Home » Language IDEs » Java Development Tools (JDT) » Problem with startup
Problem with startup [message #81376] Tue, 29 July 2003 20:42
Originally posted by: fstruwig.msn.com
Greetings.
I'm using win2000 with eclipse v.2.1.
When I attempt to run eclipse, a logfile is created, and the process is
stopped.
Any ideas would be appreciated.
The logfile follows:
!SESSION Jul 19, 2003
08:48:49.734 ---------------------------------------------
java.version=1.4.1_02
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=en_ZA
Command-line arguments: -os win32 -ws win32 -arch x86 -install
file:C:/Documents and Settings/Entertainer/My
Documents/Franz/programming/eclipse/eclipse-SDK-2.1.1-win32/ eclipse/
!ENTRY org.eclipse.jdt.debug.ui 4 150 Jul 19, 2003 08:48:49.750
!MESSAGE Internal Error
!STACK 0
java.lang.reflect.InvocationTargetException
at org.eclipse.jface.operation.ModalContext.run(ModalContext.ja va:283)
org.eclipse.jface.dialogs.ProgressMonitorDialog.run(Progress MonitorDialog.ja
va:357)
org.eclipse.jdt.internal.debug.ui.launcher.VMPreferencePage. search(VMPrefere
ncePage.java:624)
org.eclipse.jdt.internal.debug.ui.launcher.VMPreferencePage$ 8.handleEvent(VM
PreferencePage.java:316)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :81)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:840)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:1838)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :1545)
at org.eclipse.jface.window.Window.runEventLoop(Window.java:583 )
at org.eclipse.jface.window.Window.open(Window.java:563)
org.eclipse.ui.internal.OpenPreferencesAction.run(OpenPrefer encesAction.java
:53)
at org.eclipse.jface.action.Action.runWithEvent(Action.java:842 )
org.eclipse.jface.action.ActionContributionItem.handleWidget Selection(Action
ContributionItem.java:456)
org.eclipse.jface.action.ActionContributionItem.handleWidget Event(ActionCont
ributionItem.java:403)
org.eclipse.jface.action.ActionContributionItem.access$0(Act ionContributionI
tem.java:397)
org.eclipse.jface.action.ActionContributionItem$ActionListen er.handleEvent(A
ctionContributionItem.java:72)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1402)
at org.eclipse.ui.internal.Workbench.run(Workbench.java:1385)
org.eclipse.core.internal.boot.InternalBootLoader.run(Intern alBootLoader.jav
a:858)
at org.eclipse.core.boot.BootLoader.run(BootLoader.java:461)
sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAcce ssorImpl.java:39
sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMe thodAccessorImpl
..java:25)
at org.eclipse.core.launcher.Main.basicRun(Main.java:291)
at org.eclipse.core.launcher.Main.run(Main.java:747)
at org.eclipse.core.launcher.Main.main(Main.java:583)
Caused by: java.lang.NullPointerException
ncePage.java:690)
ncePage.java:727)
org.eclipse.jdt.internal.debug.ui.launcher.VMPreferencePage$ 12.run(VMPrefere
ncePage.java:618)
org.eclipse.jface.operation.ModalContext$ModalContextThread. run(ModalContext
..java:101)
Re: Problem with startup [message #81597 is a reply to message #81376] Tue, 29 July 2003 16:49 Go to previous message
Originally posted by: amanaval.sybase.com
Do you have your JDK installed ?
-Anou
"kingpin" <fstruwig@msn.com> wrote in message
news:bg611i$a2p$1@eclipse.org...
> Greetings.
> stopped.
> !STACK 0
> at
> va:357)
> at
> ncePage.java:624)
> at
> at
> :53)
> at
> at
> at
> tem.java:397)
> at
> at
> a:858)
> at
> at
> .java:25)
> at
> ncePage.java:690)
> at
> ncePage.java:727)
> at
> ncePage.java:618)
> at
> .java:101)
Previous Topic:Project Build Performance degrades over time.
Next Topic:Eclipse Profiler Plugin
Current Time: Fri Jul 18 22:34:29 EDT 2025
Powered by FUDForum. Page generated in 0.03676 seconds
