Home » Eclipse Projects » Equinox » [DS] Failure to activate a component does not reset already bound dependencies
[DS] Failure to activate a component does not reset already bound dependencies [message #84721] Wed, 21 March 2007 17:58
--nextPart2178513.6zcO6a7nyl
Content-Type: text/plain; charset=utf-8
Content-Transfer-Encoding: 8Bit
If a component managed by declarative services throws an exception during a
bind call or activate(), all the dependencies that have already been bound
remain bound.
This has the unfortunate result that any subsequent attempts to activate the
component will fail due to the previously bound dependencies not being
bound on the new instance created on the next activation attempt.
I have attached a patch to BuildDispose.java that I think resolves the
issue, however I'm not at all confident that this is an appropriate
solution to the problem.
In any case can someone let me know if this is a bug or expected behaviour.
Samant
Content-Type: text/x-diff; name="BuildDispose.java.patch"
Content-Disposition: attachment; filename="BuildDispose.java.patch"
Index: src/org/eclipse/equinox/ds/instance/BuildDispose.java
RCS file: /cvsroot/eclipse/org.eclipse.equinox.ds/src/org/eclipse/equi nox/ds/instance/BuildDispose.java,v
retrieving revision 1.2
diff -u -r1.2 BuildDispose.java
--- src/org/eclipse/equinox/ds/instance/BuildDispose.java 12 Jul 2006 19:01:44 -0000 1.2
+++ src/org/eclipse/equinox/ds/instance/BuildDispose.java 8 Mar 2007 22:41:49 -0000
@@ -125,6 +125,9 @@
} catch (ComponentException e) {
Log.log(1, "[SCR] Error attempting to build component ", e);
+ if(componentInstance != null) {
+ unbind(componentInstance);
throw e;
} finally {
@@ -178,11 +181,16 @@
// get all instances for this component
- Iterator it = componentConfiguration.getInstances().iterator();
+ final List instances = new ArrayList(componentConfiguration.getInstances());
+ Iterator it = instances.iterator();
while (it.hasNext()) {
- disposeComponentInstance((ComponentInstanceImpl) it.next());
+ final ComponentInstanceImpl instance = (ComponentInstanceImpl) it.next();
+ try {
+ disposeComponentInstance(instance);
+ } finally {
+ componentConfiguration.removeInstance(instance);
- componentConfiguration.removeAllInstances();
// clean up this component configuration object
it = componentConfiguration.getReferences().iterator();
@@ -561,7 +569,8 @@
* @param componentInstance
private void unbindReference(Reference reference, ComponentInstanceImpl componentInstance) {
- Iterator itr = reference.getServiceReferences().iterator();
+ final Set serviceReferences = new HashSet(reference.getServiceReferences());
+ Iterator itr = serviceReferences.iterator();
while (itr.hasNext()) {
ServiceReference serviceReference = (ServiceReference) itr.next();
unbindServiceFromReference(reference, componentInstance, serviceReference);
--nextPart2178513.6zcO6a7nyl--
Previous Topic:Issues deploying using the Servletbridge
Next Topic:error deploying first standalone osgi app
Current Time: Sun Jul 27 01:42:51 EDT 2025
Powered by FUDForum. Page generated in 0.05250 seconds
