Home » Archived » Test and Performance Tools Platform (TPTP) » Trouble getting started
Trouble getting started [message #81576] Wed, 23 August 2006 15:05 Go to next message
Originally posted by: akarypid.yahoo.gr
Hi all,
I keep getting the following message when I try to follow to use TPT:
"Error occurred during initialization of VM
Could not find agent library on the library path or in the local directory:
piAgent"
I've located such a library on my system at:
/opt/eclipse-sdk-3.2/eclipse/plugins/org.eclipse.hyades.exec ution.linux.x86_4.2.0.v200606131519/libpiAgent.so
I've put that in the -Djava.library.path option to the VM and also set
LD_LIBRARY_PATH accordingly, but the problem persists.
I'm on a Linux system using the Sun 1.5.0.06 JDK and Eclipse 3.2 with TPT
4.2.0.
Alexandros Karypidis
Re: Trouble getting started [message #81593 is a reply to message #81576] Wed, 23 August 2006 16:49 Go to previous messageGo to next message
Alexandros Karypidis wrote:
> Hi all,
> piAgent"
> 4.2.0.
If you've gone to that much trouble to see that the piAgent is "visible"
and you're still having the question, I'd have to ask if we're dealing
with a 32-bit vs. 64-bit issue here... are you on a 64-bit system? If
so, is the Sun JVM you downloaded a 64-bit one or a 32-bit one?
RDS
Randy D. Smith randy (dot) d (dot) smith (at) intel (dot) com
Eclipse TPTP Committer, Platform Proj (data collection/agent controller)
Re: Trouble getting started [message #81775 is a reply to message #81593] Sun, 27 August 2006 04:36 Go to previous message
>> Hi all,
>> directory: piAgent"
>> 4.2.0.
Sorry for the late reply... I've looked into it some more and solved the
problem. I noticed that "ldd libpiAgent.so" reported that I was missing the
standard C libraries that the agent was compiled against
(libstdc++-libc6.2-2.so.3). These are provided by the package "lib-compat"
on my system (a Gentoo box). Installing the libraries solved the problem.
Previous Topic:Trouble Testing plugins
Next Topic:Downloading problem, pls help
Current Time: Sun Nov 23 11:46:53 EST 2025
Powered by FUDForum. Page generated in 0.03064 seconds
