Home » Modeling » GMF (Graphical Modeling Framework) » Cannot find some specific classes (problems removing components)
Cannot find some specific classes (problems removing components) [message #84596] Tue, 12 December 2006 07:13 Go to next message
Originally posted by: talita.frb.br
Hi!
I've read some emails describing this same problem.
When deleting an component from the diagram, also deletes the respective
view and semantic. If there's any links from/to this component, the
respective view is also deleted, but the semantic stays.
I´ve read something about editing the NotationViewDependentsAdvice and
XXXEditHelper classes but I'm not finding them in the project.
I hope there's someone who can help me.
Thanks, anyway!
Re: Cannot find some specific classes (problems removing components) [message #84887 is a reply to message #84596] Tue, 12 December 2006 13:50 Go to previous messageGo to next message
Originally posted by: vcciubot.uwaterloo.ca
Do it in the EditHelper corresponding to the semantic element you are
removing:
* Gets a command to destroy the connections incident to this block
protected ICommand getDestroyDependentsCommand(
DestroyDependentsRequest request) {
End end = (End) request.getElementToDestroy();
Set ret = new HashSet();
ret.addAll(end.getOutgoingConnections());
ret.addAll(end.getIncomingConnections());
return request.getDestroyDependentsCommand(ret);
Re: Cannot find some specific classes (problems removing components) [message #85194 is a reply to message #84887] Wed, 13 December 2006 09:11 Go to previous messageGo to next message
Originally posted by: julias.frb.br
Hi, Vlad!
I´ve tried this and i've included this method in one EditHelper but,
when debugging, this method is never called.
What can I do?
I tried to find the NotationViewDependentsAdvice, as I've read in some
emails, but it dont exists in the project.
thanks!
Julia
> removing:
Re: Cannot find some specific classes (problems removing components) [message #85266 is a reply to message #85194] Wed, 13 December 2006 12:08 Go to previous messageGo to next message
I remember having the same problem with the generated code.
In the generated XXXBaseEditHelper remove this code:
* @generated
protected ICommand getDestroyElementCommand(DestroyElementRequest req) {
return null;
The implementation in AbstractEditHelper is responsible for calling
getDestroyDependentsCommand().
vlad
Re: Cannot find some specific classes (problems removing components) [message #85586 is a reply to message #85266] Thu, 14 December 2006 12:59 Go to previous message
Thank you Vlad!! it worked =)
but it seems that this method overrides a method on the superclass.
deleting it make the thing works, ok, but what should i return, if i
wanted to put an "generated NOT" instead of deleting it?
thanks again!!
> * @generated
> return null;
> vlad
Previous Topic:arrangeAll by code
Next Topic:Canvas Link Mapping from Node
Current Time: Mon Jul 21 22:27:20 EDT 2025
Powered by FUDForum. Page generated in 0.26266 seconds
