Home » Archived » EPP » Custom distros for private use?
Custom distros for private use? [message #7460] |
Thu, 28 February 2008 13:05  |
I'm attempting to use the EPP features for creating a custom distro for
use within my company. It is mainly a version of Eclipse with the
plugins we need already installed and ready to go. I have a few questions:
1. Is creating custom distros for private (local) use an expected use of
EPP?
2. Which versions of Eclipse are expected to be in the rootFileFolder?
The RCP versions? SDK? I don't want to have a mirror of the entire
eclipse.org downloads and am wondering what I need for EPP to build bundles.
3. Are non-eclipse.org update sites supported? (I was having problems
pulling a feature from a non eclipse.org site and want to make sure EPP
wasn't hardwired to work with eclipse.org.)
4. (This may be related to question 2 above) I've created a
configuration file and, using the CVS version of EPP as described in
"How to build a package locally" it seems to get through a lot of the
packaging process until it gets to the "Building configured
application..." step. All I see is (via an ant target):
> [java] Building configured application...
> [java] Configuration files taken from /home/aaronsi/workspace/packagerConfiguration.
> [java] The application will be built in /home/aaronsi/workspace.
at which point it dies silently. Any idea on what should be happening
next or what I'm doing wrong? I have the SDK and RCP eclipse packages
in the rootFileFolder.
Thanks for any info.
-Aaron
Re: Custom distros for private use? [message #7471 is a reply to message #7460] |
Thu, 28 February 2008 14:30   |
Originally posted by: mknauer.innoopract.com
Hi Aaron,
see my comments below... :)
> questions:
> EPP?
Yes, this is a use case, but I didn't provide a fancy editor for the config
files, nor is it really integrated in Eclipse as it is running on the
server.
If many people start using the EPP tools (and not only our packages), I
would be happy to work with other interested people on making it more easy
to use.
> bundles.
I am using the Eclipse Platform downloads. EPP uses the root files from that
archive. I know that there are better ways, but it is a reliable method to
get everything you need.
On the other hand, the name of the files is kind of hard wired. The EPP
build uses the rcp version attribute (e.g. "3.4M4") to build the file name
of the platform archive. I am not sure, but it looks like this could be
your problem below.
Yes, it's a standard URL and it is up to you to use something like
file:///home/data/httpd/download.eclipse.org/releases/ganyme de/ if you are
on the build server itself, or to use another URL.
The EPP build is caching the downloaded features and plugins, i.e. you do
not have to download things twice if you are running multiple builds.
>> [/home/aaronsi/workspace/packagerConfiguration.
A successful build log looks like this here:
http://download.eclipse.org/technology/epp/downloads/release /ganymede/M5/jee.log
If everything is okay you would see as next messages
## Packing installation site....Done.
## Building...Done.
## Moving Files...Done.
## Done.
Do you have any log files in your runtime workspace?
Or did you try to start the build with '-consoleLog'?
Sometimes it's really hard to figure out a specific error. Most of the times
there are dependency errors (one plugin requires a specific version of
another, etc.)
Let me know if one of these things helped to solve your problem and to get
your EPP build running.
Markus
> -Aaron
Re: Custom distros for private use? [message #7482 is a reply to message #7471] |
Fri, 29 February 2008 09:14   |
Thanks for the help. So far it is working well for us. The only issue
I ran into was that the skeletons directory wasn't included in the
binary build (build.properties) so that when I exported the plugin (I
run it via commandline from ant) it failed because it couldn't find the
skeleton files.
Is there a binary build available anywhere?
-Aaron
Markus Knauer wrote:
> Hi Aaron,
>> questions:
>> EPP?
> server.
> to use.
>> bundles.
> your problem below.
> ## Building...Done.
> ## Done.
> another, etc.)
> Markus
>> -Aaron
Re: Custom distros for private use? [message #10909 is a reply to message #7482] |
Wed, 01 October 2008 11:26  |
Originally posted by: gregor.rosenauer.itsv.at
I have recently discovered the usefulness of EPP for building a reference
installation of Eclipse for my employer.
The process was challenging as we have strict proxies that prevented me
from checking out the project from CVS, update sites come online and
offline unexpectedly, and Windows does not have an "unzip.exe"
preinstalled, which is expected by the Packager.
Now I get as far as Packager building my custom ZIP, but on the final
step, where the Ant script is invoked, it fails:
Building...Could not build package.:
org.apache.tools.ant.Project.setProjectReference(Ljava/lang/ Object;)V:org.apache.tools.ant.Project.setProjectReference(L java/lang/Object;)V
The full log excerpt:
!SUBENTRY 1 org.eclipse.ant.core 4 1 2008-10-01 13:54:12.126
!MESSAGE
!STACK 0
java.lang.NoSuchMethodError:
org.eclipse.ant.internal.core.ant.InputHandlerSetter.setInpu tHandler(InputHandlerSetter.java:43)
org.eclipse.ant.internal.core.ant.InternalAntRunner.addInput Handler(InternalAntRunner.java:1273)
org.eclipse.ant.internal.core.ant.InternalAntRunner.run(Inte rnalAntRunner.java:532)
org.eclipse.ant.internal.core.ant.InternalAntRunner.run(Inte rnalAntRunner.java:456)
at org.eclipse.ant.core.AntRunner.run(AntRunner.java:378)
at org.eclipse.ant.core.AntRunner.run(AntRunner.java:475)
org.eclipse.epp.packaging.core.assembly.PackagerRunner.packA pplication(PackagerRunner.java:51)
I am using Eclipse 3.4 EE package, also tried with a clean 3.4.1 RCP
install, same issue. Using Ant 1.7. I would be grateful for any help.
BTW Packager's logging is quite sparse, esp. on startup it stays quiet for
some time while digesting the features, I added some logging and it is
better indicating progress now, maybe this could be added?
It would also be very handy if update sites that are offline or not
reachable do not break the build but are retried at the end of the
process, before Packager continues with the next step. I have experienced
that simply rerunning the build will work, as sites are sometimes flaky
but come back online shortly most of the time.
Re: Custom distros for private use? [message #576245 is a reply to message #7460] |
Hi Aaron,
> questions:
> EPP?
server.
to use.
> bundles.
your problem below.
## Building...Done.
## Done.
another, etc.)
Markus
> -Aaron
Re: Custom distros for private use? [message #576257 is a reply to message #7471] |
skeleton files.
-Aaron
> Hi Aaron,
>> questions:
>> EPP?
> server.
> to use.
>> bundles.
> your problem below.
> ## Building...Done.
> ## Done.
> another, etc.)
> Markus
>> -Aaron
Re: Custom distros for private use? [message #578165 is a reply to message #7482] |
!MESSAGE
!STACK 0
Current Time: Sat Jul 12 07:23:38 EDT 2025
Powered by FUDForum. Page generated in 0.04326 seconds
