Home » Archived » M2M (model-to-model transformation) » [ATL] parameterizing metamodel elements
[ATL] parameterizing metamodel elements [message #84806] Thu, 19 June 2008 11:02 Go to next message
I was wondering if something like this is possible in ATL and how.
rule class2class
from i : UML!Class
to o : UML!Class mapsTo i
name <- i.name
do
o.<metamodel parameter> <- 'somevalue';
where <metamodel parameter> could be for instance name, isAbstract, isLeaf
etc.
thanks in advance.
regards,
Aram.
Aram Hovsepyan
Distrinet research group
Katholieke Universiteit Leuven
Re: [ATL] parameterizing metamodel elements [message #84884 is a reply to message #84806] Mon, 23 June 2008 03:50 Go to previous message
There is no kind of parametrizable templates in ATL, but a possible
solution could be to generate ATL transformations, using the ATL metamodel.
create OUT:ATL from IN:metamodel
Here is an example of transformation creating ATL :
http://www.eclipse.org/m2m/atl/atlTransformations/#KM32ATLCo pier
Note that the mapsTo word is reserved by the syntax but isn't actually
used in ATL.
William
Aram Hovsepyan a écrit :
> rule class2class
> from i : UML!Class
> name <- i.name
> do
> etc.
> thanks in advance.
> regards,
> Aram.
Previous Topic:[ATL] Documentation on Refinement Mode: A Contradiction?
Next Topic:[QVTO] Problems with blackboxing
Current Time: Mon Nov 03 17:34:18 EST 2025
Powered by FUDForum. Page generated in 0.30139 seconds
