Home » Language IDEs » ServerTools (WTP) » Unabel test Web Service with Web Service Explorer
Unabel test Web Service with Web Service Explorer [message #84215] Wed, 16 March 2005 09:56 Go to next message
Originally posted by: Pudel.Hundt.gmx.de
I have got a problem. When i am testing a WSDL with the Web Service
Explorer m described in "Using Web Service Explorer to test a Web
service" tutorial I always get the same error:
IWAB0135E An unexpected error has occurred. 400
I tryed it with several WSDL fiels and I alget the same result. What could
be the reason?
Thank you for help.
Lorenz
Re: Unabel test Web Service with Web Service Explorer [message #86982 is a reply to message #84215] Thu, 24 March 2005 13:44 Go to previous messageGo to next message
The Web Services Explorer is receiving an "HTTP 400: Bad Request" from the Web
site it is trying to contact. This is either an error with the server (for
instance, there are documented cases - and a fix - of this with IIS), or the
WSE is sending incorrect traffic. Can you append here a couple of WSDL URLs
that you are trying, and detail the steps you are following thru the WSE that
lead to the error?
Cheers - CB.
Lorenz Hundt wrote:
> be the reason?
> Thank you for help.
> Lorenz
Re: Unabel test Web Service with Web Service Explorer [message #896031 is a reply to message #84215] Mon, 16 July 2012 22:24 Go to previous message
Hi, Lorenz:
Have you resolved your problem about "IWAB0135E An unexpected error has occurred. 400"? I have met the same problem, hope you can help me if you have known. Thanks.
kevin
Previous Topic:New XML file wizard and schemaLocation
Next Topic:Default behaviour for opening html files drives me nuts. [solved]
Current Time: Fri Nov 21 03:54:56 EST 2025
Powered by FUDForum. Page generated in 0.35807 seconds
