Home » Archived » M2M (model-to-model transformation) » [QVT] qvt lanuch config: transformation IN parameter: invalid source
[QVT] qvt lanuch config: transformation IN parameter: invalid source [message #83592] |
Tue, 03 June 2008 10:55  |
Originally posted by: David-392.Li.MorganStanley.com
Again :-), I have some questions Re. QVT.
We use Eclipse Version: 3.3.0 Build id: I20080207-1530 to do the test for
QVT.
1. We create a QVT project.
2. Put the source meta model modx.ecore, and model test.modx inside the
porject.
3. Put the target metat model intermediate.ecore inside the project.
4. Create the modex2inter.qvto
5. Create the coresponding launch config. When configing the
transformation IN paramter through selecting the test.modx, but the panel
hang for a quit while, and then complains that "Invalid source URI
'platform:/resource/qvtPrototype/models/test.modx' for parameter 'modx'"
And the Model URI is "platform:/resource/qvtPrototype/models/test.modx"
Thanks for any suggestions!
David
Re: [QVT] qvt lanuch config: transformation IN parameter: invalid source [message #83620 is a reply to message #83592] |
Tue, 03 June 2008 14:29   |
Hi David,
Do you intend to you use dynamic model instance or generated java model
instance in
your transformation?
In case an ecore file from a workspace is to be used to compile and run a
transf,
it should be explicitly registered. See 'QVT Settings/Metamodel Mapping'
property page
on your QVT project.
Looks like your transf might compile against the ecore file metamodel
while your model
instance refers to the generated one. Though they may seem logically the
same metamodels,
they are considered distinct metamodels in this case.
/Radek
On Tue, 03 Jun 2008 16:55:06 +0200, David <David-392.Li@MorganStanley.com>
wrote:
> for QVT.
> porject.
> panel hang for a quit while, and then complains that "Invalid source URI
> David
Using Opera's revolutionary e-mail client: http://www.opera.com/mail/
Re: [QVT] qvt lanuch config: transformation IN parameter: invalid source [message #83633 is a reply to message #83620] |
Tue, 03 June 2008 16:57   |
Radek Dvorak wrote:
> Hi David,
> instance in
> transf,
> property page
> while your model
> same metamodels,
> /Radek
> wrote:
>> for QVT.
>> porject.
>> David
Hi Radek,
I solved this problem by doing following:
Generate the ecore mete model code, and export the model project as
plugin jar, and put the jar under Eclipse plugin folder. Then we can
define the IN parameter without problem.
So I guess that QVT needs Ecore meta model code in order to run?
can it automatically generate code from meta model if this is the case?
Since the project contains the corresponding metat models.
We tried to define the mapping between namespace and the meta model
through 'QVT Settings/Metamodel Mappi. But seems didn't work for us.
I am not sure what it means "Do you intend to you use dynamic model
instance or generated java model instance in your transformation"? Can I
understand that it is what we did as describe above through generating
meta model code?
Thanks very much,
David
Re: [QVT] qvt lanuch config: transformation IN parameter: invalid source [message #83648 is a reply to message #83633] |
Tue, 03 June 2008 17:42   |
------------YxEog0xuUM0vLfLdwgdXjC
Content-Type: text/plain; format=flowed; delsp=yes; charset=utf-8
Hi David,
Look at the usage of workspace located ecore file as metamodel in the
attached example project.
You just define the mapping of metamodel uri used in your modeltype
definition to
a location uri of your ecore file.
Yes, the step of generating the metamodel code is one alternative but
sometimes it is
desireable to develop a transformation and involved metamodels
simultaneously.
In this case, you may modify both the metamodel ecore file and your transf.
Both cases are supported by QVTO.
Creating a dynamic instance does not require its metamodel code generated.
You can create one by opening the ecore file in 'Sample Ecore Editor',
select a class
and run 'Create Dynamic Instance...' action.
The resulting model you can use as input to a transf or the transf can
create dynamic instances
as output.
QVTO does not support automation of the metamodel code generation step.
/Radek
On Tue, 03 Jun 2008 22:57:40 +0200, David <David-392.Li@MorganStanley.com>
wrote:
> Radek Dvorak wrote:
>> Hi David,
>> model instance in
>> a transf,
>> Mapping' property page
>> while your model
>> the same metamodels,
>> Regards,
>> /Radek
>> <David-392.Li@MorganStanley.com> wrote:
>>> Hi,
>>> for QVT.
>>> the porject.
>>> URI 'platform:/resource/qvtPrototype/models/test.modx' for parameter
>>> 'modx'"
>>> David
> Hi Radek,
> meta model code?
> Thanks very much,
> David
Content-Disposition: attachment; filename="eclipsecon2008.m2m.qvto.zip "
Content-Type: application/zip; name="eclipsecon2008.m2m.qvto.zip "
Content-Transfer-Encoding: Base64
UEsDBBQAAAAIAEeLaziUpPmJ/gAAAAECAAAgAAAAZWNsaXBzZWNvbjIwMDgu bTJt
LnF2dG8vLnByb2plY3R1UctOwzAQPAeJf6hyxw499bBNJUAckRDljIyzRAY/ wtqJ
6N9jOw5VKnHzzO7MeGw4/Bi9mZC8cnZf37Km3qCVrlO239evx8ebXX1or69g IPeJ
Mjygl6SGELcjW4EVBluUWg0epbPbptkxszXsewoOeJ6mNemMQRta4MspscXT Z8BX
6H1UunsZUCZU4H2UCttlpiQ76llJX2KZM5o9T+EuSZDOl4gaQf2Y0v2MK+iU TFUE
nQpTwReeWk/yLbYJQtnkkKhlPAk9YsuBz4fiwy+NgK+zgF9WKMzSMfYJI2HZ nsG/
9cpTsSMJ6z8cGZHCn7IoFc7inHF2/Xvg9Rf+AlBLAwQKAAAAAACzcJc4AAAA AAAA
AAAAAAAAIgAAAGVjbGlwc2Vjb24yMDA4Lm0ybS5xdnRvLy5zZXR0aW5ncy9Q SwME
FAAAAAgAbYtrOHjiF1fiAAAAaAEAAEcAAABlY2xpcHNlY29uMjAwOC5tMm0u cXZ0
by8uc2V0dGluZ3Mvb3JnLmVjbGlwc2UubTJtLnF2dC5vbWwubW1vZGVsLnVy aW1h
cHWQvWrDMBDH90LfQegBdK6nIOyGksmDl4ZAV6FcHIGkUyUlzuP3YrfeOggO /T/u
x3X7R/Dijrk4ir18U40UGC2dXZx6+XE8DIPcv7++dLfsRpM0v8TSgWI1LmIW j+D0
Fm+fcS6MRfN/L6+1Jg0wz7OiMCnKE3yNw59lrdxciw2td6ngYg1tgO97BQoe xpHO
6E9LApiSFzGVEF1YgUShW7Z4+hy2vmKvGMy2uCS0EOgCDAnIg2JEKarJE9Yl l7yp
F8pBQ8a1Dn5xLMW2aXaKiRQTEfcwzdrCYkYJzxvBP0di7QdQSwMEFAAAAAgA iHCX
OEdWUU6IBAAAnA4AACcAAABlY2xpcHNlY29uMjAwOC5tMm0ucXZ0by9FY29y ZTJF
TU9GLnF2dG+tVktv4zYQPku/gthL7DZRtjnaTYA8HCBodx1ks6eiWNDS2GZK kSpJ
xQmy/u+doSSathOvg64v8gw5M9+8mZa6AOmeK2Cjy/HdiNUWLPswd64aHB8v FosM
cikqC5k2s2Mop8cnHz+eHI9ybeDDMI2kP42v14VtPoeSZ7qceVlbQX5calSQ fURF
epo9lQJVpM5wZafalNwJrZhXfULqekIxIIoNGnCHTNeOkSxx8EYfxUsuVK/P XtLk
kRsGtzz/h88QxuC0Ec6M1m48eYDc2V7/L69oMBi19/4epkmQOTorecWcbule f5ik
S7JQVULNWCczGERXWiSDQcthaSLUHIxwlo0+8xKKkYQSlCOpmGYpQq6NIKAW 5DRT
9uvdDcLRCwXFPcW0O4FLya0VUwEmYKQLvf7RGbdjU4CB4gs4BJwmCqyDokMT VHyp
J9Vbbm5rib32xgm9/xN57Om9/SV3hT2fWMx37gKwb7zjaNNwhHJgpjwHdMbW FZjG
zq8rT5BH7ttMcgfMgNXyEW5UbwPqYYyTQtPG9tw5IyY1iq50OlPnrjZcXgPH bxQk
o9Gce/ax9eJjpJtSDeKBFcQCp41m8HI9rD6nBLhJZwgtkWlSCPtQq5wiu+XZ SNUl
0fRF8oo7TkLE6v6zlziNsUBkicjOnz0L96UNxJ8CE8XlKgwtA4PwlGspseN6 INn3
NEm0779tk52KF6bQgu9ZmdHfIVu+GbimgXdBRP/SpPNwq+k6U03XkbGdhiiU saGY
XjMUH7xrCri1Zic1Wdzkb8DbxPWplk5UUuSCqhUTHDOi3Imu14NJ3dBY4N+E /arE
v/UKTu1JPJJ6ASawPXWha0VSdVU1R2Laa4SI4U/ZKfulz9wcFDv6DZNrgW3c yHQu
z6339AY7fwamz0AVYro+hUJDkatRd6GfgYqDvitrDMuPVsTOEIYyv+UGE+Yi 5yGw
olnacl6dyYYLi4aecqh8owVFgfXDub6+h1pjzSYKljEWK7A/ORhLGp8rCFsD 00MJ
s5KQtMTeONJkLyTNHrlCjY9RCRcNPaSzO+DFWMlnOlTaNRfyOVcz4BNJtYz1 RenF
mp71Du6794d37A6mGHWVw8HhakBQl+NvQWXcdEwub+wfQhXjaW8lQqlermUq HL0Z
nmjo7oxp07mXuqy0xaEZHM+1cvgColANacFVG+e4mxrO2rLUyu/LV+EdBmwb ZRf2
5k9y5qaIZ4a4aucECkIzKVQtZTsL1h9ir227aKeFBbj3FCY8Svivf0bSRP4c r4kZ
uFsjSuGwyu7bQ9/aCeIPt38/85hbR0hZggHH6iU91N9VrCPI0TszSZbd2MMa Cjvq
be2B7UPVmPHF+sr0XDcrIuEBw0ThlSaL0S0WLcruttc5B0nTPsrB67EJqrun +ZZN
35/oEL3zFsLlcx+xnKM7bUko6zhWp3/zeNFTdvDAHznWsppljZaD/lq2Dlru cA9V
E60lcLWp4aJl76NihebiB8qwFvbQh4/fTQ3tVnwnnE7qfyibSs230OBwleTM u8Bc
79KEqpa0IwGnxKoysdb+A1BLAwQKAAAAAACzcJc4AAAAAAAAAAAAAAAAHgAA AGVj
bGlwc2Vjb24yMDA4Lm0ybS5xdnRvL21vZGVsL1BLAwQUAAAACAA1nHM46iE+ J+8D
AADIGgAAKAAAAGVjbGlwc2Vjb24yMDA4Lm0ybS5xdnRvL21vZGVsL2Vtb2Yu ZWNv
cmXdWN9v2jAQfp+0/yHKnovb7mVCZdPWtRLSVqoWpL26yUG9JXYWmwL//c6O YxIC
JRDTh/WBQnL33a/P57OvvizTJHiBXDLBB+FF7zwMgEciZnw2CCfj27NP4ZfP 799d
QSRy6N/c0+gPnUGwTFnfaV2i1vt3Af4hGJd9fDkIn5XK+oQsFoueSGc9kc/I r5/D
sBSRdZHFRyNxeX5+gWI/HqNnSOkZ41JRHkEN3XhSU4YoYZkEgwDpVKNckhst Fgac
pigMqZhaEC4nD0OnLo0h56HMICIoSzAkopV6GAuCyPscpmxpgT5rpCu4TqiU bMow
DQHG01erTJsqEmVelubtD3icZ5CPUUwOwg+E6G8FmIZ7VPk8UvOcJrdA8T9s QX2A
KeSgM2KRxYJD/FWpnD3NFT6dZ2jhm5jzeBCeXdiQ9R+MDQ5avc8FyqhVGESC K8p4
ClwNQrSO+jDKMiGZqouSyARAPPg6QkCqkDatfK1I73XWyfrxVupa2cK18PT6 CJuV
uhU2mfz6JFVOIxVWoL8JkQDlFvyKVIl3MBW/U0UN77azkRwMeJOArkkYUOu6 q84G
/ujpN2Bg3aqi6KxRjkqqxvi6Up0aP/AdAeusDyZfi7QIvA07Stkmi71UVcfd SHhZ
mW6xlilrE6bjQj3z9jHRxeu4Ql5oYrjlTCIKblVdYfXnTtSOtbnh89R1sc0a ueXo
gZA/MN+o1q5Sa6ec2t4O21QiUAnOS7bu8DNu3VOOovjbVn+pihWxvRse3m+P V8x2
svDnPFEsS1jE1MqmNLA7QuynixRbcpCIhWNmrXEXnq6ZilXnku1kohEnGwOF j6Z+
T3P8gdxuN0qtpffPUqUsEb48zimTWKBlBFnrico0Gy/M3kKaxoLtOg6N8hhD jndP
Qx2wJ5z9re8lnqANyau4Q65gho864prqVnEnPGEp8iu+owbLT13tEa/ZJWqt 2cNa
M1Rszdn9K0yLkcx633FpcZBKdwObila94BjDzSLn7FRbUZHGfVuqxyqXtdho +69l
b1/jt3JkTSBPnHeN/O33xvV+sPXk23pTXB+AN7Yy32OsmxhPyB2oTc0uLdVh unVi
KkqkNin74Y67T/mfxqp1Y+o6VlkDVbdcyjpv4g9A4xFPVieZEL5Dzl5ONH1c i7SZ
F2/ow1M4HcOUIqNPuT21P/l5bDX6bTUo/cVXa9DzGXJovNp24+YO/4cf5iYP w10n
S/u8Feb6NrCALZkSlDfvRvvOvPtNX2gvoXzW27iQPMyEpczrFuq8OsxAYyp+ 3VR9
OD/QVql8QhPY4faFcJsIesyNgLuVPM3NIeVcKKoqi7rFGF1b1zsWIT4oTNpp EB/9
A1BLAwQUAAAACABPqXQ4AogOv4oEAAAMLQAAJwAAAGVjbGlwc2Vjb24yMDA4 Lm0y
bS5xdnRvL21vZGVsL2Vtb2YuZW1vZtVaS2/bOBC+F+h/EHSPFcpJ6hh2u33s AgHS
TdAmQG8FIzMuuxKlJak4+fdLSibt2KQSWePH+mBIFDWcb94cavThMUuDB8IF zdk4
RL3jMCAsySeUTcfh7c1fR4Pww/u3b0Yky++H1zj5B09J8JjRoX0nVu+8fROo nyLF
xFA9HIe/pCyGUTSbzXp5Nu3lfBr9+HoRmini+ZRZv5oRHx8jNe3ye/KLZPiI MiEx
S8gz6poP+66oJtoVREGSSD2PFEuRnthTvKg1BR3WMy/zBMuK6RYEguqCJDkn YYWc
TsbhT4OZ4YyMQz0lDEpO27H2XtMY5TNGJjdPRS1XqS5qgsPPKRZiec3eH3au VlS9
9nyWKAvCq+vVmQjNeQ0CKj7eCclxIsfhPU4FqVkwTHyUktO7UhLfmvMbO09z QcUV
nxBO1GzJS6IHbhn9tyTze7N2EKT5jPBxqN4pi0JfHSED4jnZMKilsILjJAzy osgF
lY5nDtYWK1PxjeDJFUufDG419IVw+qDZtiOf88yQr1iPOkoHQUrnSg1W1uuW zsAv
nMEhyiYGks3C7t1yqSx0FeEy+kao9VhXrP1OWC3Uhfd6HGTQEmuNaxRZEl0C kmXz
C5ZYj2wck6IubMSGjT9TkhEmm7h452Si0kcrjcdbi4sST9267vvdvQ/s7pv4 wLpE
QGOh4q7WrUs0cdzJ5ZeiG5Bn9A3vN1qbfnOMofK0ywJgpE+MUzkF77dJl4fs 2ibX
pdLNJq1QHnBa+mqW841C8uaQuqVVC0n/gyICcqUTG91Zmdl6qCHPQLmUq74E DGiX
yqo5Tj0ibwj2CDraw4e/U4P0b/U/eUVadsfB9mn5FFhnB+8dZ9Y7HuVGpQ9A /fXO
8HB195voShWY/sDSL17h/+fBin5OoQKCa1PV3rjQunEljXsZXxw4XmMHdQoD m2Sj
dZGAFn3XmKsbFSc9rtdQfiDo+mODLfC6dKC2wBxToQLrY0IKf38AoU5V8Rai 1bnh
/2uZSlqkNKHyyaQHmAxwvq0MYGmA7sQ3hwVUyZpXDgQVUDFbPfFsWdq2h7pC AmoF
VfegkKC6QLYvPT8saMrOYMkYrac/0PJcL+IPq96sg/afdRySgUrKjAips/Jc zU7p
7L776gAMFEZKTg+x6EeWwdpK27pb+6zqtOv2InbUvsVLxuR1NVcA6OJq21BU vAiN
tpLdx9bFWQ2DuEhewJ1Rwe1foPRn+7hLzSfTuDG8NnlfZ71B93UXbd3lbppL cw1H
r9Anr9vQnG0bXnNtovJpT44H00XcYtNg9115h0yANjMGtf9rgl2XJutQgUqT BZC9
7NwcwMCOvOeMHQquEyhc1pYOBdkpFLKLg1HWGQykCbnHZer76GK/xb89XNG3 rzlc
AdsEbO10RWP/v/QwkT1yueY0o1ItrsdfUQ4iVznY6WQE2aOX228XL58AnTVU NS/x
8Rysjx97VPMpz1OCGRBZ2zf+rgyPTWGoxrZvdcEkmaqtGQxZa9XKatNu+o3t /tF+
/rKDb0ni7X3chBnLJZZLYasWxWrA2o7Pj6Llb5rVwH9QSwMEFAAAAAgAT6l0 OH+r
q2KDDQAAdooCADEAAABlY2xpcHNlY29uMjAwOC5tMm0ucXZ0by9tb2RlbC9l bW9m
LmVtb2YucXZ0b3RyYWNl7Z1Rc9vGFYXfO9P/wGGeK4iyndoaqWlqyzOeqSOP KmXy
loHJlYIGBBgQlJR/3wUvAAIiQ6UiyD3Ye15s81oCdhfnu9xzsVicffc4jQf3 JptH
aXI+HB0dDwcmGaeTKLk7H95cf/zb2+F3//jrX87yLByb0+viz8HjNDqtf+Wk +BV7
kGR+auPnw1/yfHYaBA8PD0fp9O4oze6Cnz5/qn5keZj6h5Y/ZcZxNJub5U9O T6bB
b/d5kM5MFub2+GEcLH/F/lSamaFtyWAgbbkqIpP5MmJj03A2s22+rH5xkIRT e6I8
/RKOfw3vzHAwk3+cD4eDaTpZxPZfF8VBTy4+X34clsexR8oWSR5NzeenB/wl M7fn
w3QcFw23f5nkXlr1TTAKLsrT/Pw+DufzYHXaoGpg8LSF1X+M0yQ3j/mqAWWg 7MHc
xLfDQf77rGhvddT6h+2P34fxwjQCxWCkExNfxGZqkrxs9ywO89s0m54GmZmn i2xs
gnLg7elOjo/fHtmxP7JjnwbL3w7MNL2t+lf3QnrSPuNZ0O7B2udZmNme5FYw 9WDY
NiziRpfl8+DXKJmcDy9vrodl5yVedf/gvbd/fPPz8TO9b/Wl9fEsWFPq/6fd H+zf
k7In+xZw81y1ilsN6FbKrUPr1LObIXAt6qW29q3m5UlqGcspu9WvHPPAwg3a PZHe
uJLvgUdAdHv0z/QhMZNr24IjZmbvMjOUwF3mZxCdf8mKqXj++741fmVuTWaN R2MC
XZ25W3HXJ3Kj7GB5Vb/P8yz6usgNiNDrsXYp8vJDPTYaZP+fPFuM80UWxh9N aP/e
u/zXTkgMiMEfYlC06FCznOa5agpaDeiWhNahCUENgZtxAQeB030JaQIBZvaP BAKL
NzuIfW1OJx1SW78ZvWZG9y6jg4kcJYu71DqLOJ2rOxgD1SkRfOvoNes3Kuo3 JKAX
BLB0IyEd+kcp2mAxwDm+hHQwgDPTR2Lgsz1SNIujcbT/2dDG74FWA/g9sPFz Zww0
B5so0AaXof2JP53N0nnEO7jbRT+iE/bZCRMCcAhohiWkBgFgP+wQA/phCanB ANgS
O8SAllhCajDAd8UKDELd2X0bg9U6Mmf6j+ZXJpxcJjHKKghQS3BCX+yzLyYG 8BjQ
GUtIEQTA3tghCPTGElIEArA7dgbCLIumUR7dm6Jlz3FQj395herPq0u0avMq VjFn
z1Bcgupy2ImLbdD6hRjUbfqx+Hg+/FeaxiZMGkN0FqydcVPopZOG5pC41Mlb d+nx
Q5iHf0YSjcF9UWqszlOnxfrE3abE+rAHu55lOlwX76YreagUePhhwJI1v/Ul 5LnM
Yb7pHUqdVW8JKZrg4te9FRQAddW9P5jMzpQnrPdtU/0rlr39LnuTAmwKWvMF Vr0V
MOBmVNA5oP2VkB4OYJwwFAf0xhLSwwG+NVZgEnRZ4/fplI+JPK97Bfvk6DbH 5ACd
A9pjCWmiANggc5dArw0yGgnAFtkhCbTIEtJEAr5JVmAWdJnkT7xptlXwb+iO /XbH
BAAWANpiCamQP7AfdogA/bCEVCAAbIQdIkAjLCEVCOA7YAWGQJMDnpjbsNAf PcAW
zX9LE+yzCSYD2AzQB0tICwHAVtghBbTCEtJCAbAbdkZBH3YLKX9wNUJKNgt5 5y41
crOQjlLhmnY3XchDJUCIvUIcqppf+BLyW+UwX/MOlc4St4S0TG3xq9wOfR5h kFDn
MEj/2heaQGwC4niNB75FTTrWBQRXzt6i1iCg7gGr3ltkz/eo+Xjjhxj0B4PW jIH3
flRA4GZcwEFgNUhCmkBAqQ1BgbC8XvsmYHmSWvpyym41L8c8tNjRFH7gUViX NvcC
9y+jM43DaZ1FnO7VHYxbX0vSN83G9a3GsqXC+g0J6AUBLN1ISIn+Uao2UAxw ji8h
JQzAzPSRGOCCBgkpYQBsLYNKU6DKBi8v75dKvnQDW6TP9Qx++2Gi0AcUaIwl pA0E
XIfMdQ0+O2RIGHCtMtc27Kp7N2sb0BTufG3DyOHbbpnWJeS9ylHyuEuxs6zT vbyD
tOoAbWxD5FzioGNvMmLQGwxYzpGQIghQKjlYIHDOLyFFIODM/rniQcN+JrAg oG1p
Qh408FC3HLPGD78USMF6CAU1oxUFWRjNLY2PYzOjZX5G+wrqparXApGFXrDA 6pGE
1JGAUkOCooElJAmpowGlkARFA5cD7aD44nKCiNv9SiAu8PQvpQMJHCV7u9Q5 Czqd
KjsoR5G+taFurv5RUcSh/nugfxZuJKRB/Si1GiwCOLOXkAYCcGb4SASwQLPT Yh4k
gbuv0TCT+5fJsTQOk8S5BY90rN9lmlLcQX1h6VUbEmetRsmTWoSgHxCwYCMh NQjA
VG2gMOBcX0JqMMCZ9fOZFBXPaGFigPaElkqDoMgVJ2aeF49k8S7us8LntrQ+ O2OC
0AcQ6I4lpAoDYIfMFcv+OmREFIBdskMU6JIlpAoFfKeswDDUnd23UahP5IyB RRbR
FmyTO7dq8NkfU/648qcrlpAC8QN7YW7I4K8XxgEA2AE7BIAOWEIKAMD3veTA Pw6K
k4M97IUGAtQzXwRBQp2DULccdIsq+N1s+e3gHxTSv+WFrjtBHjbxoPIuwZX/ 6+mk
Y/OFbX372WfpnOZaKe8U6LhTQAT6gUBrpsC7Bd4D4GZMwCHgHQMJaYEA5bYB q6V6
/DAcBPBeWIExULBiTjoWzb//Oi8uQQ6ifkwj8Ipe2FsvTATQEaAXlpAWAHC9 sEMI
6IUlpAUCXC/sEAJ6YQlpgQDeCztkQWoW3DD6RXr/EOZhcUlBdH7gQVhXNh+R 929i
A6ZxlAmNQ6kzZe8g56eESn/UZmzelvUvY2NJHCVhK7jfdOX/2svyWEEe3rHO vtI2
0uMovNVUhaj+OqRG/a36G+8y+ax9N8MBrn/O6iWkQP8wM3sk/bM4s4PGr2G0 7bww
wzUC/qVwHHmjpG4FKyIVFGWsrgPzBFfpl2Zb+opFGRVFGaofXv0sykhIgfZR ijJQ
+ueMXkIK9A8zs0fSPxf8SkiB/sHW+qo0AQqeey2EvzwPp/xbtM7XKPpqeKl9 YO3T
7krIe+Xjml0+CeKn2UVSP67V5fsR/bS6SOqHN7p8JaJ0rP9Gt2gQ5/pbpM5N jn31
uZQ+rvRpcyXku/BxXS6fnvXT5QKJH9fkcjNjP00ukPjhPS4Z8I+B8lhAD1qB YaDy
afMrPXsrLC/u+3TamtlJBzV733XZc3mDz5ssEAN8DFgCkpAmCFDKQVAgsBwk IU0g
oJSGoEDg/gs7iB1L3873YDhhfd+/hM4cjiZ1lnC6FncQJkmah/k6wNJJ1f6V m2Uq
eS8bWegXCyzmSEgbCTAFHW6kqcgAoNKA4wiQaGBZZwfFbyRZOqW2tvOGmd27 zA6o
c5Rs7lDufBhrLwLnoylPFM6yjoqyDhnoCQMs50hIDQEodRwoCjjZl5AaCmBm /EgU
8GEVCamhAOyRFcKgAQbwyj7aY1xQBX5CIaHOoai+HAAXMMM/18h1zP284XWR LKZl
o3m/S8T9mha4PRfw4dkUOJmjmF+Haudq5n3oW6Yv/46sRsOYFf+V0HnXS8dD 6USh
Vyi0LB9vfqkBwc3YgMNAAyAhbTDAuAGuZPavsIMldef1nZHDV6kzv0tIj9xR MrtL
1bPQs0edBwautongcUcq3yequ95DIvpDBMs+EtLJA0rxB4sJugMJ6WQCxylw tZuG
1W59YAJs3RvR0IYG4s0CMCh4z8CbewaPeXPiJ91Re5/gWxoB/4wAksJRJvwO hc50
vYOYL7/+14yZrksV/53p2rt0DaVwlHTtUOhM1zuIeZNtY+5eSvodc7d3uRtX 7iiJ
3KHqudPgPnUeRPPLbGIyMwFRPMLyg3dcj6NiPQ556CEPrdstXI2jiwY3AwRO BH2B
hFQSAeMQuNxAwXKDPhABtuZApZlQa6Zvkui3BXcv3yZ/h/uv0UtXIeJQ/qpm HGil
JaQRBlwn7RAIOmkJaQQC10g7BIJGWkIagYD30QqMhFIfHacPJqNr2KL9E5po JSaa
LACzQActIXUk4NpnhzTQPktIHQ243tkZDbMsmkZ5dG+Khj0HQz385QWqP6+u 0KrN
q1gFnj1DcQWqq2HnMbZB69dhULfpx+Lj+fCTPdldS0RnwdoZN4VeOntoDolD mZw4
vAP7IczDPyOJxuC+KD9W56lzY33ibvNifdiDXc8yJ66Ld9OVPFQGPPwwYMma X/0S
8lzmKF/0LqXOmriE1M1y4QviCoqCSgvii9mMRcCt2lewZzgL4mQBnYXWBIIF cT0k
uBkccBroiiWkjgYUnwxFA0ufHan/JomLSrqZ/BAuZ2esgbIG6nO2B9U7i6Es hlYh
dTMc+GKow4kO9x7cQfgbDbx0ypXWnW86OHrDWY13sxpAoaPMaFzqnW8A3YvC g7xp
wKV3mqv2ozdrMxZuMujjLSxC0BcIWl/IvHflPwJuBgUdA074JaQGA5xZPxIG rGxK
SA0GYBVNLBpY0txB8e0Hn1jTFH3zpYX+TXEQlQ4zveHLC/uZvm+uPl3wdbNN JfMF
hv6lbjSVw6RtZ2LvwxYCV6a1HEvJ/gEOd57jItqO8t0T5W66jIdKdRALZ7nt rn/f
6UAaR/k671LnZeD0uvjTfv4fUEsDBAoAAAAAALNwlzgAAAAAAAAAAAAAAAAY AAAA
ZWNsaXBzZWNvbjIwMDgubTJtLnF2dG8vUEsBAhQAFAAAAAgAR4trOJSk+Yn+ AAAA
AQIAACAAAAAAAAAAAQAgALaBAAAAAGVjbGlwc2Vjb24yMDA4Lm0ybS5xdnRv Ly5w
cm9qZWN0UEsBAhQACgAAAAAAs3CXOAAAAAAAAAAAAAAAACIAAAAAAAAAAAAQ AP9B
PAEAAGVjbGlwc2Vjb24yMDA4Lm0ybS5xdnRvLy5zZXR0aW5ncy9QSwECFAAU AAAA
CABti2s4eOIXV+IAAABoAQAARwAAAAAAAAABACAAtoF8AQAAZWNsaXBzZWNv bjIw
MDgubTJtLnF2dG8vLnNldHRpbmdzL29yZy5lY2xpcHNlLm0ybS5xdnQub21s Lm1t
b2RlbC51cmltYXBQSwECFAAUAAAACACIcJc4R1ZRTogEAACcDgAAJwAAAAAA AAAB
ACAAtoHDAgAAZWNsaXBzZWNvbjIwMDgubTJtLnF2dG8vRWNvcmUyRU1PRi5x dnRv
UEsBAhQACgAAAAAAs3CXOAAAAAAAAAAAAAAAAB4AAAAAAAAAAAAQAP9BkAcA AGVj
bGlwc2Vjb24yMDA4Lm0ybS5xdnRvL21vZGVsL1BLAQIUABQAAAAIADWcczjq IT4n
7wMAAMgaAAAoAAAAAAAAAAEAIAC2gcwHAABlY2xpcHNlY29uMjAwOC5tMm0u cXZ0
by9tb2RlbC9lbW9mLmVjb3JlUEsBAhQAFAAAAAgAT6l0OAKIDr+KBAAADC0A ACcA
AAAAAAAAAQAgALaBAQwAAGVjbGlwc2Vjb24yMDA4Lm0ybS5xdnRvL21vZGVs L2Vt
b2YuZW1vZlBLAQIUABQAAAAIAE+pdDh/q6tigw0AAHaKAgAxAAAAAAAAAAEA IAC2
gdAQAABlY2xpcHNlY29uMjAwOC5tMm0ucXZ0by9tb2RlbC9lbW9mLmVtb2Yu cXZ0
b3RyYWNlUEsBAhQACgAAAAAAs3CXOAAAAAAAAAAAAAAAABgAAAAAAAAAAAAQ AP9B
oh4AAGVjbGlwc2Vjb24yMDA4Lm0ybS5xdnRvL1BLBQYAAAAACQAJAAQDAADY HgAA
AAA=
------------YxEog0xuUM0vLfLdwgdXjC--
Current Time: Mon Jul 21 21:45:12 EDT 2025
Powered by FUDForum. Page generated in 0.07313 seconds
