Home » Eclipse Projects » Eclipse 4 » import a class from another project
import a class from another project [message #684] Wed, 08 April 2009 15:36 Go to next message
I created a Java project A. And under A, I would like to import a class
from another project B which has a package
org.eclipse.example.Myprogram.ClassA. But when i write
import org.eclipse.example.Myprogram.ClassA, I get the following msg:
org.eclipse.example cannot be resolved.
How should I fix the problem? Thanks.
Will
Re: import a class from another project [message #687 is a reply to message #684] Thu, 09 April 2009 09:31 Go to previous message
> Will
You want the newcomer group.
Paul Webster
Re: import a class from another project [message #561109 is a reply to message #684] Thu, 09 April 2009 09:31 Go to previous message
> Will
Paul Webster
Previous Topic:import a class from another project
Next Topic:bespin
Current Time: Thu Nov 13 07:02:06 EST 2025
Powered by FUDForum. Page generated in 0.09541 seconds
