Home » Eclipse Projects » Subversive » "Premature end of file" error when using some clients
"Premature end of file" error when using some clients [message #7381] |
Fri, 25 May 2007 18:24  |
Since the Forum is *raging* with spams, I had to post this here to get help.
When I use the SVNKit client or the Subclipse default JAVA SVN client I
I get an error connecting to any repository (screenshot linked below).
When I switch to Native JavaHL, everything works ok.
http://picasaweb.google.com/dmondark/Public/photo#5065713818 188004738
Now when right clicking on the errors and selecting details->Advanced, I
get the following:
PROPFIND request failed on '/wordpress'
Processing PROPFIND request response failed: Premature end of file.
(/wordpress)
The versions (Clean installations):
PDT: 0.7 RC3
Subversive: 1.1.2
JAVA SVN: 1.0.4
SVNKit:1.1.1
Native JavaHL: 1.4.3
Any idea why is this happening??
Ali
Re: "Premature end of file" error when using some clients [message #7455 is a reply to message #7433] |
Fri, 08 June 2007 09:09   |
Hi Igor,
Thank you for responding.
I am not sure what are the versions of the SVN servers, the issue occurs
on all of the 3 repositories I tried: Wordpress, Joomla development and
Lifetype.
The problem is almost consistent. The behavior looked much like a
network issue at first. What made me not consider that is that it never
happens when using Native JavaHL, and I am not behind a firewall other
than my own software one, in which I made sure java and javaw is allowed
to traffic in/out.
I am running subversive on a clean all-in-one PDT installation.
I am not sure what more information is needed here..Please let me know
if any further details is needed.
Thank you for your help.
Ali
Igor Vinnykov wrote:
> Hello Ali,
> Thank you for the report. What version of SVN do you try to connect? Could
> you please also inform us about any specific in your environment and
> repository, because the problem is pretty unusual.
> Best regards,
> Igor Vinnykov
> "Ali B." <dmondark@gmail.com> ???????/???????? ? ???????? ?????????:
> news:f37nl0$bj9$1@build.eclipse.org...
>> help.
>> When I use the SVNKit client or the Subclipse default JAVA SVN client I I
>> get an error connecting to any repository (screenshot linked below). When
>> get the following:
>> Quote:
>> (/wordpress)
>> PDT: 0.7 RC3
>> Subversive: 1.1.2
>> JAVA SVN: 1.0.4
>> SVNKit:1.1.1
>> Cheers,
>> Ali
Re: "Premature end of file" error when using some clients [message #7466 is a reply to message #7455] |
Mon, 18 June 2007 09:28   |
Hello Ali,
The only thing we can suppose here is the porblem with JavaSVN/SVNKit. We
will forward information about that problem to TMate, which is author of
JavaSVN and SVNKit.
Igor Vinnykov
news:f4bka5$oc1$1@build.eclipse.org...
> Hi Igor,
> Lifetype.
> The problem is almost consistent. The behavior looked much like a network
> issue at first. What made me not consider that is that it never happens
> when using Native JavaHL, and I am not behind a firewall other than my own
> software one, in which I made sure java and javaw is allowed to traffic
> in/out.
> I am not sure what more information is needed here..Please let me know if
> Cheers,
> Ali
>> Hello Ali,
>> Could you please also inform us about any specific in your environment
>> and repository, because the problem is pretty unusual.
>> Best regards,
>> Igor Vinnykov
>>> help.
>>> get the following:
>>> Quote:
>>> (/wordpress)
>>> PDT: 0.7 RC3
>>> Subversive: 1.1.2
>>> JAVA SVN: 1.0.4
>>> SVNKit:1.1.1
>>> Cheers,
>>> Ali
Re: "Premature end of file" error when using some clients [message #8379 is a reply to message #7466] |
Fri, 20 July 2007 19:11  |
Hello Igor,
Forgive me for this reply my be a *little* late ;)
Thank you for checking on the issue, I just wanted to ask if any of
those two have pros over the Native JavaHL? The latter is working great
for me, I wouldn't mind if it is not slower or less functionality.
Ali
> Hello Ali,
> JavaSVN and SVNKit.
> Best regards,
> Igor Vinnykov
>> Hi Igor,
>> Lifetype.
>> in/out.
>> Cheers,
>> Ali
>>> Hello Ali,
>>> Best regards,
>>> Igor Vinnykov
>>>> help.
>>>> get the following:
>>>> Quote:
>>>> (/wordpress)
>>>> PDT: 0.7 RC3
>>>> Subversive: 1.1.2
>>>> JAVA SVN: 1.0.4
>>>> SVNKit:1.1.1
>>>> Cheers,
>>>> Ali
Current Time: Sat Jul 12 20:05:08 EDT 2025
Powered by FUDForum. Page generated in 0.03527 seconds
