Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » Same named element in 2 different xsd
Same named element in 2 different xsd [message #82580] Tue, 08 May 2007 10:35 Go to next message
Hi Martin,
I have the same named element "ParentTree" in 2 different xsds eg
navigation.xsd and topology.xsd. Navigation.xsd reference topology.xsd. So
when I try a datastore.initialize, teneo finds the same eClass in
"ParentTree" in navigation and topology. Is there a way around this? Can I
redirect one of the ParentTree to point to a different table in the
database without explicitly changing the xsd?
Julia
Re: Same named element in 2 different xsd [message #82628 is a reply to message #82580] Tue, 08 May 2007 14:39 Go to previous messageGo to next message
Hi Julia,
If the problem is that both eclasses are stored in the same table then you can use an
@Table(name="myname") annotation on the eclass to control were it is stored. You can set this
annotation in the xsd, the ecore or in a separate xml file.
See here for some extra info:
http://www.elver.org/jpox/ejb3_features.html
http://www.elver.org/jpox/ejb3_format.html
http://www.elver.org/jpox/ejb3_examples.html
gr. Martin
Julia wrote:
> Hi Martin,
> So when I try a datastore.initialize, teneo finds the same eClass in
> I redirect one of the ParentTree to point to a different table in the
> Julia
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: Same named element in 2 different xsd [message #82639 is a reply to message #82628] Tue, 08 May 2007 17:34 Go to previous messageGo to next message
Hi Martin,
Actually, it's the same named element and structure in both xsds but will
hold different data. Would I not need 2 different tables in the datastore?
Would changing the table="ParentTree" to table="ParentTree_nav" in
package.jdo for one of the xsds work? It's probably a hack :-). Would
following the links you provided work in this case?
Julia
Re: Same named element in 2 different xsd [message #82649 is a reply to message #82639] Wed, 09 May 2007 01:03 Go to previous messageGo to next message
Hi Julia,
I would assume that they are conceptually different (as they are modelled each as their own type).
So in this case they would need different tables.
To solve the duplicate eclass name issue (when generating the jdo file) the best is to set the
following property
PersistenceOptions.QUALIFY_ENTITY_NAME
to
PersistenceOptions.QUALIFY_ENTITY_NAME_NSPREFIX);
This property must be set to generate the jdo file. However passing properties can not be done for
the right-click menu-generate-jdo option. You have to generate the jdo file programmatically. This
is not difficult, just make a class with a static main method in your model project and call the
following method:
JpoxHelper.INSTANCE.generateMapping(your_epackages, options)
this will return the jdo file.
gr. Martin
Julia wrote:
> Hi Martin,
> will hold different data. Would I not need 2 different tables in the
> datastore? Would changing the table="ParentTree" to
> table="ParentTree_nav" in package.jdo for one of the xsds work? It's
> probably a hack :-). Would following the links you provided work in this
> case?
> Julia
The Netherlands
Re: Same named element in 2 different xsd [message #82700 is a reply to message #82649] Wed, 09 May 2007 08:17 Go to previous message
Hi Martin,
May be at some stage teneo can implement some extension point so that
one can set these options in Window -> Preferences... for teneo.
Parvez
Martin Taal wrote:
> Hi Julia,
> the best is to set the following property
> to
> properties can not be done for the right-click menu-generate-jdo option.
> You have to generate the jdo file programmatically. This is not
> project and call the following method:
> gr. Martin
> Julia wrote:
>> Hi Martin,
>> this case?
>> Julia
Re: Same named element in 2 different xsd [message #606632 is a reply to message #82580] Tue, 08 May 2007 14:39 Go to previous message
Hi Julia,
gr. Martin
Julia wrote:
> Hi Martin,
> Julia
The Netherlands
Re: Same named element in 2 different xsd [message #606633 is a reply to message #82628] Tue, 08 May 2007 17:34 Go to previous message
Hi Martin,
Julia
Re: Same named element in 2 different xsd [message #606634 is a reply to message #82639] Wed, 09 May 2007 01:03 Go to previous message
Hi Julia,
following property
to
following method:
gr. Martin
Julia wrote:
> Hi Martin,
> case?
> Julia
The Netherlands
Re: Same named element in 2 different xsd [message #606639 is a reply to message #82649] Wed, 09 May 2007 08:17 Go to previous message
Hi Martin,
Parvez
Martin Taal wrote:
> Hi Julia,
> to
> gr. Martin
> Julia wrote:
>> Hi Martin,
>> this case?
>> Julia
Previous Topic:Restrict copy/paste for some elemets
Next Topic:HbDataStore.close() throwing SQLException
Current Time: Mon Jul 21 21:10:50 EDT 2025
Powered by FUDForum. Page generated in 0.26054 seconds
