| Eclipse 3.0: 100% CPU all the time [message #85031] |
Tue, 12 August 2003 14:56  |
Originally posted by: no.email.please
I tried various builds of the 3.0 line (3.0M1, 3.0M2, i20030723 and
i20030806) and they all have this same problem for me: even when I am
no longer using Eclipse (and it's iconified), it keeps my CPU at 100%
with a javaw process.
I use 2.1.1 every day and I never see this problem.
Has anyone else seen this?
Cedric
http://beust.com/weblog
| Re: Eclipse 3.0: 100% CPU all the time [message #85540 is a reply to message #85031] |
Wed, 13 August 2003 15:31   |
I get a somewhat similar problem, both with 3.0M2, and 3.0I20030806.
Eclipse will perform normally for a while. Then it gets into a state
where on some operations (Ctrl-Shift-T, find type is one that seems to
trigger it a lot), it will basically just freeze for anywhere from 30
seconds to a couple of minutes. During this time, the cpu usage is
almost 100%. Once it starts doing this for Ctrl-Shift-T, it will always
keep doing it, until I exit and come back in. There are also other
operations which seem to cause the freeze, but Ctrl-Shift-T is the most
common one. There also seems to be the same pause on exiting Eclipse
sometimes, except in that case it sometimes never exits at all, and I
have to kill it.
One consideration is that I installed this version of Eclipse to use a
workspace from a 2.1.1 installation, ie I did not start from scratch. I
did this since I have a lot of projects in the workspace, and it is such
an incredible pain to import a larger number of existing projects form
the filesystem. Once a new Integration build is out I will perhaps try a
clean install, where I start with an empty workspace, and go through the
normal import process.
| Re: Eclipse 3.0: 100% CPU all the time [message #116566 is a reply to message #85031] |
Wed, 12 November 2003 18:13  |
I have seen the same issue with 2.1 and 2.1.1.
Matt
FUDForum. Page generated in 0.09856 seconds
