Home » Newcomers » Newcomers » Debugging java class files from ANT build
Debugging java class files from ANT build [message #82742] Sun, 03 July 2005 06:29 Go to next message
Is there a way to use the Eclipse debugging features if an
application has been launched from an Ant build file?
Re: Debugging java class files from ANT build [message #82755 is a reply to message #82742] Sun, 03 July 2005 12:24 Go to previous messageGo to next message
Yes: set the VM arguments for the Ant build (or any Java application) to
include:
-Xdebug -Xnoagent -Djava.compiler=NONE -Xrunjdwp:transport=dt_socket,server=y,suspend=y,address=800 0
Then set up a remote Java application debug session to drive the debugging
of the execution of the program
HTH
Darins
"Martin Holmes" <martincanbe@hotmail.com> wrote in message
news:da8elh$ndc$1@news.eclipse.org...
> Hello,
> Thanks
Re: Debugging java class files from ANT build [message #82784 is a reply to message #82755] Sun, 03 July 2005 14:11 Go to previous message
Thanks that worked with ease,
Is it just a easy to debug and Applet running in a browser?
Martin
"Darin Swanson" <Darin_Swanson@us.ibm.com> wrote in message
news:da93ed$987$1@news.eclipse.org...
> include:
> HTH
> Darins
>> Hello,
>> Thanks
Previous Topic:Open Index.html in IE in Eclipse Help
Next Topic:Property file editor
Current Time: Thu Nov 20 14:23:59 EST 2025
Powered by FUDForum. Page generated in 0.08875 seconds
