Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » [Teneo] Which version of Hibernate?
[Teneo] Which version of Hibernate? [message #83444] Tue, 15 May 2007 13:39 Go to next message
Originally posted by: irbull.cs.uvic.ca
I just updated my hibernate to the latest version (3.2.4 GA) and I get
the exception below. I had an older version of the hibernate jar (still
called hibernate3.jar) from march and the library example works fine
there. Any thoughts?
Exception in thread "main" org.hibernate.exception.SQLGrammarException:
could not insert: [Library]
org.hibernate.exception.SQLStateConverter.convert(SQLStateCo nverter.java:67)
org.hibernate.exception.JDBCExceptionHelper.convert(JDBCExce ptionHelper.java:43)
org.hibernate.id.insert.AbstractReturningDelegate.performIns ert(AbstractReturningDelegate.java:40)
org.hibernate.persister.entity.AbstractEntityPersister.inser t(AbstractEntityPersister.java:2158)
org.hibernate.persister.entity.AbstractEntityPersister.inser t(AbstractEntityPersister.java:2638)
org.hibernate.action.EntityIdentityInsertAction.execute(Enti tyIdentityInsertAction.java:48)
at org.hibernate.engine.ActionQueue.execute(ActionQueue.java:25 0)
org.hibernate.event.def.AbstractSaveEventListener.performSav eOrReplicate(AbstractSaveEventListener.java:298)
org.hibernate.event.def.AbstractSaveEventListener.performSav e(AbstractSaveEventListener.java:181)
org.hibernate.event.def.AbstractSaveEventListener.saveWithGe neratedId(AbstractSaveEventListener.java:107)
org.hibernate.event.def.DefaultSaveOrUpdateEventListener.sav eWithGeneratedOrRequestedId(DefaultSaveOrUpdateEventListener .java:187)
org.hibernate.event.def.DefaultSaveEventListener.saveWithGen eratedOrRequestedId(DefaultSaveEventListener.java:33)
org.hibernate.event.def.DefaultSaveOrUpdateEventListener.ent ityIsTransient(DefaultSaveOrUpdateEventListener.java:172)
org.hibernate.event.def.DefaultSaveEventListener.performSave OrUpdate(DefaultSaveEventListener.java:27)
org.hibernate.event.def.DefaultSaveOrUpdateEventListener.onS aveOrUpdate(DefaultSaveOrUpdateEventListener.java:70)
at org.hibernate.impl.SessionImpl.fireSave(SessionImpl.java:535 )
at org.hibernate.impl.SessionImpl.save(SessionImpl.java:523)
at org.hibernate.impl.SessionImpl.save(SessionImpl.java:519)
at mdvpersistence.Example.main(Example.java:68)
Caused by: java.sql.SQLException: No value specified for parameter 3
at com.mysql.jdbc.SQLError.createSQLException(SQLError.java:910 )
com.mysql.jdbc.PreparedStatement.fillSendPacket(PreparedStat ement.java:1674)
com.mysql.jdbc.PreparedStatement.executeUpdate(PreparedState ment.java:1512)
com.mysql.jdbc.PreparedStatement.executeUpdate(PreparedState ment.java:1455)
com.mysql.jdbc.PreparedStatement.executeUpdate(PreparedState ment.java:1440)
org.hibernate.id.IdentityGenerator$GetGeneratedKeysDelegate. executeAndExtract(IdentityGenerator.java:73)
org.hibernate.id.insert.AbstractReturningDelegate.performIns ert(AbstractReturningDelegate.java:33)
... 16 more
Re: [Teneo] Which version of Hibernate? [message #83485 is a reply to message #83444] Tue, 15 May 2007 14:32 Go to previous messageGo to next message
I am still at hibernate 3.2.3.
Can you post the hbm and the hibernate log output? If you set these then you should get some info:
### log just the SQL
log4j.logger.org.hibernate.SQL=debug
### log JDBC bind parameters ###
log4j.logger.org.hibernate.type=debug
Here is a post with a similar problem only it is not in english but maybe you can understand what
they write:
http://www.guj.com.br/posts/list/59353.java
gr. Martin
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> ... 16 more
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: [Teneo] Which version of Hibernate? [message #83499 is a reply to message #83485] Wed, 16 May 2007 01:46 Go to previous message
Thanks Martin,
No worries, I just noticed on the Elver site where you listed the
dependency on 3.2.3. I was just updating my system, but I a fine with
hibernate 3.2.3 (I am only using hibernate through Teneo anyways) :)
cheers,
ian
> maybe you can understand what they write:
> gr. Martin
>> (still called hibernate3.jar) from march and the library example works
>> fine there. Any thoughts?
>> org.hibernate.exception.SQLGrammarException: could not insert: [Library]
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> ... 16 more
Re: [Teneo] Which version of Hibernate? [message #606696 is a reply to message #83444] Tue, 15 May 2007 14:32 Go to previous message
they write:
gr. Martin
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> ... 16 more
The Netherlands
Re: [Teneo] Which version of Hibernate? [message #606697 is a reply to message #83485] Wed, 16 May 2007 01:46 Go to previous message
Thanks Martin,
cheers,
ian
> gr. Martin
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> ... 16 more
Previous Topic:Is it possible to store uml models excluding class diagrams using Teneo or CDO?
Next Topic:[Teneo] Performance creating a DB
Current Time: Sat Jul 26 10:37:26 EDT 2025
Powered by FUDForum. Page generated in 0.07712 seconds
