Home » Archived » M2M (model-to-model transformation) » [ATL] Adding elements to collections
[ATL] Adding elements to collections [message #82004] Thu, 22 May 2008 02:37 Go to next message
I'm almost sure this is a well documented issue somewhere, but I just
can't find it :(
I'm trying to write this matched rule:
rule Activity2Step{
from
activity : BPMN!Activity
using{
container : BPMN!Graph = activity.refImmediateComposite();
to
step : IM!Step
do{
if (container.oclIsTypeOf(BPMN!SubProcess)){
container.graph.vertices <-
container.graph.vertices->including(activity);
Long story short, there's this already existent collection called
'vertices' which I access with container.graph.vertices, and I want to add
an element to it. I know using including per se won't help, since these
collection operations don't really modify the collection. So I tried what
you're seeing, assigning the result of the including operation to the same
collection, but I get:
SEVERE: cannot set feature bpmn!Pool.vertices to value
org.eclipse.emf.ecore.impl.DynamicEObjectImpl@cc05a6 (eClass:
org.eclipse.emf.ecore.impl.EClassImpl@14a3622 (name: Activity)
(instanceClassName: null) (abstract: false, interface: false))
If you could point me in the right direction, I'd be extremely thankful.
-Juan
Re: [ATL] Adding elements to collections [message #82212 is a reply to message #82004] Mon, 26 May 2008 13:16 Go to previous messageGo to next message
As I've been doing some research on the topic, I found the following
thread:
http://dev.eclipse.org/newslists/news.eclipse.modeling.m2m/m sg01764.html
Apparently for this user, it did work adding elements to the collection,
however his issue was concerning the order of the elements. At the end of
the discussion they mentioned that they would change this after the user
filed a bug. Can you comment on this? I haven't found anything else :(
Re: [ATL] Adding elements to collections [message #82283 is a reply to message #82212] Mon, 26 May 2008 19:42 Go to previous messageGo to next message
Originally posted by: freddy.allilaire.univ-nantes.fr
--------------010403080104010609050108
Hi Juan,
I'm not sure to clearly understand what you want to do.
But I think the third code snippet in the following document may help
you:
http://www.eclipse.org/m2m/atl/basicExamples_Patterns/articl e.php?file=SideEffect/index.html
There is an example with the "nameToAssignHistory" collection populated
in imperative section.
HTH.
Freddy.
OBEO
Juan Cadavid a
Re: [ATL] Adding elements to collections [message #83088 is a reply to message #82283] Fri, 30 May 2008 23:12 Go to previous message
Thanks a lot Freddy! They sure are helpful. I don't know how could I have
missed them before ;_)
Previous Topic:[ATL]: Value from Stereotype's Property
Next Topic:[ATL] how to get the parent's name in UML
Current Time: Tue Nov 11 17:05:25 EST 2025
Powered by FUDForum. Page generated in 0.03844 seconds
