Home » Archived » Test and Performance Tools Platform (TPTP) » Trouble Testing plugins
Trouble Testing plugins [message #81608] Wed, 23 August 2006 17:48 Go to next message
I've copied all my plugins from the build dir to a separate Eclipse
installation that I set up for testing. I've also created an Artifact,
a Location, eployment, launch configuration, etc that is needed to run
the test in Standard mode. For the location, I've defined a
ECLIPSE_STARTUP_PATH to point to the startup.jar file of my plugin
(which is in a separate build directory). I'm not sure exactly if I'm
doing the right thing here... (do we need to copy the startup.jar file
from app somewhere too?), but everything seems fine, and launches my
perspective, except for some major problems.
The application is launched, but the progress window stops at around 60%
(Launching) and finally times out with
org.eclipse.hyades.internal.execution.local.control.Inactive ProcessException.
It also dosent have the welcome perspective that its supposed to
display. This welcome perspective had a button for login in as well as
a menu item. However, the login menu item appears correctly. Third
problem I have is that when the login is selected, it brings up my login
dialog, but I try to login, it can't login to the server as it seems to
wait forever. Any ideas as to what could be the problem? I'm using
Windows and Eclipse 3.2 with TPTP from callisto
Mahesh
Re: Trouble Testing plugins [message #81678 is a reply to message #81608] Thu, 24 August 2006 11:11 Go to previous message
You don't need an artifact, location, and a deployment file if you're
launching locally on your machine.
Under the overview page of the test suite, you can specify the startup.jar
file that should be used as the context for your test suite. Give that a
try to see if things work.
It's also important to realize that you need the AGR plug-in (along with its
dependecies) installed under the Eclipse workbench that you use for your
context.
"Mahesh Sooriarachchi" <msoori@hotmail.com> wrote in message
news:eciif3$vnj$1@utils.eclipse.org...
> Thanks
> Mahesh
Previous Topic:Testing an Eclipse plugin with AGR
Next Topic:Trouble getting started
Current Time: Thu Nov 27 13:36:27 EST 2025
Powered by FUDForum. Page generated in 0.07293 seconds
