Home » Archived » M2M (model-to-model transformation) » [ATL] Problems with Contexts and ATL 2006
[ATL] Problems with Contexts and ATL 2006 [message #7664] Sun, 14 January 2007 00:31 Go to next message
Originally posted by: irbull.cs.uvic.ca
Is there a known issue with helper contexts and ATL 2006?
I have the following helper and context:
helper context ecore!EObject def: test() : String =
'test';
rule Example {
from s : ecore!EObject
to t : metamodel!Node (
name <- s.test()
It matches ecore!EObject fine, but the context doesn't work. I get
message: ERROR: could not find operation test on MOF!RelationshipType
having supertypes: [OclType, OclAny] (including Java operations)
If I don't use the context and use:
helper def: test2() : String =
'test2';
the name <- thisModule.test2()
works fine.
cheers,
ian
Re: [ATL] Problems with Contexts and ATL 2006 [message #7747 is a reply to message #7664] Sun, 14 January 2007 08:53 Go to previous messageGo to next message
Hi Ian,
I do not think there is such a specific issue in ATL 2006.
Are you sure this only happens with this version, and not with ATL 2004?
Do you have this problem with any metamodel, or only with the Ecore
metametamodel?
Could you please give your launch configuration?
Frédéric Jouault
> 'test';
> rule Example {
> name <- s.test()
> 'test2';
> works fine.
> cheers,
> ian
Re: [ATL] Problems with Contexts and ATL 2006 [message #8962 is a reply to message #7747] Wed, 17 January 2007 22:24 Go to previous messageGo to next message
that is a good question, I think it worked with 2004, bu I probably
wasn't doing it on the ecore!EObject.
What is the best way to give you my launch configuration (where are they
stored)?
cheers,
ian
Frédéric Jouault wrote:
> Hi Ian,
> metametamodel?
> Frédéric Jouault
>> 'test';
>> rule Example {
>> name <- s.test()
>> 'test2';
>> works fine.
>> cheers,
>> ian
Re: [ATL] Problems with Contexts and ATL 2006 [message #8982 is a reply to message #8962] Wed, 17 January 2007 22:25 Go to previous messageGo to next message
I am also having problems with distinct .. foreach. This may be
releated too.
cheers,
ian
> stored)?
> cheers,
> ian
>> Hi Ian,
>> metametamodel?
>> Regards,
>> Frédéric Jouault
>>> 'test';
>>> rule Example {
>>> name <- s.test()
>>> 'test2';
>>> works fine.
>>> cheers,
>>> ian
Re: [ATL] Problems with Contexts and ATL 2006 [message #9071 is a reply to message #8962] Thu, 18 January 2007 04:37 Go to previous messageGo to next message
Originally posted by: freddy.allilaire.univ-nantes.fr
Hi Ian,
You can save a launch configuration by using the tab "Common". You
should choose the option "Shared file". This will create a *.launch file
in the selected folder.
Freddy.
> stored)?
> cheers,
> ian
>> Hi Ian,
>> metametamodel?
>> Regards,
>> Frédéric Jouault
>>> 'test';
>>> rule Example {
>>> name <- s.test()
>>> 'test2';
>>> works fine.
>>> cheers,
>>> ian
Re: [ATL] Problems with Contexts and ATL 2006 [message #9194 is a reply to message #9071] Thu, 18 January 2007 14:32 Go to previous messageGo to next message
--------------070602000307010604040404
Here is my launch configuration.
However, I think the problem may be around SuperTypes and ATL.
-- @atlcompiler atl2006
module TestTransform; -- Module Template
create output : metamodel from My : ecore;
helper context ecore!EObject def: getMyString() : String =
self.toString();
rule Example {
name <- s.getMyString()
This transformation doesn't work:
****** BEGIN Stack Trace
message: ERROR: could not find operation getMyString on
MOF!RelationshipType having supertypes: [OclType, OclAny] (including
Java operations)
A.main() : ??#24 null
local variables = {self=TestTransform : ASMModule}
local stack = []
A.__exec__() : ??#8 null
local variables = {e=TransientLink {rule = 'Example', sourceElements =
{s = My!calls}, targetElements = {t = output!<notnamedyet>}, variables =
{}}, self=TestTransform : ASMModule}
local stack = []
A.__applyExample(1 : NTransientLink;) : ??#12 11:25-11:40
local variables = {t=output!<notnamedyet>, s=My!calls,
link=TransientLink {rule = 'Example', sourceElements = {s = My!calls},
targetElements = {t = output!<notnamedyet>}, variables = {}},
local stack = [output!<notnamedyet>, output!<notnamedyet>,
TestTransform : ASMModule]
****** END Stack Trace
But if I change the context to use OclAny it does work. It seems
strange that the rule matches the EObject but the helper doesn't.
Does it make sense to match EObject?
cheers,
ian
Freddy Allilaire wrote:
> Hi Ian,
> Freddy.
> Ian Bull a
Re: [ATL] Problems with Contexts and ATL 2006 [message #9214 is a reply to message #9194] Thu, 18 January 2007 16:17 Go to previous messageGo to next message
Where is RelationshipType defined?
Could you please try to use ecore!EModelElement instead of ecore!EObject
and report the results?
Frédéric Jouault
> self.toString();
> rule Example {
> Java operations)
> local stack = []
> = {s = My!calls}, targetElements = {t = output!<notnamedyet>}, variables
> = {}}, self=TestTransform : ASMModule}
> local stack = []
> cheers,
> ian
>> Hi Ian,
>> file in the selected folder.
>> Regards,
>> Freddy.
>>> they stored)?
>>> cheers,
>>> ian
>>>> Hi Ian,
>>>> 2004?
>>>> metametamodel?
>>>> Regards,
>>>> Frédéric Jouault
>>>>> 'test';
>>>>> rule Example {
>>>>> name <- s.test()
>>>>> 'test2';
>>>>> works fine.
>>>>> cheers,
>>>>> ian
> <?xml version="1.0" encoding="UTF-8" standalone="no"?>
> <launchConfiguration type="org.atl.eclipse.adt.launching.atlTransformation">
> <mapAttribute key="Libs"/>
> <mapAttribute key="Model Handler">
> <mapEntry key="metamodel" value="EMF"/>
> <mapEntry key="My" value=""/>
> <mapEntry key="output" value=""/>
> <mapEntry key="ecore" value="EMF"/>
> </mapAttribute>
> <mapAttribute key="Input">
> <mapEntry key="My" value="ecore"/>
> </mapAttribute>
> <stringAttribute key="Project Name" value="TestATL"/>
> <mapAttribute key="ModelType">
> <mapEntry key="metamodel" value="METAMODELOUTPUT"/>
> <mapEntry key="My" value="MODELINPUT"/>
> <mapEntry key="output" value="MODELOUTPUT"/>
> <mapEntry key="ecore" value="METAMODELINPUT"/>
> </mapAttribute>
> <mapAttribute key="Output">
> <mapEntry key="output" value="metamodel"/>
> </mapAttribute>
> <booleanAttribute key="Mode Debug" value="false"/>
> <booleanAttribute key="AllowInterModelReferences" value="false"/>
> <stringAttribute key="ATL File Name" value="/TestATL/TestTransform.atl"/>
> <mapAttribute key="Path">
> <mapEntry key="metamodel" value="/TestProject/metamodel.ecore"/>
> <mapEntry key="My" value="/TestProject/My.viewshaper"/>
> <mapEntry key="output" value="/TestATL/output.viewshaper"/>
> <mapEntry key="ecore" value="#EMF"/>
> </mapAttribute>
> </launchConfiguration>
Re: [ATL] Problems with Contexts and ATL 2006 [message #9234 is a reply to message #9214] Thu, 18 January 2007 16:51 Go to previous messageGo to next message
Hi Frederic,
RelationshipType is in my metamodel. Basically, I am trying to write a
transformation that will take any EMF meta model and transform it to
normalized form that I am using in my PhD. RelationshipType just
happens to be in the model that I am translating today, but tomorrow it
could be a library database.
Because I need it to work on any model, I am writing my transformations
using EObjects instead of the actual types (in this case
RelationshipType). I tried this with EModelElement, but nothing matches.
cheers,
ian
> Hello,
> Frédéric Jouault
>> self.toString();
>> rule Example {
>> Java operations)
>> local stack = []
>> sourceElements = {s = My!calls}, targetElements = {t =
>> output!<notnamedyet>}, variables = {}}, self=TestTransform : ASMModule}
>> local stack = []
>> cheers,
>> ian
>>> Hi Ian,
>>> Regards,
>>> Freddy.
>>>> they stored)?
>>>> cheers,
>>>> ian
>>>>> Hi Ian,
>>>>> 2004?
>>>>> metametamodel?
>>>>> Regards,
>>>>> Frédéric Jouault
>>>>>> 'test';
>>>>>> rule Example {
>>>>>> name <- s.test()
>>>>>> 'test2';
>>>>>> works fine.
>>>>>> cheers,
>>>>>> ian
>> </mapAttribute>
>> </mapAttribute>
>> </mapAttribute>
>> </mapAttribute>
>> </mapAttribute>
Re: [ATL] Problems with Contexts and ATL 2006 [message #10209 is a reply to message #9234] Thu, 18 January 2007 17:25 Go to previous messageGo to next message
Hi Ian,
1. About your transformation scenario
Is /TestProject/My.viewshaper an Ecore metamodel or a terminal model?
According to the header of your transformation (My : ecore) and to your
launch configuration (My->/TestProject/My.viewshaper & ecore->#EMF
(i.e., Ecore)), the file /TestProject/My.viewshaper should contain an
Ecore metamodel.
If /TestProject/My.viewshaper is not an Ecore metamodel then the
transformation cannot run properly because the launch configuration is
erroneous. I would even be surprised if anything was matched at all (see
the reason in the next section).
2. About using Ecore!EObject as a wildcard
Every Java object corresponding to an EMF model element is an instance
of the Java interface org.eclipse.emf.ecore.EObject. However, this does
not mean that you can use Ecore!EObject as a wildcard to match every
model element.
ATL does not let you handle Java objects but model elements. Therefore,
a source pattern typed with Ecore!EObject only matches model elements,
which type explicitly extends the Ecore!EObject metamodel element.
In practice, this means that only elements of Ecore metamodels
(including the Ecore metametamodel itself) are matched.
3. About writing transformations independent of the source metamodel
There are at least two possibilities to design a transformation scenario
that works whatever its source metamodel is:
1- Using reflective access (e.g., .refGetValue(propertyName)) and
imperative mode (because a declarative rule can only match elements of a
precise type).
2- Writing a Hight-Order Transformation (HOT) that generates one
transformation per metamodel. This technique is, for instance, used in
the http://www.eclipse.org/gmt/amw/examples/#UMLProfiles AMW scenario
(see figures 8 and 9 in the pdf documentation and/or the ATL
transformations MM2Profile.atl and Profile2MM.atl provided in the zip file).
Frédéric Jouault
Ian Bull wrote:
> Hi Frederic,
> cheers,
> ian
>> Hello,
>> ecore!EObject and report the results?
>> Regards,
>> Frédéric Jouault
>>> self.toString();
>>> rule Example {
>>> Java operations)
>>> local stack = []
>>> local stack = []
>>> cheers,
>>> ian
>>>> Hi Ian,
>>>> Regards,
>>>> Freddy.
>>>>> they stored)?
>>>>> cheers,
>>>>> ian
>>>>>> Hi Ian,
>>>>>> 2004?
>>>>>> Ecore metametamodel?
>>>>>> Regards,
>>>>>> Frédéric Jouault
>>>>>>> 'test';
>>>>>>> rule Example {
>>>>>>> name <- s.test()
>>>>>>> get message: ERROR: could not find operation test on
>>>>>>> 'test2';
>>>>>>> works fine.
>>>>>>> cheers,
>>>>>>> ian
>>> </mapAttribute>
>>> </mapAttribute>
>>> </mapAttribute>
>>> </mapAttribute>
>>> </mapAttribute>
Re: [ATL] Problems with Contexts and ATL 2006 [message #10239 is a reply to message #10209] Thu, 18 January 2007 18:02 Go to previous messageGo to next message
Thanks for the response.
My.viewshaper is a terminal model, and i have changed launch
configuration so my metamodel is the ecore model that viewshaper
conforms to (viewshaper.ecore).
Ok, so I understand that I can't use EObject to match anything, but it
does work. Since this is not really supported I would like to change
this. I am basically using the imperative method (with called rules)
already. I just use the EObject to start the whole thing.
Can I match OclAny? Is there a whildcard that will match any element
without writing a HOT.
ian
> Hi Ian,
> Ecore metamodel.
> model element.
> precise type).
> file).
> Frédéric Jouault
> Ian Bull wrote:
>> Hi Frederic,
>> it could be a library database.
>> transformations using EObjects instead of the actual types (in this
>> case RelationshipType). I tried this with EModelElement, but nothing
>> matches.
>> cheers,
>> ian
>>> Hello,
>>> Regards,
>>> Frédéric Jouault
>>>> self.toString();
>>>> rule Example {
>>>> Java operations)
>>>> local stack = []
>>>> local stack = []
>>>> cheers,
>>>> ian
>>>>> Hi Ian,
>>>>> Regards,
>>>>> Freddy.
>>>>>> probably wasn't doing it on the ecore!EObject.
>>>>>> are they stored)?
>>>>>> cheers,
>>>>>> ian
>>>>>>> Hi Ian,
>>>>>>> ATL 2004?
>>>>>>> Regards,
>>>>>>> Frédéric Jouault
>>>>>>>> 'test';
>>>>>>>> rule Example {
>>>>>>>> name <- s.test()
>>>>>>>> 'test2';
>>>>>>>> works fine.
>>>>>>>> cheers,
>>>>>>>> ian
>>>> </mapAttribute>
>>>> </mapAttribute>
>>>> </mapAttribute>
>>>> </mapAttribute>
>>>> </mapAttribute>
Re: [ATL] Problems with Contexts and ATL 2006 [message #10272 is a reply to message #10239] Thu, 18 January 2007 19:54 Go to previous messageGo to next message
Ok. You should now have a correct launch configuration.
I did not manage to reproduce this matching of "everything" with
EObject. Could you please give us a copy of your project (or of a
simplified version) exhibiting this behavior?
No, you cannot match OclAny. There is no wildcard that you can match.
Here is one possible solution:
create OUT : OUTMM from IN : INMM;
entrypoint rule Main() {
do {
for(e in
-- get all EClasses from INMM (%EMF stands for Ecore when
-- it is not explicitly referenced from the header)
"%EMF"!EClass.allInstancesFrom('INMM')->collect(e |
-- get all elements from IN typed by each EClass of INMM
e.allInstancesFrom('IN')
)->flatten()) {
thisModule.TransformOneElement(e);
rule TransformOneElement(e : OclAny) {
-- do something for each element of model IN
Frédéric Jouault
Re: [ATL] Problems with Contexts and ATL 2006 [message #10338 is a reply to message #10272] Thu, 18 January 2007 20:10 Go to previous messageGo to next message
--------------050205050800090402070206
I will try your solution,
In the mean time, this is an example that matches everything. I am using
the same MM for input and output (but I have tried it with other models
too).
cheers,
ian
Fr
Re: [ATL] Problems with Contexts and ATL 2006 [message #10370 is a reply to message #10272] Thu, 18 January 2007 20:31 Go to previous messageGo to next message
Also,
Did you literally mean "%EMF" because I get an error that says:
message: cannot find model %EMF
I searched the source code for the String %EMF (It is probably
recognized somewhere and it wasn't found.
Maybe I have the wrong version. I just checked out the plugins from the
gmt.atl project and added the missing libs (to engine).
cheers,
Ian
> Hello,
> do {
> for(e in
> )->flatten()) {
> Frédéric Jouault
Re: [ATL] Problems with Contexts and ATL 2006 [message #10402 is a reply to message #10370] Thu, 18 January 2007 20:49 Go to previous messageGo to next message
Yes, I literally mean "%EMF".
Here is the code that loads models in plugin org.atl.eclipse.adt.debug,
class org.atl.eclipse.adt.launching.AtlLaunchConfigurationDelegate , line
317:
toReturn.put("%" + modelHandler.get(mmName), mofmm);
It registers the metametamodel of the model handler used to load the
model under the name "%" + name of model handler.
Therefore "%EMF" corresponds to the Ecore metametamodel when you load at
least one model with EMF.
This scheme enables the use of several model handlers in a single
transformation.
Can you please check if you have the code mentionned above?
If not, then you might need to upgrade.
Frédéric Jouault
Re: [ATL] Problems with Contexts and ATL 2006 [message #10435 is a reply to message #10402] Thu, 18 January 2007 21:11 Go to previous messageGo to next message
Nope, I have version 1.10 which is from head. I noticed that you have
1.5.2.16 (this has the fix in it). Is this a separate branch?
Ian
> Hello,
> 317:
> transformation.
>> the gmt.atl project and added the missing libs (to engine).
> Frédéric Jouault
Re: [ATL] Problems with Contexts and ATL 2006 [message #10466 is a reply to message #10435] Thu, 18 January 2007 23:08 Go to previous messageGo to next message
The Eclipse debug API changes from version to version. In order to cope
with these changes, a new branch of the org.atl.eclipse.adt.debug plugin
was started for Eclipse 3.1: ADTDebugForEclipse3_1.
If you are using a version of Eclipse older than 3.0, then you should
check out this branch. The way to do this is documented in the "ATL
installation guide" section 3.2.2, page 8:
http://www.eclipse.org/m2m/atl/doc/ATL_Installation_Guide%5B v0.1%5D.pdf
Frédéric Jouault
> Cheers,
> Ian
>> Hello,
>> org.atl.eclipse.adt.debug, class
>> org.atl.eclipse.adt.launching.AtlLaunchConfigurationDelegate , line 317:
>> at least one model with EMF.
>> transformation.
>> Regards,
>> Frédéric Jouault
Re: [ATL] Problems with Contexts and ATL 2006 [message #10498 is a reply to message #10466] Thu, 18 January 2007 23:20 Go to previous message
Frederic,
I am using 3.3M4, I will try the 3.1 branch with this version.
thanks again for all your help, you must be up late! (or else you are
traveling).
cheers,
ian
> Hello,
> Best regards,
> Frédéric Jouault
>> Cheers,
>> Ian
>>> Hello,
>>> transformation.
>>> Regards,
>>> Frédéric Jouault
Previous Topic:[ATL] lauching ATL automaticaly
Next Topic:Empty Stack Exception
Current Time: Thu Jul 17 18:08:09 EDT 2025
Powered by FUDForum. Page generated in 0.10662 seconds
