Home » Language IDEs » Java Development Tools (JDT) » additional codetemplates in eclipse?
additional codetemplates in eclipse? [message #7516] Mon, 28 April 2003 14:20 Go to next message
Originally posted by: dexters.gmx.de
i would like to know, if it is "easily" possible to create new
codetemplates for and integrate them into eclipse?
here is what i want to do:
i want to write my own codetemplate, so that i can select
e.g "new->java->entityBean" and eclipse asks me for a filename,
reads my codetemplate, "copies" the content to that file
and opens it up in a new editor.
do i have to write my own plugin for this? if so, appr. how many
classes do i have write (just to get a picture if the result is
worth the effort ;) ?
best regards,
dex
Re: additional codetemplates in eclipse? [message #7528 is a reply to message #7516] Mon, 28 April 2003 16:10 Go to previous messageGo to next message
Hm, should be (It's some time since I did something like this)
* Implement something from wizard and wizardpage (two classes, max
20 methods, I uess)
* write the xml to contribute it into the right place (Wizard :).
* Deplay as plugin (using the wizards for this)
But as you are doing it, you maybe want to write a more
generic one, so that others may contribute to this wizard
Something like this:
New -> Templates -> Ask 'which one' -> 'Contribution' askes
some questions -> sets up the file...
This would be really cool :) If you would then also get the
(unfortunatelly still internal) typecomment to fill in at the right
place... But maybe we should wait for the upcoming template API :)
Jan, dreaming...
Re: additional codetemplates in eclipse? [message #8058 is a reply to message #7528] Mon, 28 April 2003 19:06 Go to previous messageGo to next message
> place...
It's not internal anymore since 2.1! Have a look at the class CodeTemplates.
Regarding Dex's question, you can't add an new code template at the
moment. But Jan is right, having a wizard will give you even more
possibilities (to react on the configured settings and e.g. create
methods).
Martin
Re: additional codetemplates in eclipse? [message #8088 is a reply to message #8058] Mon, 28 April 2003 19:12 Go to previous message
Oops, not CodeTemplates, 'org.eclipse.jdt.ui.CodeGeneration'
>> place...
> CodeTemplates.
> methods).
> Martin
Previous Topic:Unit Testing Plugin Code
Next Topic:Eclipse 2.2 vs. Eclipse 3.0
Current Time: Thu Nov 06 09:26:33 EST 2025
Powered by FUDForum. Page generated in 0.03769 seconds
