Home » Eclipse Projects » Eclipse Platform » How to call or Not to createPartControl()
How to call or Not to createPartControl() [message #7567] Wed, 23 April 2003 11:01 Go to next message
Hi all,
I am trying to get the following line to work but I get a null value for
the viewer.
ISourceViewer viewer = this.getSourceViewer();
From the newsgroup someone sys that I am suppose use createPartControl()
and someone else says that I can't use it as it is called from the
framework.I read about it in the documentation where it says "Clients
should not call this method (the workbench calls this method when it needs
to, which may be never). "
Is there any other way I can get the above functionality.
I would realy apprecaite any help.
Syed
Re: How to call or Not to createPartControl() [message #8871 is a reply to message #7567] Wed, 23 April 2003 20:53 Go to previous messageGo to next message
Originally posted by: bob.objfac.com
There is nothing that is going to get you a sourceviewer reference before it
is created, so there's not much use in asking for 'the above functionality'.
Please see my reply in your previous thread on the same subject.
Bob
"Syed Rizvi" <sma_r@hotmail.com> wrote in message
news:b869sv$978$1@rogue.oti.com...
> Hi all,
> the viewer.
> Syed
Re: How to call or Not to createPartControl() [message #8997 is a reply to message #8871] Thu, 24 April 2003 01:24 Go to previous messageGo to next message
I am not clear about one thing and that is when I open up an editor is the
sourceViewer created or not.As I call the underlined method after the
creation of the editor,as I have stated in the previous thread on the same
subject.
Syed
> Bob
> > Hi all,
> > the viewer.
> > Syed
Re: How to call or Not to createPartControl() [message #9231 is a reply to message #8997] Thu, 24 April 2003 09:30 Go to previous messageGo to next message
Originally posted by: mccull1.does.not.like.spam.us.ibm.com
The ISourceViewer is _probably_ created when the editor is created, but that
is really up to the editor. If the editor is a subclass of
AbstractTextEditor, you can get it back out using a hack, but there is no
API for it. See this bug:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=22452
and note that the same hack works if the left hand side says ISourceViewer
instead of ITextViewer.
-Andrew
news:b87sdv$969$1@rogue.oti.com...
> subject.
> Syed
before it
functionality'.
> > Bob
> > > Hi all,
for
> > > the viewer.
createPartControl()
needs
> > > Syed
Re: How to call or Not to createPartControl() [message #10257 is a reply to message #9231] Thu, 24 April 2003 09:58 Go to previous messageGo to next message
That reply is puzzling the heck out of me. I'm looking at the code in
AbstractTextEditor createPartControl() which unconditionally calls
createSourceViewer() which unconditionally does a new SourceViewer, in both
AbstractTextEditor and in the TextEditor override.
So how is the SourceViewer instance available before this call?
Bob
"Andrew McCullough" <mccull1@does.not.like.spam.us.ibm.com> wrote in message
news:b88opu$j0$1@rogue.oti.com...
that
> -Andrew
the
same
> > subject.
> > Syed
> before it
> functionality'.
> > > Bob
> > > > Hi all,
> for
> > > > the viewer.
> createPartControl()
"Clients
> needs
> > > > Syed
Re: How to call or Not to createPartControl() [message #10389 is a reply to message #10257] Thu, 24 April 2003 10:04 Go to previous messageGo to next message
Sorry, I should have been more explicit:
The SourceViewer is obviously not available before the call to
createPartControl, but Syed said the editor was already created ("As I call
creation of the editor"), and that he was re-calling createPartControl(),
which is obviously inappropriate.
As long as we're talking about AbstractTextEditor & Subclasses, the
SourceViewer is created when the editor is created, and it can be retrieved
via the hack described in the bug report. Any other editor, of course,
might work differently.
-Andrew
"Bob Foster" <bob@objfac.com> wrote in message
news:b88pqf$1o4$1@rogue.oti.com...
both
> Bob
message
> that
no
ISourceViewer
> > -Andrew
> the
> same
> > > subject.
> > > Syed
> > before it
> > functionality'.
> > > > Bob
> > > > > Hi all,
value
> > for
> > > > > the viewer.
> > createPartControl()
> "Clients
it
> > needs
> > > > > Syed
Re: How to call or Not to createPartControl() [message #10585 is a reply to message #10389] Thu, 24 April 2003 10:31 Go to previous messageGo to next message
Got it. If it's one's own editor, of course, you don't need the hack. You
can always wrap the protected getSourceViewer() method.
You make an interesting point. From Syed's earlier posts, I assumed his
problem was that he was trying to get the SourceViewer too early in the
cycle. For example, it's an easy mistake to try to get it in the editor
constructor or initialization method (at least, I've made it ;). Maybe
there's some other kind of bug.
Hey, Syed, if my last reply in the other thread didn't help you, how about
posting some source code?
Bob
news:b88qpr$2mt$1@rogue.oti.com...
call
retrieved
> -Andrew
> both
> > Bob
> message
but
> > that
> no
> ISourceViewer
> > > -Andrew
is
> > the
the
the
> > same
> > > > subject.
> > > > Syed
> > > before it
> > > functionality'.
> > > > > Bob
> > > > > > Hi all,
> value
> > > for
> > > > > > the viewer.
> > > createPartControl()
the
> > "Clients
when
> it
> > > needs
> > > > > > Syed
Re: How to call or Not to createPartControl() [message #14296 is a reply to message #10585] Fri, 25 April 2003 01:14 Go to previous messageGo to next message
Thanks both of you for the info.What I am actually doing is using the
JavaEditor example of Eclipse.With that I can open up an editor for a
java file(So the editor is open).This editor extends TextEditor so
createPartControl must be called somewhere BUT it is not called in my
JavaEditor code.
I am using the ButtonPressed method in MessageDialog.Whenever a button is
pressed it checks its ID an and simply calls the setEditable method in the
main class(class with the JavaEditor Constructor).
So to my understanding when the editor has been created then I should be
able to get hold of the viewer.
I have tried both of your solutions,
Bob
With your hack the createPartControl is not called(even being in the
Construtor class for the JavaEditor).Secondly the setEditable method
didn't got me the "viewer".Can you let me know which code you want.
Andrew for you hack,I couldn't get rid of the error that I am getting on
"editor".Any idea how to clear this.
Again thanks both of you for the info.
Syed
> Bob
> call
> retrieved
> > -Andrew
> > both
> > > Bob
> > message
> but
> > > that
> > no
> > ISourceViewer
> > > > -Andrew
> is
> > > the
> the
> the
> > > same
> > > > > subject.
> > > > > Syed
> > > > before it
> > > > functionality'.
> > > > > > Bob
> > > > > > > Hi all,
> > value
> > > > for
> > > > > > > the viewer.
> > > > createPartControl()
> the
> > > "Clients
> when
> > it
> > > > needs
> > > > > > > Syed
Re: How to call or Not to createPartControl() [message #14311 is a reply to message #14296] Fri, 25 April 2003 01:44 Go to previous messageGo to next message
You put a breakpoint in createPartControl() and it is never called? That is
very strange. How is this editor being created?
To back all the way out of this confusion, put a breakpoint in the
createPartControl() method of the unmodified JavaEditor example, edit a .jav
file and see what happens. If you put breakpoints in the initialize method,
etc. you will be able to see the order in which these things should happen.
Bob
news:b8ag7d$a1c$1@rogue.oti.com...
> JavaEditor code.
> Bob
> Syed
You
about
> > Bob
message
> > call
> > retrieved
course,
> > > -Andrew
in
in
> > > both
> > > > Bob
> > > message
created,
> > but
> > > > that
there is
> > > no
> > > ISourceViewer
> > > > > -Andrew
editor
> > is
> > > > the
after
> > the
on
> > the
> > > > same
> > > > > > subject.
> > > > > > Syed
reference
> > > > > before it
> > > > > functionality'.
subject.
> > > > > > > Bob
> > > > > > > > Hi all,
null
> > > value
> > > > > for
> > > > > > > > the viewer.
> > > > > createPartControl()
from
> > the
> > > > "Clients
> > when
> > > it
> > > > > needs
> > > > > > > > Syed
Re: How to call or Not to createPartControl() [message #14340 is a reply to message #14311] Fri, 25 April 2003 01:58 Go to previous messageGo to next message
Bob
There is no createPartControl method in the unmodified javaeditor example.
it is simply calling with "super" the TextEditor as the javaeditor extends
TextEditor,and I think that is what is calling createPartControl.
Syed
> Bob
> > JavaEditor code.
> > Bob
> > Syed
> You
> about
> > > Bob
> message
> > > call
> > > retrieved
> course,
> > > > -Andrew
> in
> in
> > > > both
> > > > > Bob
> > > > message
> created,
> > > but
> > > > > that
> there is
> > > > no
> > > > ISourceViewer
> > > > > > -Andrew
> editor
> > > is
> > > > > the
> after
> > > the
> on
> > > the
> > > > > same
> > > > > > > subject.
> > > > > > > Syed
> reference
> > > > > > before it
> > > > > > functionality'.
> subject.
> > > > > > > > Bob
> > > > > > > > > Hi all,
> null
> > > > value
> > > > > > for
> > > > > > > > > the viewer.
> > > > > > createPartControl()
> from
> > > the
> > > > > "Clients
> > > when
> > > > it
> > > > > > needs
> > > > > > > > > Syed
Re(2): How to call or Not to createPartControl() [message #15449 is a reply to message #14340] Fri, 25 April 2003 11:05 Go to previous message
The JavaEditor is using createPartControl of TextEditor,so I think that is
what is being used by the editor.
Syed
Syed Rizvi wrote:
> Bob
> Syed
jav
> > Bob
> > > JavaEditor code.
the
> > > Bob
> > > Syed
> > You
> > about
> > > > Bob
> > message
I
> > > > call
> > > > retrieved
> > course,
> > > > > -Andrew
> > in
> > in
> > > > > both
> > > > > > Bob
in
> > > > > message
> > created,
> > > > but
> > > > > > that
> > there is
> > > > > no
> > > > > ISourceViewer
> > > > > > > -Andrew
> > editor
> > > > is
> > > > > > the
> > after
> > > > the
> > on
> > > > the
> > > > > > same
> > > > > > > > subject.
> > > > > > > > Syed
> > reference
> > > > > > > before it
> > > > > > > functionality'.
> > subject.
> > > > > > > > > Bob
> > > > > > > > > > Hi all,
> > null
> > > > > value
> > > > > > > for
> > > > > > > > > > the viewer.
> > > > > > > createPartControl()
> > from
> > > > the
says
> > > > > > "Clients
method
> > > > when
> > > > > it
> > > > > > > needs
> > > > > > > > > > Syed
Previous Topic:Feature project: Export
Next Topic:How to make a library of JARS
Current Time: Sun Jul 13 08:06:38 EDT 2025
Powered by FUDForum. Page generated in 0.06557 seconds
