| [Transaction] createPrivilegedRunnable [message #84964] |
Fri, 25 May 2007 10:51  |
Originally posted by: james.willans.xactium.com
Is it possible to enable an already running java thread to update
resources within a transactional editing domain? createPrivilegedRunnable
seems to force you to start the thread that is returned, but the thread in
question has already been started.
James
| Re: [Transaction] createPrivilegedRunnable [message #84998 is a reply to message #84964] |
Fri, 25 May 2007 11:40   |
Hi, James,
Please use the EMF newsgroup (included in my reply) for questions about the
Transaction component.
The privileged runnable doesn't impose any restriction on when a client
should start the thread that is to run the runnable.
TransactionalEditingDomain::createPrivilegedRunnable() doesn't return a
thread; it returns a runnable.
To execute the runnable on a thread that is already in progress, you can use
whatever means that thread provides. The most common example is the
display thread: you would run the runnable on the display thread using
Display::syncExec() on the Display object corresponding to the target
thread.
Note that it attempting to run the privileged runnable asynchronously (with
respect to the thread that currently owns the transaction) is absolutely
out of the question, as it will surely result in corruption of the
transaction state.
For more information, see the Programmer's Guide topic about sharing
transactions between threads, which is new since 1.1 M7.
HTH,
Christian
> James
| Re: [Transaction] createPrivilegedRunnable [message #85013 is a reply to message #84998] |
Oops ... forgot to redirect to the EMF newsgroup
cW
Christian W. Damus wrote:
> Hi, James,
> the Transaction component.
> use
> thread.
> (with respect to the thread that currently owns the transaction) is
> absolutely out of the question, as it will surely result in corruption of
> the transaction state.
> HTH,
> Christian
>> createPrivilegedRunnable seems to force you to start the thread that is
>> returned, but the thread in question has already been started.
>> Thanks,
>> James
| Re: [Transaction] createPrivilegedRunnable [message #606796 is a reply to message #84964] |
Hi, James,
thread.
transaction state.
HTH,
Christian
> James
| Re: [Transaction] createPrivilegedRunnable [message #606797 is a reply to message #84998] |
cW
> Hi, James,
> use
> thread.
> HTH,
> Christian
>> Thanks,
>> James
FUDForum. Page generated in 0.06024 seconds
