Opening JSP "deadlocks" Eclipse [message #82514] |
Fri, 11 March 2005 09:54  |
maybe it is not an Eclipse problem, but a "too-less-hardware" error, but
let's see.
I've a JSP project with about 500 JSPs and 500 Java classes. Some pages
and classes are very very large (about 2000 - 5000 lines per page or class).
Unfortunaltely I've only a 800 MHz AMD with 640 MB RAM.
I installed the latestes milestone from eclipse and WTP.
Sometimes when I open very large JSP pages (only then) eclipse grabs all
processor time and works forever, not responding anymore. Then I've to
kill the process.
Tomcat instead compiles these large JSPs in about 2-3 seconds.
Do you think this is an eclipse/WTP problem, or is my machine to old?
Oli
Re: Opening JSP "deadlocks" Eclipse [message #82738 is a reply to message #82514] |
Fri, 11 March 2005 11:23   |
Originally posted by: pavery.us.ibm.com
Hi Oli,
It's hard to tell what's going on w/out more details.
(but I doubt it's that your machine is too old =)
A couple things you can do to help debug are:
- open the progress view
(window > show view > other... > basic > progress)
and in that view also enable showing system jobs (should be under the
little arrow on the toolbar for the view: preferences > show sleeping
and system tasks)
with this view open you might be able to see which
builders/validators/system background jobs are "stuck".
- next time you encounter a deadlock, if you are running the workbench
w/ the "-consolelog" option, from the console you can press
ctrl + break to get a memory dump (this will save to your "eclipse"
directory), and you can see what was going on in each thread when the
workbench was stuck.
That should help narrow down where the problem is.
-phil
Oli Glimmer wrote:
> let's see.
> class).
> kill the process.
> Oli
Re: Opening JSP "deadlocks" Eclipse [message #83316 is a reply to message #82738] |
Mon, 14 March 2005 07:27   |
--------------050906050904080607060804
I was able to get a better machine. Now it is a Pentium 4 - 2GHz with
512 MB RAM.
But the problem persists.
I turned "progress" on and there are only 2 items shown, when eclipse
goes into "work-forever".
That is "Update Process" and "Compacting memory (Sleeping)".
I also dumped the memory, but if I see that correctly, there are only
"waiting" threads. I attachted a text file with that dump.
Any ideas?
Oli
phil avery schrieb:
> Hi Oli,
> and system tasks)
> -phil
> Oli Glimmer wrote:
>> but let's see.
>> pages and classes are very very large (about 2000 - 5000 lines per
>> page or class).
>> all processor time and works forever, not responding anymore. Then
>> I've to kill the process.
>> Regards,
>> Oli
name="dump"
Content-Disposition: inline;
filename="dump"
Full thread dump Java HotSpot(TM) Client VM (1.5.0-b64 mixed mode):
"Worker-4" daemon prio=5 tid=0x0c0abb00 nid=0xc54 in Object.wait() [0x0c97f000..0x0c97fc68]
at java.lang.Object.wait(Native Method)
- waiting on <0x032b5548> (a org.eclipse.core.internal.jobs.WorkerPool)
at org.eclipse.core.internal.jobs.WorkerPool.sleep(WorkerPool.j ava:167)
- locked <0x032b5548> (a org.eclipse.core.internal.jobs.WorkerPool)
at org.eclipse.core.internal.jobs.WorkerPool.startJob(WorkerPoo l.java:199)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:60)
"org.eclipse.jdt.internal.ui.text.JavaReconciler" daemon prio=2 tid=0x0aec6558 nid=0x8b4 in Object.wait() [0x0c54f000..0x0c54fb68]
- waiting on <0x03b9ce90> (a org.eclipse.jface.text.reconciler.DirtyRegionQueue)
at org.eclipse.jface.text.reconciler.AbstractReconciler$Backgro undThread.run(AbstractReconciler.java:176)
- locked <0x03b9ce90> (a org.eclipse.jface.text.reconciler.DirtyRegionQueue)
"Java indexing" daemon prio=4 tid=0x0aefbe30 nid=0x464 in Object.wait() [0x0bcff000..0x0bcffbe8]
- waiting on <0x03a52ba0> (a org.eclipse.jdt.internal.core.search.indexing.IndexManager)
at java.lang.Object.wait(Unknown Source)
at org.eclipse.jdt.internal.core.search.processing.JobManager.r un(JobManager.java:345)
- locked <0x03a52ba0> (a org.eclipse.jdt.internal.core.search.indexing.IndexManager)
at java.lang.Thread.run(Unknown Source)
"Reference Cleaner: 1" prio=7 tid=0x0ae488e8 nid=0x924 in Object.wait() [0x0bbdf000..0x0bbdfc68]
- waiting on <0x039dc6f8> (a java.lang.ref.ReferenceQueue$Lock)
at java.lang.ref.ReferenceQueue.remove(Unknown Source)
- locked <0x039dc6f8> (a java.lang.ref.ReferenceQueue$Lock)
at org.eclipse.jface.resource.ImageCache$ReferenceCleanerThread .run(ImageCache.java:424)
"Worker-0" daemon prio=5 tid=0x0ac6ab18 nid=0xe10 in Object.wait() [0x0b34f000..0x0b34f9e8]
"Start Level Event Dispatcher" daemon prio=5 tid=0x0ae98810 nid=0xce4 in Object.wait() [0x0b2cf000..0x0b2cfb68]
- waiting on <0x02ff1aa0> (a org.eclipse.osgi.framework.eventmgr.EventThread)
at org.eclipse.osgi.framework.eventmgr.EventThread.getNextEvent (EventThread.java:162)
- locked <0x02ff1aa0> (a org.eclipse.osgi.framework.eventmgr.EventThread)
at org.eclipse.osgi.framework.eventmgr.EventThread.run(EventThr ead.java:100)
"Framework Event Dispatcher" daemon prio=5 tid=0x0ac981c8 nid=0x398 in Object.wait() [0x0b28f000..0x0b28fbe8]
- waiting on <0x02fd9bc8> (a org.eclipse.osgi.framework.eventmgr.EventThread)
- locked <0x02fd9bc8> (a org.eclipse.osgi.framework.eventmgr.EventThread)
"Low Memory Detector" daemon prio=5 tid=0x00a91298 nid=0xa64 runnable [0x00000000..0x00000000]
"CompilerThread0" daemon prio=10 tid=0x00a8fe70 nid=0x978 waiting on condition [0x00000000..0x0abcf6c0]
"Signal Dispatcher" daemon prio=10 tid=0x00a8f1f8 nid=0x810 waiting on condition [0x00000000..0x00000000]
"Finalizer" daemon prio=9 tid=0x00a866e8 nid=0xdf0 in Object.wait() [0x0ab4f000..0x0ab4fa68]
- waiting on <0x02fc4768> (a java.lang.ref.ReferenceQueue$Lock)
- locked <0x02fc4768> (a java.lang.ref.ReferenceQueue$Lock)
at java.lang.ref.Finalizer$FinalizerThread.run(Unknown Source)
"Reference Handler" daemon prio=10 tid=0x00a85258 nid=0x104 in Object.wait() [0x0ab0f000..0x0ab0fae8]
- waiting on <0x02fc47e8> (a java.lang.ref.Reference$Lock)
at java.lang.ref.Reference$ReferenceHandler.run(Unknown Source)
- locked <0x02fc47e8> (a java.lang.ref.Reference$Lock)
"main" prio=7 tid=0x00034e40 nid=0xde0 runnable [0x0007e000..0x0007fc40]
at org.eclipse.swt.widgets.Scrollable.getClientArea(Scrollable. java:151)
at org.eclipse.swt.custom.StyledText.getPartialBottomIndex(Styl edText.java:3991)
at org.eclipse.swt.custom.DisplayRenderer.updateTopIndex(Displa yRenderer.java:242)
at org.eclipse.swt.custom.DisplayRenderer.createTextLayout(Disp layRenderer.java:219)
at org.eclipse.swt.custom.StyledTextRenderer.getTextLayout(Styl edTextRenderer.java:409)
at org.eclipse.swt.custom.StyledText.redrawLines(StyledText.jav a:5958)
at org.eclipse.swt.custom.StyledText.internalRedrawRange(Styled Text.java:4884)
at org.eclipse.swt.custom.StyledText.redrawRange(StyledText.jav a:6084)
at org.eclipse.jface.text.source.AnnotationPainter$SquigglesStr ategy.draw(AnnotationPainter.java:107)
at org.eclipse.jface.text.source.AnnotationPainter.handleDrawRe quest(AnnotationPainter.java:1231)
at org.eclipse.jface.text.source.AnnotationPainter.disablePaint ing(AnnotationPainter.java:369)
at org.eclipse.jface.text.source.AnnotationPainter.updatePainti ng(AnnotationPainter.java:782)
at org.eclipse.jface.text.source.AnnotationPainter.access$1(Ann otationPainter.java:781)
at org.eclipse.jface.text.source.AnnotationPainter$1.run(Annota tionPainter.java:909)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:3 5)
at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchr onizer.java:118)
- locked <0x04aed5b8> (a org.eclipse.swt.widgets.RunnableLock)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.jav a:2885)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2544)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1612)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1578)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:293)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:144)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:102)
at org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:228)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:333)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:150)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:268 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:260)
at org.eclipse.core.launcher.Main.run(Main.java:887)
at org.eclipse.core.launcher.Main.main(Main.java:871)
"VM Thread" prio=10 tid=0x00a81110 nid=0x4bc runnable
"VM Periodic Task Thread" prio=10 tid=0x00a92470 nid=0x98c waiting on condition
--------------050906050904080607060804--
Re: Opening JSP "deadlocks" Eclipse [message #83590 is a reply to message #83316] |
Mon, 14 March 2005 15:36  |
> Any ideas?
I would suggest opening a bug, and attaching your dumps to that.
I noticed in your dumps, you are using Java 1.5? So, in the trial-and-error style
of debugging, you might try 1.4.2 or so, and see if makes a difference (if
so, might be a JIT bug).
Also, when you get your dumps, I assume from ctrl-break in console window,
you might take a couple of them, several seconds apart. This will help determine
if there is literally "no movement" or if somethings happening and its just really,
really slow (like an infinite loop, or near infinite loop).
Thanks.
FUDForum. Page generated in 0.05094 seconds
