| Re: [ATL] Running ATL from the command line [message #84995 is a reply to message #84985] |
Mon, 23 June 2008 12:35  |
Originally posted by: jmcq.cs.nuim.ie
Thanks! I've just found that myself and have downloaded Dennis
Wagelaar's ATL command line tool. Has anyone else used this? I'm
particularly interested to know what version of ATL, EMF etc it is
compatible with - I'm presuming Eclipse 3.2.2 and therefore equivalent
ATL and EMF versions. Does this imply it will work with later versions
of Eclipse/ATL? If not is there somewhere I can access a version of ATL
(including source code) for Eclipse 3.2.2 for Linux?
Thanks in advance,
Jacqui
Freddy Allilaire wrote:
> Hi Jacqui,
> The following link may help you:
> http://wiki.eclipse.org/ATL_Howtos#How_do_I_launch_transform ations_programmatically.3F
> HTH
> Freddy.
> Jacqui a écrit :
>> Does anyone know of any documentation or examples for running ATL from
>> the command line? Thanks.
>> Jacqui
FUDForum. Page generated in 0.03080 seconds
