Context-Sensitive Help [message #84898] |
Fri, 08 July 2005 20:11  |
Originally posted by: fred.lackey.spamjammer.com
Is there some way to get Eclipse 3.1 to provide context-sensitive help when
F1 is pressed (or any key, for that matter)? I am coming from the M$ world,
and within Visual Studio, if you want more info about a particular class,
you just select the class and hit F1. The appropriate page is then opened
for you to read. I would love to have this within Eclipse.
Thanx! =}
Re: Context-Sensitive Help [message #85577 is a reply to message #85358] |
Tue, 12 July 2005 08:34  |
Originally posted by: cj19841015.hotmail.com
Thanks to Eric, this help me a lot.
At the very begining I even don't know how to change the JavaDoc location
for Core Classes except the way I mentioned in my reply.
And I believe I also found how to add different API Javadoc at workbench
level.
Thanks again:-)
"Eric Rizzo" <eclipse3@rizzoweb.com> wrote in message
news:datv1r$4il$1@news.eclipse.org...
> Fred Lackey wrote:
>> "Juri Glass" <glass@cs.tu-berlin.de> wrote in message
>> news:danald$6is$1@news.eclipse.org...
>>>Shift + F2
>> I have tried this, but it appears to be for project-specific items only.
>> Is there any way to set this up for the JDK 5 base? I am really trying
>> to open the door to understanding Java better. My goal is to be able to
>> pull in complex methods and classes and then walk through them to better
>> understand what the author was attempting to accomplish. Being able to
>> open the Java reference is where this becomes helpful to me at this
>> point.
> As long as you are referencing a JDK and not just a JRE, Shift-F2 should
> work for core classes. What happens when you hit Shift+F2 on a core
> library class like String?
> To make sure your JRE has its JavaDoc association correct, open up the
> Preferences page for the installed JREs (Preferences | Java | Installed
> JREs) select the one you're working with, and click Edit...
> There you should expand the rt.jar entry and see that it has a valid
> JavaDoc location.
> HTH,
> Eric
FUDForum. Page generated in 0.10579 seconds
