Home » Newcomers » Newcomers » Tutorial SWT Standalone
Tutorial SWT Standalone [message #85034] Sat, 09 July 2005 10:09 Go to next message
Originally posted by: peter.ax.t-online.de
Hi everybody,
Dirk Gutsche wrote and til now no answer, I have the same probleme, what is
wrong ? the tutorial ? the downloaded file ?
I installed Eclipse and wanted to try the "Build a standalone SWT
application" tutorial. The cheat sheet gives the following instructions:
1. Download the SWT archive file from eclipse.org web site. Look for
the section titled SWT Binary and Source. Do not extract the archive
file, just save it to disk.
2. Select "Import..." from the File menu.
3. Select "Existing Projects into Workspace" and click on the Next
button.
4. Select "Select archive file:" and use the Browse button to locate
the SWT standalone archive you have previously downloaded.
5. Click on the "Finish" button
So I downloaded swt-3.0.2-win32.zip, followed steps 2-4, BUT:
The "Finish" button remains inactive, and the "Projects" field is empty.
I also tried extracting the archive and choosing various files from it,
and also "Select root directory", but nothing worked.
What did I do wrong? Any ideas? Did I download the wrong file?
Thank you!!
Peter Ax
Re: Tutorial SWT Standalone [message #85521 is a reply to message #85034] Mon, 11 July 2005 19:12 Go to previous messageGo to next message
Originally posted by: dzabel.snafu.de
Peter Ax schrieb:
> Hi everybody,
> button.
> Thank you!!
> Peter Ax
Just the same with me! I gave up for the moment; I would be very
interested if anybody solved this.
Thank you!
Dirk
Re: Tutorial SWT Standalone [message #85691 is a reply to message #85521] Tue, 12 July 2005 13:50 Go to previous message
>> Thank you!!
>> Peter Ax
SWT 3.0.2 cannot be imported using this wizard. However, SWT 3.1
can. Please get the SWT 3.1 download by following the link at
http://www.eclipse.org/swt/
-Billy
Previous Topic:Windows File Associations to Auto open in Eclipse
Next Topic:How to browse Filestructures using Eclipse
Current Time: Fri Jul 18 19:11:36 EDT 2025
Powered by FUDForum. Page generated in 0.10234 seconds
