Home » Eclipse Projects » Remote Application Platform (RAP) » left and right margin of coolbar
| left and right margin of coolbar [message #83817] |
Mon, 21 April 2008 10:22  |
when using a coolbar, there's always a margin of some pixels (red in
this example).
GridLayoutFactory.fillDefaults().applyTo(parent);
coolBar = new CoolBar( parent, SWT.NONE );
coolBar.setBackground(Graphics.getColor(255, 0, 0));
coolBar.setLayoutData(new GridData(GridData.FILL_HORIZONTAL));
coolBar.setLocked(true);
final CoolItem coolItem1 = new CoolItem( coolBar, SWT.NONE );
final Button button = new Button(coolBar, SWT.NONE);
button.setText("Hallo");
coolItem1.setControl( button );
coolItem1.setSize(button.computeSize(SWT.DEFAULT, SWT.DEFAULT));
The margin is used to display the pickup icon (on the left), if the
setLocked property is set to false.
Has anyone an idea how I can get rid of these nasty pixels?
Stefan.
| Re: left and right margin of coolbar [message #83831 is a reply to message #83817] |
Mon, 21 April 2008 11:42   |
Originally posted by: rsternberg.innoopract.com
Hi Stefan,
I guess this is the same issue as reported in bug 211077, isn't it?
I tried your snippet with GTK, and there is also a red area on the left
side in locked mode. If this is the SWT behavior, we probably cannot do
so much about it, unless we'd make this margin themeable...
Ralf
Stefan Röck wrote:
> this example).
> Stefan.
| Re: left and right margin of coolbar [message #83885 is a reply to message #83831] |
Tue, 22 April 2008 04:07  |
Hi Ralf,
you are right, it is the bug
https://bugs.eclipse.org/bugs/show_bug.cgi?id=211077
I attachted a screenshot to the bug for illustration. Could you make
this margin themable? It would help us very much because the currently
implemented workaround causes a high load on the server for layout
calculations :-(
Stefan.
Ralf Sternberg schrieb:
> Hi Stefan,
> Best regards,
> Ralf
> Stefan Röck wrote:
>> this example).
>> Regards,
>> Stefan.
Current Time: Thu Nov 13 16:47:03 EST 2025
Powered by FUDForum. Page generated in 0.03356 seconds
