[ATL] EFloat attribute assignment [message #85024] |
Tue, 24 June 2008 06:41 |
Hi all,
I am developing a very simple ATL transformation from Eclipse UML2 to
one of my DSL metamodels.
This is a simplified version of my rule:
rule SAcomponent_Clock{
from
s : UML2!Component
to
t : saveccm!Clock (
jitter <- 4.5,
The problem resides in the binding because the type of the jitter
attribute is EFloat and ATL works only with Double precision float
numbers, so I get the following Exception:
GRAVE: ****** BEGIN Stack Trace
GRAVE: message: cannot set feature saveccm!Clock.jitter to value 5.5
GRAVE: exception:
GRAVE: The value of type 'class java.lang.Double' must be of type 'class
java.lang.Float'
java.lang.ClassCastException: The value of type 'class java.lang.Double'
must be of type 'class java.lang.Float'
Does anyone know how to set an EFloat attribute to ATL?
It's overstated that I cannot modify the target metamodel changing the
type of the jitter attribute to EDouble!
Ivano
FUDForum. Page generated in 0.06142 seconds
