Home » Eclipse Projects » Remote Application Platform (RAP) » IPartListener2
IPartListener2 [message #84895] Fri, 25 April 2008 08:37 Go to next message
I need add part listener to window.getPartService() or activePage, but i
need add this listener before all view (workbenchpart) created.
I have one perspective which opening on start two view.
code:
public class ApplicationWorkbenchAdvisor extends WorkbenchAdvisor{
public void preStartup() {
Sysout("PRE STARTUP");
PlatformUI.getWorkbench().addWindowListener(new WindowListener(){
public void windowOpened(IWorkbenchWindow window) {
Sysout("WINDOW OPENED");
window.getPartService().addPartListener(new
MyPartListener());
and in View in method :
public void createPartControl(Composite parent) {
sysout("VIEW CREATED");
and in MyPartListener:
public void partOpened(IWorkbenchPartReference partRef) {
Sysout("PART OPENED");
Result is:
PRE STARTUP
VIEW CREATED
WINDOW OPENED
and i need:
PRE STARTUP
WINDOW OPENED
PART OPENED
VIEW CREATED
or
PRE STARTUP
WINDOW OPENED
VIEW CREATED
PART OPENED
When i register IPartListener ??
P.S. sry for my English
Re: IPartListener2 [message #84929 is a reply to message #84895] Fri, 25 April 2008 09:27 Go to previous messageGo to next message
I found one place where i have complete instance Window with page and
there are'nt created any view yet.
public class ApplicationActionBarAdvisor extends ActionBarAdvisor {
protected void makeActions(final IWorkbenchWindow window) {
window.getPartService().addPartListener(new MyPartListener());
Probably, i do many mistakes in english language when i tryied describe
my problem. I make apology.
NkD
Michal NkD Nikodím napsal(a):
> code:
> MyPartListener());
> Result is:
> PRE STARTUP
> VIEW CREATED
> WINDOW OPENED
> and i need:
> PRE STARTUP
> WINDOW OPENED
> PART OPENED
> VIEW CREATED
> or
> PRE STARTUP
> WINDOW OPENED
> VIEW CREATED
> PART OPENED
Re: IPartListener2 [message #84987 is a reply to message #84929] Fri, 25 April 2008 12:59 Go to previous messageGo to next message
Originally posted by: fappel.innoopract.com
did you try to override DemoWorkbenchWindowAdvisor#postWindowCreate()?
Ciao
Frank
-----Ursprüngliche Nachricht-----
Von: Michal NkD Nikodím [mailto:michal.nikodim@asei.cz]
Bereitgestellt: Freitag, 25. April 2008 15:28
Bereitgestellt in: eclipse.technology.rap
Unterhaltung: IPartListener2
Betreff: Re: IPartListener2
NkD
i
> code:
WindowListener(){
> MyPartListener());
> Result is:
> PRE STARTUP
> VIEW CREATED
> WINDOW OPENED
> and i need:
> PRE STARTUP
> WINDOW OPENED
> PART OPENED
> VIEW CREATED
> or
> PRE STARTUP
> WINDOW OPENED
> VIEW CREATED
> PART OPENED
Re: IPartListener2 [message #85107 is a reply to message #84987] Mon, 28 April 2008 02:37 Go to previous messageGo to next message
Frank Appel napsal(a):
> Ciao
> Frank
Yes, i did. But it is not right place (maybe only bug).
This place isn't before all view created.
NkD
Re: IPartListener2 [message #85120 is a reply to message #85107] Mon, 28 April 2008 02:50 Go to previous message
if i use:
DemoWorkbenchWindowAdvisor#postWindowCreate(){
getWindowConfigurer().getWindow().getPartService().addPartLi stener(new
MyPartListener());
log:
1. View - Part CREATED view.listofpersons
2. View - Part CREATED view.persondashboard
3. View - Part CREATED view.relationdashboard
4. PartListener - partOpened view.relationdashboard
5. View - Part CREATED view.address
6. PartListener - partOpened view.address
missed two view (1,2)
if i use:
ApplicationActionBarAdvisor#akeActions(final IWorkbenchWindow window){
log:
2. PartListener - partOpened view.listofpersons
3. View - Part CREATED view.persondashboard
4. PartListener - partOpened view.persondashboard
5. View - Part CREATED view.relationdashboard
6. PartListener - partOpened view.relationdashboard
7. View - Part CREATED view.address
8. PartListener - partOpened view.address
it's right
About other important thing:
public class Perspective implements IPerspectiveFactory {
public void createInitialLayout(IPageLayout layout) {
String editorArea = layout.getEditorArea();
layout.setEditorAreaVisible(false);
IFolderLayout left = layout.createFolder("folder.left",
IPageLayout.LEFT, 0.25f, editorArea);
left.addView(ViewId.LIST_OF_PERSONS.ID);
left.addPlaceholder(ViewId.LIST_OF_VIEWS.ID);
IPlaceholderFolderLayout right =
layout.createPlaceholderFolder("folder.right", IPageLayout.RIGHT, 0.80f,
editorArea);
right.addPlaceholder(ViewId.LOG.ID);
IFolderLayout top = layout.createFolder("folder.top",
IPageLayout.TOP, 0.37f, editorArea);
top.addView(ViewId.PERSON_DASHBOARD.ID);
top.addView(ViewId.RELATION_DASHBOARD.ID);
IPlaceholderFolderLayout bottom =
layout.createPlaceholderFolder("folder.bottom", IPageLayout.BOTTOM,
0.63f, editorArea);
bottom.addPlaceholder(ViewId.ADDRESS.ID);
bottom.addPlaceholder(ViewId.BIRT.ID);
bottom.addPlaceholder(ViewId.REMUN_VIEW.ID);
and view.address is open from (only for developing):
WorkbenchWindowAdvisor#postWindowOpen() {
try {
PlatformUI.getWorkbench().getActiveWorkbenchWindow().getActi vePage().showView( "view.address");
} catch (PartInitException e) {
throw new RuntimeException(e);
Previous Topic:Refresh in Browser removes branding
Next Topic:Wizard
Current Time: Mon Oct 27 20:48:34 EDT 2025
Powered by FUDForum. Page generated in 0.03612 seconds
