Home » Eclipse Projects » Eclipse Platform » Hashtable
Hashtable [message #83453] |
Thu, 26 June 2003 19:42  |
Originally posted by: jayesh.patel.ansa2.com
We hope this the right place for this kind of
problem we're having at the moment.
This is a problem we never had until today, and up
until today the code was working
fine.
Our problem is this, we've been adding into an
instance of 'java.util.Hashtable' using
'put(object, value)' method. This is what is
happening:
- we add an object into the table, and shows up in
the inspector and the counter
increments by one.
- we add another object and the same thing
happens.
- we add another object and this time it replaces
the first object in the table, and get this
increments counter by one.
Our code carries on and some entries are added,
but a third get over written. Now the
interesting thing is that it is not random, it's
always the same objects, but the counter always
says that the more entries in the table, than
there really are. Before you even say it, both
the object and the value are not null, so don't
even go there.
We've checked our code/data time and time again,
there is nothing wrong there. The odd
thing is we was using eclipse 2.0.2 with 1.4.0
java. We updated to 2.1 eclipse and java
1.4.2, still get the same exact problem.
Is this a bug in our code, eclipse or jave?
Has anybody else encountered this problem?
We' checked the Sun java site for any similar
problems to this and found none.
Please help we're at our wits end.
Many thanks .....
Jayesh Patel
Re: Hashtable [message #85801 is a reply to message #83453] |
Mon, 30 June 2003 16:01   |
My guess is you have a subtle bug in you equals() and/or hasCode() methods
on the
objects you use as the key. Check documentation for requirements.
Frank
"Jayesh Patel" <jayesh.patel@ansa2.com> wrote in message
news:bdg0cg$emv$1@rogue.oti.com...
> fine.
> happening:
> increments by one.
> happens.
> even go there.
> Many thanks .....
> Jayesh Patel
Re: Hashtable [message #86249 is a reply to message #85801] |
Tue, 01 July 2003 05:25   |
Couple of you have given us a few pointers we have
to check, however
another observation we've made is the overwriten
key is put into the
'next' in the hashtable entry.
We'll check our string key objects, which is the
fustrating thing they are
all unique.
Many thanks .....
Jayesh Patel
"Frank Sauer" <frank.sauer@trcinc.com> wrote in
message news:bdq4v5$e5t$1@rogue.oti.com...
> on the
for requirements.
> Frank
message
and up
> > fine.
> > happening:
up in
> > increments by one.
> > happens.
replaces
added,
it's
always
don't
> > even go there.
again,
> > Many thanks .....
> > Jayesh Patel
Re: Hashtable [message #86445 is a reply to message #86249] |
Tue, 01 July 2003 10:02  |
Originally posted by: wegener.cboenospam.com
> to check, however
> key is put into the
Then it sounds like you have keys that are hashing to the same value and
Hashtable is behaving as expected. When 2 keys hash to the same value and
the keys aren't equal, the objects are chained together. The fact that
the item count is incrementing and the next field of entries is being
populated indicates that you are adding items to the table.
Have you tried printing toString on your Hashtable to dump out all of the
entries. I think that you will find that they all are there.
> all unique.
> Many thanks .....
> Jayesh Patel
> > on the
> for requirements.
> > Frank
> message
> and up
> > > fine.
> > > happening:
> up in
> > > increments by one.
> > > happens.
> replaces
> added,
> it's
> always
> don't
> > > even go there.
> again,
> > > Many thanks .....
> > > Jayesh Patel
Current Time: Mon Jul 21 21:58:23 EDT 2025
Powered by FUDForum. Page generated in 0.26157 seconds
