Home » Eclipse Projects » Eclipse Platform » CVS crashes Eclipse 2.1 under Linux
CVS crashes Eclipse 2.1 under Linux [message #83468] Thu, 26 June 2003 20:37 Go to next message
Originally posted by: robinson.cs.stanford.edu
I'm running Eclipse 2.1 on a RH 9 system, and trying to connect to a CVS
server through ssh. I've set up a public/private keypair that allows me
to ssh into the server machine without using a password, and allows me to
use command-line CVS without using a password (with this server specified
as CVSROOT).
I can add this remote server as a repository in the CVS repository
explorer perspective. Then when I select a Java project and try
to share it, it takes me through the wizard. However, Eclipse
crashes after I click Finish.
I get this behavior regardless of whether I choose "ext" or "extssh" as
the method of connecting to the repository. My hs_err_* log always
looks roughly the same after Eclipse has crashed in this way (the crash
is always in gtk_progress_bar_set_fraction()). I'll paste the log file
in below.
Thanks in advance for any help you can offer...
Will Robinson
contents of hs_err_pid6257.log follow:
An unexpected exception has been detected in native code outside the VM.
Unexpected Signal : 11 occurred at PC=0x4D585F15
Function=(null)+0x4D585F15
Library=/usr/lib/libgdk-x11-2.0.so.0
NOTE: We are unable to locate the function name symbol for the error
just occurred. Please refer to release documentation for possible
reason and solutions.
Current Java thread:
at org.eclipse.swt.internal.gtk.OS.gtk_progress_bar_set_fractio n(Native Method)
- locked <0x485d2490> (a java.lang.Class)
at org.eclipse.swt.widgets.ProgressBar.updateBar(ProgressBar.ja va:213)
at org.eclipse.swt.widgets.ProgressBar.setSelection(ProgressBar .java:203)
at org.eclipse.jface.dialogs.ProgressIndicator.worked(ProgressI ndicator.java:115)
at org.eclipse.jface.wizard.ProgressMonitorPart.internalWorked( ProgressMonitorPart.java:156)
at org.eclipse.jface.operation.AccumulatingProgressMonitor$Coll ector.run(AccumulatingProgressMonitor.java:74)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:3 5)
at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchr onizer.java:98)
- locked <0x44218450> (a org.eclipse.swt.widgets.RunnableLock)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.jav a:1614)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :1432)
at org.eclipse.jface.operation.ModalContext$ModalContextThread. block(ModalContext.java:136)
at org.eclipse.jface.operation.ModalContext.run(ModalContext.ja va:261)
at org.eclipse.jface.wizard.WizardDialog.run(WizardDialog.java: 758)
at org.eclipse.team.internal.ccvs.ui.wizards.SharingWizard.perf ormFinish(SharingWizard.java:174)
at org.eclipse.team.internal.ui.ConfigureProjectWizard.performF inish(ConfigureProjectWizard.java:124)
at org.eclipse.jface.wizard.WizardDialog.finishPressed(WizardDi alog.java:608)
at org.eclipse.jface.wizard.WizardDialog.buttonPressed(WizardDi alog.java:321)
at org.eclipse.jface.dialogs.Dialog$1.widgetSelected(Dialog.jav a:423)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:89)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :81)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:913)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:1637)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :1429)
at org.eclipse.jface.window.Window.runEventLoop(Window.java:583 )
at org.eclipse.jface.window.Window.open(Window.java:563)
at org.eclipse.team.internal.ui.actions.ConfigureProjectAction$ 1.run(ConfigureProjectAction.java:42)
at org.eclipse.team.internal.ui.actions.TeamAction$1.run(TeamAc tion.java:168)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:69)
at org.eclipse.team.internal.ui.actions.TeamAction.run(TeamActi on.java:165)
at org.eclipse.team.internal.ui.actions.ConfigureProjectAction. run(ConfigureProjectAction.java:35)
at org.eclipse.ui.actions.ActionDelegate.runWithEvent(ActionDel egate.java:71)
at org.eclipse.ui.internal.PluginAction.runWithEvent(PluginActi on.java:241)
at org.eclipse.jface.action.ActionContributionItem.handleWidget Selection(ActionContributionItem.java:456)
at org.eclipse.jface.action.ActionContributionItem.handleWidget Event(ActionContributionItem.java:403)
at org.eclipse.jface.action.ActionContributionItem.access$0(Act ionContributionItem.java:397)
at org.eclipse.jface.action.ActionContributionItem$ActionListen er.handleEvent(ActionContributionItem.java:72)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1402)
at org.eclipse.ui.internal.Workbench.run(Workbench.java:1385)
at org.eclipse.core.internal.boot.InternalBootLoader.run(Intern alBootLoader.java:845)
at org.eclipse.core.boot.BootLoader.run(BootLoader.java:461)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAcce ssorImpl.java:39)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMe thodAccessorImpl.java:25)
at org.eclipse.core.launcher.Main.basicRun(Main.java:291)
at org.eclipse.core.launcher.Main.run(Main.java:747)
at org.eclipse.core.launcher.Main.main(Main.java:583)
Dynamic libraries:
08048000-0804e000 r-xp 00000000 03:02 16337 /usr/java/j2sdk1.4.1_03/bin/java
0804e000-0804f000 rw-p 00005000 03:02 16337 /usr/java/j2sdk1.4.1_03/bin/java
40000000-40015000 r-xp 00000000 03:02 179192 /lib/ld-2.3.2.so
40015000-40016000 rw-p 00014000 03:02 179192 /lib/ld-2.3.2.so
40017000-4001f000 r-xp 00000000 03:02 635611 /usr/java/j2sdk1.4.1_03/jre/lib/i386/native_threads/libhpi.s o
4001f000-40020000 rw-p 00007000 03:02 635611 /usr/java/j2sdk1.4.1_03/jre/lib/i386/native_threads/libhpi.s o
40020000-40023000 r--s 00000000 03:02 619356 /usr/java/j2sdk1.4.1_03/jre/lib/ext/dnsns.jar
40023000-40024000 r--s 00000000 00:09 593312 /u/robinson/eclipse/plugins/org.eclipse.ui_2.1.0/ui.jar
40024000-40025000 r-xp 00000000 00:09 2271069 /u/robinson/eclipse/plugins/org.eclipse.core.resources.linux _2.1.0/os/linux/x86/libcore_2_1_0a.so
40025000-40026000 rw-p 00001000 00:09 2271069 /u/robinson/eclipse/plugins/org.eclipse.core.resources.linux _2.1.0/os/linux/x86/libcore_2_1_0a.so
40027000-40032000 r-xp 00000000 03:02 2247771 /lib/tls/libpthread-0.34.so
40032000-40033000 rw-p 0000a000 03:02 2247771 /lib/tls/libpthread-0.34.so
40035000-40038000 r-xp 00000000 03:02 179207 /lib/libdl-2.3.2.so
40038000-40039000 rw-p 00002000 03:02 179207 /lib/libdl-2.3.2.so
4003a000-402ee000 r-xp 00000000 03:02 82039 /usr/java/j2sdk1.4.1_03/jre/lib/i386/client/libjvm.so
402ee000-404cd000 rw-p 002b3000 03:02 82039 /usr/java/j2sdk1.4.1_03/jre/lib/i386/client/libjvm.so
404de000-404f0000 r-xp 00000000 03:02 179211 /lib/libnsl-2.3.2.so
404f0000-404f1000 rw-p 00011000 03:02 179211 /lib/libnsl-2.3.2.so
404f3000-40514000 r-xp 00000000 03:02 2247769 /lib/tls/libm-2.3.2.so
40514000-40515000 rw-p 00020000 03:02 2247769 /lib/tls/libm-2.3.2.so
40515000-40525000 r-xp 00000000 03:02 17167 /usr/java/j2sdk1.4.1_03/jre/lib/i386/libverify.so
40525000-40527000 rw-p 0000f000 03:02 17167 /usr/java/j2sdk1.4.1_03/jre/lib/i386/libverify.so
40527000-40548000 r-xp 00000000 03:02 17155 /usr/java/j2sdk1.4.1_03/jre/lib/i386/libjava.so
40548000-4054a000 rw-p 00020000 03:02 17155 /usr/java/j2sdk1.4.1_03/jre/lib/i386/libjava.so
4054a000-4055e000 r-xp 00000000 03:02 17168 /usr/java/j2sdk1.4.1_03/jre/lib/i386/libzip.so
4055e000-40561000 rw-p 00013000 03:02 17168 /usr/java/j2sdk1.4.1_03/jre/lib/i386/libzip.so
40561000-41c35000 r--s 00000000 03:02 2167114 /usr/java/j2sdk1.4.1_03/jre/lib/rt.jar
41c78000-41c8f000 r--s 00000000 03:02 2167115 /usr/java/j2sdk1.4.1_03/jre/lib/sunrsasign.jar
41c8f000-41d01000 r--s 00000000 03:02 2167108 /usr/java/j2sdk1.4.1_03/jre/lib/jsse.jar
41d01000-41d14000 r--s 00000000 03:02 2167107 /usr/java/j2sdk1.4.1_03/jre/lib/jce.jar
41d14000-41fd0000 r--s 00000000 03:02 2167095 /usr/java/j2sdk1.4.1_03/jre/lib/charsets.jar
41ff8000-41ffd000 r--s 00000000 00:09 649894 /u/robinson/eclipse/startup.jar
41ffd000-41ffe000 r-xp 00000000 03:02 1368352 /usr/X11R6/lib/X11/locale/lib/common/xlcUTF8Load.so.2
41ffe000-41fff000 rw-p 00000000 03:02 1368352 /usr/X11R6/lib/X11/locale/lib/common/xlcUTF8Load.so.2
42000000-4212f000 r-xp 00000000 03:02 2247763 /lib/tls/libc-2.3.2.so
4212f000-42132000 rw-p 0012f000 03:02 2247763 /lib/tls/libc-2.3.2.so
441b4000-441bf000 r-xp 00000000 03:02 179217 /lib/libnss_files-2.3.2.so
441bf000-441c0000 rw-p 0000a000 03:02 179217 /lib/libnss_files-2.3.2.so
4c3c3000-4c5c3000 r--p 00000000 03:02 473010 /usr/lib/locale/locale-archive
4c7c7000-4c866000 r--s 00000000 03:02 619358 /usr/java/j2sdk1.4.1_03/jre/lib/ext/localedata.jar
4c866000-4c874000 r--s 00000000 03:02 619357 /usr/java/j2sdk1.4.1_03/jre/lib/ext/ldapsec.jar
4c874000-4c891000 r--s 00000000 03:02 619359 /usr/java/j2sdk1.4.1_03/jre/lib/ext/sunjce_provider.jar
4c912000-4c92a000 r--s 00000000 00:09 8281926 /u/robinson/eclipse/plugins/org.eclipse.core.boot_2.1.0/boot .jar
4c92a000-4c95f000 r--s 00000000 00:09 8281940 /u/robinson/eclipse/plugins/org.eclipse.core.runtime_2.1.0/r untime.jar
4c95f000-4c9ae000 r--s 00000000 00:09 2055481 /u/robinson/eclipse/plugins/org.eclipse.ui.views_2.1.0/views .jar
4c9ae000-4cbc5000 r--s 00000000 00:09 2055457 /u/robinson/eclipse/plugins/org.eclipse.ui.workbench_2.1.0/w orkbench.jar
4cbc5000-4cc31000 r--s 00000000 00:09 10527484 /u/robinson/eclipse/plugins/org.eclipse.jface_2.1.0/jface.ja r
4cc31000-4cce2000 r--s 00000000 00:09 2271053 /u/robinson/eclipse/plugins/org.eclipse.swt.gtk_2.1.0/ws/gtk /swt.jar
4cce2000-4cd6f000 r--s 00000000 00:09 3440455 /u/robinson/eclipse/plugins/org.eclipse.core.resources_2.1.0 /resources.jar
4cd6f000-4cd85000 r--s 00000000 00:09 8281935 /u/robinson/eclipse/plugins/org.apache.xerces_4.0.7/xmlParse rAPIs.jar
4cd85000-4cea4000 r--s 00000000 00:09 8281937 /u/robinson/eclipse/plugins/org.apache.xerces_4.0.7/xercesIm pl.jar
4cea4000-4cf0b000 r--s 00000000 00:09 3955824 /u/robinson/eclipse/plugins/org.eclipse.team.cvs.core_2.1.0/ cvs.jar
4cf0b000-4cf3e000 r--s 00000000 00:09 673984 /u/robinson/eclipse/plugins/org.eclipse.search_2.1.0/search. jar
4cf3e000-4cf4c000 r--s 00000000 00:09 1469507 /u/robinson/eclipse/plugins/org.eclipse.pde_2.1.0/pde.jar
4cf4c000-4d1a5000 r--s 00000000 00:09 1386003 /u/robinson/eclipse/plugins/org.eclipse.jdt.core_2.1.0/jdtco re.jar
4d1a5000-4d1e5000 r--s 00000000 00:09 6807136 /u/robinson/eclipse/plugins/org.eclipse.jdt.junit_2.1.0/juni tsupport.jar
4d1e5000-4d1fb000 r--s 00000000 00:09 6917451 /u/robinson/eclipse/plugins/org.eclipse.help.ui_2.1.0/helpwo rkbench.jar
4d1fb000-4d25c000 r--s 00000000 00:09 228417 /u/robinson/eclipse/plugins/org.eclipse.compare_2.1.0/compar e.jar
4d25c000-4d263000 r--s 00000000 00:09 2271052 /u/robinson/eclipse/plugins/org.eclipse.swt.gtk_2.1.0/ws/gtk /swt-pi.jar
4d263000-4d28d000 r-xp 00000000 00:09 2271058 /u/robinson/eclipse/plugins/org.eclipse.swt.gtk_2.1.0/os/lin ux/x86/libswt-pi-gtk-2133.so
4d28d000-4d28f000 rw-p 00029000 00:09 2271058 /u/robinson/eclipse/plugins/org.eclipse.swt.gtk_2.1.0/os/lin ux/x86/libswt-pi-gtk-2133.so
4d28f000-4d295000 r--s 00000000 03:02 1612729 /usr/lib/gconv/gconv-modules.cache
4d295000-4d296000 r-xp 00000000 03:02 1612673 /usr/lib/gconv/ISO8859-1.so
4d296000-4d297000 rw-p 00001000 03:02 1612673 /usr/lib/gconv/ISO8859-1.so
4d297000-4d299000 r-xp 00000000 03:02 1254308 /usr/lib/pango/1.2.0/modules/pango-basic-xft.so
4d299000-4d29a000 rw-p 00001000 03:02 1254308 /usr/lib/pango/1.2.0/modules/pango-basic-xft.so
4d29f000-4d2a3000 r-xp 00000000 03:02 358406 /usr/lib/libgthread-2.0.so.0.200.1
4d2a3000-4d2a4000 rw-p 00003000 03:02 358406 /usr/lib/libgthread-2.0.so.0.200.1
4d2a4000-4d30d000 r-xp 00000000 03:02 358400 /usr/lib/libglib-2.0.so.0.200.1
4d30d000-4d30e000 rw-p 00069000 03:02 358400 /usr/lib/libglib-2.0.so.0.200.1
4d30e000-4d557000 r-xp 00000000 03:02 358607 /usr/lib/libgtk-x11-2.0.so.0.200.1
4d557000-4d560000 rw-p 00248000 03:02 358607 /usr/lib/libgtk-x11-2.0.so.0.200.1
4d562000-4d5cb000 r-xp 00000000 03:02 358601 /usr/lib/libgdk-x11-2.0.so.0.200.1
4d5cb000-4d5d0000 rw-p 00069000 03:02 358601 /usr/lib/libgdk-x11-2.0.so.0.200.1
4d5d0000-4d5e7000 r-xp 00000000 03:02 358569 /usr/lib/libatk-1.0.so.0.200.0
4d5e7000-4d5e9000 rw-p 00016000 03:02 358569 /usr/lib/libatk-1.0.so.0.200.0
4d5e9000-4d5fb000 r-xp 00000000 03:02 358603 /usr/lib/libgdk_pixbuf-2.0.so.0.200.1
4d5fb000-4d5fc000 rw-p 00011000 03:02 358603 /usr/lib/libgdk_pixbuf-2.0.so.0.200.1
4d5fc000-4d608000 r-xp 00000000 03:02 358597 /usr/lib/libpangox-1.0.so.0.200.1
4d608000-4d609000 rw-p 0000b000 03:02 358597 /usr/lib/libpangox-1.0.so.0.200.1
4d609000-4d630000 r-xp 00000000 03:02 358593 /usr/lib/libpango-1.0.so.0.200.1
4d630000-4d63c000 rw-p 00026000 03:02 358593 /usr/lib/libpango-1.0.so.0.200.1
4d63c000-4d66f000 r-xp 00000000 03:02 358404 /usr/lib/libgobject-2.0.so.0.200.1
4d66f000-4d671000 rw-p 00032000 03:02 358404 /usr/lib/libgobject-2.0.so.0.200.1
4d671000-4d674000 r-xp 00000000 03:02 358402 /usr/lib/libgmodule-2.0.so.0.200.1
4d674000-4d675000 rw-p 00002000 03:02 358402 /usr/lib/libgmodule-2.0.so.0.200.1
4d675000-4d695000 r-xp 00000000 03:02 358599 /usr/lib/libpangoxft-1.0.so.0.200.1
4d695000-4d696000 rw-p 0001f000 03:02 358599 /usr/lib/libpangoxft-1.0.so.0.200.1
4d696000-4d699000 r-xp 00000000 03:02 521435 /usr/X11R6/lib/libXrandr.so.2.0
4d699000-4d69a000 rw-p 00002000 03:02 521435 /usr/X11R6/lib/libXrandr.so.2.0
4d69a000-4d6a1000 r-xp 00000000 03:02 521425 /usr/X11R6/lib/libXi.so.6.0
4d6a1000-4d6a2000 rw-p 00006000 03:02 521425 /usr/X11R6/lib/libXi.so.6.0
4d6a2000-4d6af000 r-xp 00000000 03:02 521417 /usr/X11R6/lib/libXext.so.6.4
4d6af000-4d6b0000 rw-p 0000c000 03:02 521417 /usr/X11R6/lib/libXext.so.6.4
4d6b0000-4d6c1000 r-xp 00000000 03:02 521423 /usr/X11R6/lib/libXft.so.2.1
4d6c1000-4d6c2000 rw-p 00010000 03:02 521423 /usr/X11R6/lib/libXft.so.2.1
4d6c2000-4d6c9000 r-xp 00000000 03:02 521437 /usr/X11R6/lib/libXrender.so.1.2
4d6c9000-4d6ca000 rw-p 00006000 03:02 521437 /usr/X11R6/lib/libXrender.so.1.2
4d6ca000-4d6eb000 r-xp 00000000 03:02 358518 /usr/lib/libfontconfig.so.1.0
4d6eb000-4d6ee000 rw-p 00021000 03:02 358518 /usr/lib/libfontconfig.so.1.0
4d6ef000-4d7cb000 r-xp 00000000 03:02 521407 /usr/X11R6/lib/libX11.so.6.2
4d7cb000-4d7ce000 rw-p 000db000 03:02 521407 /usr/X11R6/lib/libX11.so.6.2
4d7ce000-4d81a000 r-xp 00000000 03:02 358514 /usr/lib/libfreetype.so.6.3.2
4d81a000-4d81e000 rw-p 0004c000 03:02 358514 /usr/lib/libfreetype.so.6.3.2
4d81f000-4d83d000 r-xp 00000000 03:02 358390 /usr/lib/libexpat.so.0.4.0
4d83d000-4d83f000 rw-p 0001e000 03:02 358390 /usr/lib/libexpat.so.0.4.0
4d83f000-4d864000 r-xp 00000000 00:09 2271059 /u/robinson/eclipse/plugins/org.eclipse.swt.gtk_2.1.0/os/lin ux/x86/libswt-gtk-2133.so
4d864000-4d866000 rw-p 00025000 00:09 2271059 /u/robinson/eclipse/plugins/org.eclipse.swt.gtk_2.1.0/os/lin ux/x86/libswt-gtk-2133.so
4d866000-4d872000 r-xp 00000000 03:02 814762 /usr/lib/gtk-2.0/2.2.0/engines/libbluecurve.so
4d872000-4d873000 rw-p 0000b000 03:02 814762 /usr/lib/gtk-2.0/2.2.0/engines/libbluecurve.so
4d873000-4d883000 r--s 00000000 00:09 638281 /u/robinson/eclipse/plugins/org.eclipse.pde.runtime_2.1.0/pd ert.jar
4d883000-4d88b000 r-xp 00000000 03:02 521415 /usr/X11R6/lib/libXcursor.so.1.0
4d88b000-4d88c000 rw-p 00007000 03:02 521415 /usr/X11R6/lib/libXcursor.so.1.0
4d88c000-4d8de000 r--s 00000000 00:09 8281946 /u/robinson/eclipse/plugins/org.eclipse.update.core_2.1.0/up datecore.jar
4d8de000-4d90b000 r--s 00000000 00:09 10287471 /u/robinson/eclipse/plugins/org.eclipse.help_2.1.0/help.jar
4d90b000-4d961000 r--s 00000000 00:09 3955819 /u/robinson/eclipse/plugins/org.eclipse.jface.text_2.1.0/jfa cetext.jar
4d961000-4d973000 r--s 00000000 00:09 3440471 /u/robinson/eclipse/plugins/org.eclipse.text_2.1.0/text.jar
4d973000-4d9ed000 r--s 00000000 00:09 9092167 /u/robinson/eclipse/plugins/org.eclipse.debug.ui_2.1.0/dtui. jar
4d9ed000-4ddba000 r--s 00000000 00:09 5489120 /u/robinson/eclipse/plugins/org.eclipse.jdt.ui_2.1.0/jdt.jar
4ddba000-4de88000 r--s 00000000 00:09 5533090 /u/robinson/eclipse/plugins/org.eclipse.team.cvs.ui_2.1.0/te amcvsui.jar
4de88000-4e019000 r--s 00000000 00:09 12557926 /u/robinson/eclipse/plugins/org.eclipse.pde.ui_2.1.0/pdeui.j ar
4e019000-4e0b5000 r--s 00000000 00:09 12247584 /u/robinson/eclipse/plugins/org.eclipse.update.ui_2.1.0/upda teui.jar
4e0b5000-4e174000 r--s 00000000 00:09 4040448 /u/robinson/eclipse/plugins/org.eclipse.jdt.debug.ui_2.1.0/j diui.jar
4e174000-4e240000 r--s 00000000 00:09 6021571 /u/robinson/eclipse/plugins/org.eclipse.ui.externaltools_2.1 .0/externaltools.jar
4e240000-4e247000 r--s 00000000 00:09 5607581 /u/robinson/eclipse/plugins/org.eclipse.ant.core_2.1.0/antsu pport.jar
4e247000-4e25e000 r--s 00000000 00:09 10527478 /u/robinson/eclipse/plugins/org.eclipse.team.core_2.1.0/team .jar
4e25e000-4e278000 r--s 00000000 00:09 2055486 /u/robinson/eclipse/plugins/org.eclipse.ui.editors_2.1.0/edi tors.jar
4e278000-4e28a000 r--p 00000000 03:02 1954708 /usr/X11R6/lib/X11/fonts/Type1/l048013t.pfa
4e28a000-4e2d1000 r--s 00000000 00:09 4504320 /u/robinson/eclipse/plugins/org.eclipse.team.ui_2.1.0/teamui .jar
4e352000-4e38a000 r--s 00000000 00:09 2055476 /u/robinson/eclipse/plugins/org.eclipse.ui.workbench.textedi tor_2.1.0/texteditor.jar
4e38a000-4e3a8000 r--s 00000000 00:09 3955813 /u/robinson/eclipse/plugins/org.eclipse.debug.core_2.1.0/dtc ore.jar
4e3a8000-4e3b4000 r--s 00000000 00:09 6330839 /u/robinson/eclipse/plugins/org.eclipse.jdt.debug_2.1.0/jdi. jar
4e3b4000-4e454000 r--s 00000000 00:09 6330840 /u/robinson/eclipse/plugins/org.eclipse.jdt.debug_2.1.0/jdim odel.jar
4e454000-4e478000 r--s 00000000 00:09 1182944 /u/robinson/eclipse/plugins/org.eclipse.jdt.launching_2.1.0/ launching.jar
4e57a000-4e586000 r--s 00000000 00:09 2055462 /u/robinson/eclipse/plugins/org.eclipse.team.cvs.ssh_2.1.0/t eamcvsssh.jar
4e586000-4e598000 r--p 00000000 03:02 1954710 /usr/X11R6/lib/X11/fonts/Type1/l048016t.pfa
4e598000-4e5a8000 r-xp 00000000 03:02 17164 /usr/java/j2sdk1.4.1_03/jre/lib/i386/libnet.so
4e5a8000-4e5a9000 rw-p 0000f000 03:02 17164 /usr/java/j2sdk1.4.1_03/jre/lib/i386/libnet.so
Local Time = Thu Jun 26 17:27:41 2003
Elapsed Time = 3300
# The exception above was detected in native code outside the VM
# Java VM: Java HotSpot(TM) Client VM (1.4.1_03-b02 mixed mode)
Re: CVS crashes Eclipse 2.1 under Linux [message #83500 is a reply to message #83468] Thu, 26 June 2003 21:54 Go to previous messageGo to next message
> in below.
Have you tried a different GTK theme?
I think this might be a known bug with bluecurve on RH9, but I don't know
the bug number.
mike
> Will Robinson
Re: CVS crashes Eclipse 2.1 under Linux [message #84101 is a reply to message #83500] Fri, 27 June 2003 13:23 Go to previous messageGo to next message
>> in below.
> the bug number.
Yes, switching to the Crux theme fixed this problem immediately. Thanks
for your help!
What a crazy bug...couldn't believe my eyes. :)
Will
Re: CVS crashes Eclipse 2.1 under Linux [message #84175 is a reply to message #84101] Fri, 27 June 2003 14:12 Go to previous message
Originally posted by: muelleimer.usenet.katzien.de
> for your help!
Will be fixed in 2.1.1 (about to come out today/tomorrow?)
https://bugs.eclipse.org/bugs/show_bug.cgi?id=32204 (AFAIK)
Jan
Previous Topic:jspEditor plugin for eclipse from strecl crashes eclipse
Next Topic:Removing action sets from a perspective
Current Time: Sun Jun 29 02:18:29 EDT 2025
Powered by FUDForum. Page generated in 0.03804 seconds
