[Teneo] new user questions [message #85058] |
Fri, 25 May 2007 13:52  |
Hi All,
I'm very excited about the use of teneo but I'm running into a couple of
basic problems, both of which have to do with controlling the mapping. For
reference, I'm using the 0.8.0 version on EMF/SDO objectes generated from
XSD in RAD 7.
Here's my teneo.annotations.xml file:
<epackage
xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xsi:schemaLocation="http://www.elver.org/xsd/teneo/persistence-mapping-hiber
nate.xsd">
<!-- This has no effect -->
<eclass name="CreateType">
<transient/>
</eclass>
<!-- Neither does this -->
<eclass name="VSPDate">
<embeddable/>
</eclass>
<eclass name="VSPDateTime">
<embeddable/>
</eclass>
</epackage>
I have never used teneo or emf for a large project before, and only used
hibernate years ago. My goal is to make the CreateType not appear in the
database at all (It's just a SOAP wrapper) and I'd like the date objects to
be embedded directly into the table that uses them instead of them being a
sepeate table connected with a join.
Is this possible right now? I saw some posts about problems with transient,
but I wasn't sure if there was a way to work around that or not. I also
some something that I could make a specific use of an object embedded, but I
haven't found a way to make all uses of an object type embedded.
My teneo.properties file only contains:
PersistenceOptions.PERSISTENCE_XML=teneo.annotations.xml
Both the properties and the xml are located in the same place as the
documenation puts the hibernate.properties and the log4j.properties. I only
mention this because the output log doesn't mention anything about loading
the annotations...
Thank you for any suggestions you could offer,
Jason Henriksen
Re: [Teneo] new user questions [message #85074 is a reply to message #85058] |
Fri, 25 May 2007 14:32  |
Hi Jason,
The persistence xml option should be a classpath resource, so you need to add the / before the xml
filename:
PersistenceOptions.PERSISTENCE_XML=/teneo.annotations.xml
(this assumes that the teneo.annotations.xml is in the root of the classpath)
There is no option yet to let an embeddable class be embedded everywhere. You currently have to set
the Embedded annotation on each ereference. Please enter a bugzilla feature request to let Teneo
automatically embed all embeddable types.
gr. Martin
Jason Henriksen wrote:
> Hi All,
> XSD in RAD 7.
> <epackage
> nate.xsd">
> <transient/>
> </eclass>
> <embeddable/>
> </eclass>
> <embeddable/>
> </eclass>
> </epackage>
> the annotations...
> Jason Henriksen
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: [Teneo] new user questions [message #606801 is a reply to message #85058] |
Hi Jason,
filename:
gr. Martin
> Hi All,
> XSD in RAD 7.
> <epackage
> nate.xsd">
> <transient/>
> </eclass>
> <embeddable/>
> </eclass>
> <embeddable/>
> </eclass>
> </epackage>
> the annotations...
> Jason Henriksen
The Netherlands
FUDForum. Page generated in 0.03347 seconds
