GLA RT [message #7304] |
Sat, 26 February 2005 06:41  |
Originally posted by: mujtaba.alsaif.brunel.ac.uk
good morning,
i managed to get throught to the gla.bat but when run, all it displays is
the the libraries used to read and provessthe GLA adapter file,
this is the execution from the command prompt
D:\eclipse-SDK-3.1M4-win32\bin>gla
"D:\eclipse-SDK-3.1M4-win32\eclipse\workspace
\Adapters and GLAs\adapter.adapter"
D:\eclipse-SDK-3.1M4-win32\bin>SET JAVA_HOME=C:\Program Files\IBM\Java142\jre
D:\eclipse-SDK-3.1M4-win32\bin>SET GLA_HOME=D:\eclipse-SDK-3.1M4-win32
D:\eclipse-SDK-3.1M4-win32\bin>"C:\Program Files\IBM\Java142\jre\bin\java"
-clas
spath
" D:\eclipse-SDK-3.1M4-win32\lib\hparse.jar;D:\eclipse-SDK-3.1 M4-win32\lib\
glaconfigs.jar;D:\eclipse-SDK-3.1M4-win32\lib\hglaconfig.jar ;D:\eclipse-SDK-3.1M
4-win32\lib\logparsers.jar;D:\eclipse-SDK-3.1M4-win32\lib\hg la.jar;D:\eclipse-SD
K-3.1M4-win32\lib\hexr.jar;D:\eclipse-SDK-3.1M4-win32\lib\hl cbe101.jar;D:\eclips
e-SDK-3.1M4-win32\lib\ecore.jar;D:\eclipse-SDK-3.1M4-win32\l ib\common.jar;D:\ecl
ipse-SDK-3.1M4-win32\lib\hlcore.jar"
org.eclipse.hyades.logging.adapter.Adapter
-ac ""D:\eclipse-SDK-3.1M4-win32\eclipse\workspace\Adapters and
GLAs\adapter.ada
pter"" -cc ""D:\eclipse-SDK-3.1M4-win32\eclipse\workspace\Adapters and
GLAs\adap
ter.adapter""
Command line usage: Adapter [-cc ContextConfiguration.xml] [-ac
ComponentConfigu
rations.xml]
is this supposed to happen?
any recommendations?
mujtaba
Re: GLA RT [message #8162 is a reply to message #7977] |
Tue, 01 March 2005 12:56  |
Hi Mujtaba,
By way of an update on bullet #2, this defect is invalid for two
reasons:
1) This script file is not in the TPTP project.
2) The problem was due to an ill configured adapter file (e.g. directory
property was set to the current directory, or '.').
I have since closed https://bugs.eclipse.org/bugs/show_bug.cgi?id=86758.
Paul
"Paul Slauenwhite" <paules@ca.ibm.com> wrote in message
news:cvqldh$573$1@www.eclipse.org...
> Hi Mujtaba,
> In short, your command should work after looking at the current code.
> This output is generated when part of the ac/cc is missing or erroneous.
> Fortunately, your command appears to be fine. I tested you command using
> the latest Haydes v3.2 driver and everything works fine when adding the
> following to the gla.bat:
> 1) The -DGLA_HOME="%GLA_HOME%" JVM parameter:
> java -DGLA_HOME="%GLA_HOME%" -classpath ...
> 2) PUSHD/POPD calls to the directory containing the adapter file
> before/after the java.exe call.
> I have opened Hyades defect
> https://bugs.eclipse.org/bugs/show_bug.cgi?id=86758 for #2 above.
> Paul
> "mujtaba alsaif" <mujtaba.alsaif@brunel.ac.uk> wrote in message
> news:cvpn8u$c8u$1@www.eclipse.org...
> > good morning,
is
> > az
> > -clas
> > spath
> 3.1M
> e-SD
> lips
> \ecl
> > GLAs\adapter.ada
> > GLAs\adap
> > ter.adapter""
> > ComponentConfigu
> > rations.xml]
> > mujtaba
FUDForum. Page generated in 0.09204 seconds
