Home » Eclipse Projects » SWTBot » *Wrong Thread* debug message
*Wrong Thread* debug message [message #7572] Mon, 08 December 2008 18:32 Go to next message
I am getting started with creating some tests using SWTBot. While
executing very simple test I noticed the following debug message.
08 Dec 2008 17:19:47.078 - Workbench Test Thread - DEBUG -
SWTBotButton - (SWTBotButton.java:45) - Clicking on Button
{*Wrong Thread*}
My test method is very simple
public void test()
bot.menu("Run").menu("Open Run Dialog...").click();
bot.button("Close").click();
A bit of background: In my test environment we have a test suite class
that extends the JUnit TestSuite class. We have overridden the run()
method so that we can output messages before testing starts and run the
tests in a separate thread (avoiding deadlocks while testing some parts
of the UI).
What is causing SWTBot to indicate that the SWT operation occurred on a
wrong thread? Is there something with this test environment that is
causing issues for SWTBot?
I did experiment with wrapping the SWTBot calls in syncExecs but seemed
to get unexpected behavior, a hang in one case in a shell's event
dispatcher. I need to experiment with this more but figured I should
first ask what is the correct approach in this situation.
Joe
Re: *Wrong Thread* debug message [message #7593 is a reply to message #7572] Mon, 08 December 2008 18:53 Go to previous messageGo to next message
This is really not failure issue, but it's a "bug" in the following log
statement in the click method of SWTBotButton:
log.debug(MessageFormat.format("Clicking on {0}", widget));
Notice that MessageFormat's format is going to call toString method of
widget, which is going to happen on non-ui thread. So it will print the
message you see. Maybe is should use SWTUtils.getText(widget) instead of
passing widget only.
Joe Luebker wrote:
> Hello,
> {*Wrong Thread*}
> public void test()
> of the UI).
> Joe
Re: *Wrong Thread* debug message [message #7725 is a reply to message #7593] Tue, 09 December 2008 11:58 Go to previous messageGo to next message
Thanks Ketan. Is there a defect reported against this? The logging
output in this case can misdirect someone trying to debug (using logging
output) how SWTBot is executing tests.
Joe
> of passing widget only.
> Joe Luebker wrote:
>> Hello,
>> {*Wrong Thread*}
>> public void test()
>> the tests in a separate thread (avoiding deadlocks while testing some
>> parts of the UI).
>> a wrong thread? Is there something with this test environment that is
>> seemed to get unexpected behavior, a hang in one case in a shell's
>> event dispatcher. I need to experiment with this more but figured I
>> should first ask what is the correct approach in this situation.
>> Thanks,
>> Joe
Re: *Wrong Thread* debug message [message #7767 is a reply to message #7725] Tue, 09 December 2008 12:10 Go to previous messageGo to next message
Joe,
There is no defect, please log a defect for any such anomalies you see.
I'm sure there are many.
Thanks.
-- Ketan
> Joe
>> log statement in the click method of SWTBotButton:
>> the message you see. Maybe is should use SWTUtils.getText(widget)
>> instead of passing widget only.
>> Joe Luebker wrote:
>>> Hello,
>>> SWTBotButton - (SWTBotButton.java:45) - Clicking on Button {*Wrong
>>> Thread*}
>>> public void test()
>>> class that extends the JUnit TestSuite class. We have overridden the
>>> run() method so that we can output messages before testing starts and
>>> run the tests in a separate thread (avoiding deadlocks while testing
>>> some parts of the UI).
>>> Thanks,
>>> Joe
Re: *Wrong Thread* debug message [message #7929 is a reply to message #7767] Wed, 10 December 2008 16:02 Go to previous message
Thanks Ketan. I just logged a bug for this,
http://swtbot.org/bugzilla/show_bug.cgi?id=147
Joe
Ketan Padegaonkar wrote:
> Joe,
> Thanks.
> -- Ketan
>> Joe
>>> Joe Luebker wrote:
>>>> Hello,
>>>> Thread*}
>>>> public void test()
>>>> Thanks,
>>>> Joe
Previous Topic:Invoking SWTBot methods on non-UI threads
Next Topic:Slow execution
Current Time: Tue Nov 11 07:37:54 EST 2025
Powered by FUDForum. Page generated in 0.05650 seconds
