Home » Language IDEs » Java Development Tools (JDT) » Popup menus in Pkg explorer and Navigator view
Popup menus in Pkg explorer and Navigator view [message #83161] Tue, 05 August 2003 09:31 Go to next message
Originally posted by: amanaval.sybase.com
I am trying to get popup menus on a right click on the Project. I tried the
ObjectContribution, but that doesn't work for both, since the Project in
Navigator is IProject and its IJavaProject in Pkg Explorer. So, tried the
ViewerContribution - still not able to get it working.
Any help is appreciated.
thanks,
-Anou
<extension
point="org.eclipse.ui.popupMenus">
<viewerContribution
targetID="org.eclipse.ui.views.ResourceNavigator"
id="org.xyz.version.eclipse.contribution1">
<menu id="org.xyz.version.eclipse.showview"
label="Versions"
path="additions">
<separator name="group1"/>
</menu>
<action
label="Environment Versions"
class="org.xyz.version.eclipse.actions.ShowVersionViewAction "
menubarPath="org.xyz.version.eclipse.showview/group1"
id="org.xyz.version.eclipse.actions.ShowVersionViewAction">
</action>
<action
label="Classpath"
class="org.xyz.version.eclipse.actions.ShowClasspathAction"
id="org.xyz.version.eclipse.actions.ShowClasspathAction">
</action>
</viewerContribution>
<viewerContribution
targetID="org.eclipse.jdt.ui.PackageExplorer"
id="org.xyz.version.eclipse.contribution2">
<menu id="org.xyz.version.eclipse.showjpview"
label="Versions"
path="additions">
</menu>
<action
menubarPath="org.xyz.version.eclipse.showjpview/group1"
</action>
<action
label="Classpath"
</action>
</extension>
Re: Popup menus in Pkg explorer and Navigator view [message #83520 is a reply to message #83161] Wed, 06 August 2003 16:46 Go to previous messageGo to next message
Originally posted by: dale.sherwood.SPAM-BITBUCKET-nyab.com
Anou:
I'm an Eclipse newbie, but this works for me. The key to making it work for
both IProject and IJavaProject (and other projects) seems to be
adaptable="true"--without it, it only pops up in Navigator views.
<extension
<objectContribution
adaptable="true"
objectClass="org.eclipse.core.resources.IProject"
id="com.nyab.tools.project">
<action
label="Hello, world!"
class="com.nyab.tools.PopupMenuActionHello"
enablesFor="1"
id="com.nyab.tools.project.hello">
</action>
</objectContribution>
</extension>
->>>--Dale-Sherwood-->
New York Air Brake Corp.
TDS Group
"Anou Manavalan" <amanaval@sybase.com> wrote in message
news:bgobil$a4q$1@eclipse.org...
the
> thanks,
> -Anou
[snip]
Re: Popup menus in Pkg explorer and Navigator view [message #83766 is a reply to message #83520] Thu, 07 August 2003 09:23 Go to previous message
Thanks Dale,
But, I actually had the adabtable=true in the objectContribution, I do see
the the first level of pop menu, but my submenus are all greyed up in the
pkg explorer.
And see that the ObjectClass mentions IProject - The first menu probably
gets visible because that adaptable overrides that, but for submenus
something is getting screwed up with Object Class taking precedence. The
project in the Pkg explorer is IJavaProject and is in no way connected ( no
interface implementation or subclass ) to the IProject which I wonder why..
and so using ObjectContribution should not even make the first menu to be
visible. And I can't seem to get any answer for this.
If it is IFile and if adaptable is true, then it will work, since the pkg
explorer has ICompilationUnit, which is derived from a file. But in case of
IProject - there is no relationship between IJavaProject and IProject except
that they are adaptable - which I am not quite sure is helping here.
regards,
-Anou
"Dale Sherwood" <dale.sherwood@SPAM-BITBUCKET-nyab.com> wrote in message
news:bgrpeb$u9c$1@eclipse.org...
> Anou:
for
> <extension
> <objectContribution
> adaptable="true"
> <action
> enablesFor="1"
> </action>
> </extension>
> TDS Group
> > Hi,
> the
the
> > thanks,
> > -Anou
> [snip]
Previous Topic:How to Register Adapters permanently
Next Topic:M2 - Absent line number information
Current Time: Wed Oct 22 22:43:21 EDT 2025
Powered by FUDForum. Page generated in 0.03176 seconds
