 JRE and server runtime have been configured as per online docs.
 Running the top-down web service tutorial:
 http://www.eclipse.org/webtools/jst/components/ws/tutorials/ TopDownWebService.html
 Failure occurs in the set up section, step 6.
 I get an error dialog titled "Save problems" and the message is:  "Save
 could not be completed.  Some related files meay have already been saved.
 Reason: Connection timed out: connect"
 I click OK to ack the error dialog.  The project shows an error.  In the
 'Problems' pane I see the following error:
 CHKJ3000E: WAR Validation Failed:
 org.eclipse.jst.j2ee.commonarchivecore.internal.exception.De ploymentDescriptorLoadException:
 WEB-INF/web.xml	AreaProject
 I also noticed that the /AreaProject/WebContent/WEB-INF/web.xml file is
 completely blank.
 Any ideas as to what is going on here and how to fix it?
 Thanks in advance.
| Re: J2EE project in top-down tutorial not created properly [message #85099 is a reply to message #85068] | Fri, 18 March 2005 18:00  |  |
 The problem was associated with firewall settings in my office. Fixed.
 > installation.
 > completely blank.
 > Thanks in advance.
FUDForum. Page generated in 0.03025 seconds
