Home » Eclipse Projects » Eclipse Platform » Cvs and .classpath .project files
Cvs and .classpath .project files [message #84963] Sun, 29 June 2003 22:01 Go to next message
Originally posted by: paul.noemail.thankyou.com
Hi all,
How can I remove the .classpath and .project files from cvs sharing? I've
added them to the ignored resources list which hasn't made any difference -
they are still showing up in the synchronise window.
Any advice ?
Re: Cvs and .classpath .project files [message #85394 is a reply to message #84963] Mon, 30 June 2003 09:52 Go to previous messageGo to next message
Originally posted by: Michael_Valenta.oti.com
Paul,
Which ignored resource list did you add them to? If you added them to
the Team>Ignored Resources list in the preference pages then they should
be ignored. The only reason they would not be ignored is if they were
already under version control.
Michael
Paul wrote:
> Hi all,
> Any advice ?
Re: Cvs and .classpath .project files [message #85832 is a reply to message #84963] Mon, 30 June 2003 16:14 Go to previous messageGo to next message
Originally posted by: msolo.third-bit.com
On Mon, 30 Jun 2003 03:01:01 +0100, Paul wrote:
> Hi all,
> Any advice ?
If the .classpath and .project files have added to cvs then make a backup
copy of them and delete the original. Next, synchronize with the
repository and cvs will inform you that the .classpath and .project files
are missing. Right-click on them and select the option to remove them from
the repository. Commit your changes. Then restore your backup copies and
synchronize with the repository again. Now right-click on the two files
and select the ignore option. Now you will not be prompted to commit them.
Matthew
Re: Cvs and .classpath .project files [message #91597 is a reply to message #85832] Fri, 11 July 2003 03:03 Go to previous message
Why can't the JDT automatically detect .classpath files that have a
platform dependent suffix ?
John Arthorne wrote:
> The SWT plugin has the same problem. It gets around this by checking in
> all the .classpath files with the OS as the suffix: .classpath_win32,
> .classpath_motif, etc. This requires an extra step on checkout: rename
> the appropriate .classpath_xxx file to be .classpath. This way it's the
> same steps on all platforms.
> As Peter says, the approach taken by other platform plugins is to put OS
> -specific code in a plugin fragment (org.eclipse.core.resources.win32,
> for example, is the windows-specific fragment of the resources plugin).
> Graham Perks wrote:
>> The problem is, I develop on both Windows and Linux. I would like the
>> .classpath files to be in CVS. However each platform will have a
>> different
>> classpath. So I decide, well let's check in ONE version at least, say the
>> Windows one. Now on Linux I get nagged every time I sync and one day will
>> accidentally check in the Linux version. Then when I next sync on
>> Windows,
>> it will pull down the Linux version and my Windows installation is hosed.
>> What a pain!
>> "Richard L. Kulp" <richkulp@NOSPAM.us.ibm.com> wrote in message
>> news:bef8ss$e4k$1@eclipse.org...
>>> However, do you really want to delete them?
>>> It makes sharing the project very difficult. Those files contain all of
>>> the information necessary to check out a project as a Java Project AND
>>> have the correct build path already setup. Otherwise everytime the
>>> project is checked out, it would need to be explicitly checked out as a
>>> Java project and then by hand the build path needs to be setup.
>>> Thanks, Rich Kulp
Previous Topic:How to open an icompilationunit in Editor and select a line or object!
Next Topic:Error opening class files [NEWBIE]
Current Time: Tue Dec 02 19:18:39 EST 2025
Powered by FUDForum. Page generated in 0.04403 seconds
