Home » Language IDEs » Java Development Tools (JDT) » Display other Files than .java files in java browsing perspective?
Display other Files than .java files in java browsing perspective? [message #81272] Tue, 29 July 2003 08:49 Go to next message
Originally posted by: m.bauer.signsoft.com
my question is like I wrote in topic.
Is there a possibility to dispaly other files than .java-files in this view?
I put some xml-files beside my java-files (the java-files depend on the
xml-files) so I want them to be displayed with the corresponding java-file.
Thanks in advance
Michael Bauer
Re: Display other Files than .java files in java browsing perspective? [message #81287 is a reply to message #81272] Tue, 29 July 2003 08:57 Go to previous messageGo to next message
Originally posted by: daniel.megert.gmx.net
Michael Bauer wrote:
>Hi,
You can either open the file directly using Navigate > Open Resource...
(Ctrl+Shift+R) or what I do: replace the Projects view with the Package
Explorer and filter away Java elements. If you like that setup you can
save it as your Java Browsing perspective layout.
HTH
Dani
Re: Display other Files than .java files in java browsing perspective? [message #81302 is a reply to message #81272] Tue, 29 July 2003 09:02 Go to previous messageGo to next message
Hi Michael,
I don't think that the Views in the browsing perspective support other
file types. But you can customize the perspective.
What you need is the 'Package Explorer' - View.
Open the Package Explorer with Window->Show View->Package Explorer (if
it doesn't appears go to 'Other'.
Drag&Drop the Package Explorer to the Projects-View so that this area
has taps now.
Close the Projects-View and save the perspective with Window->Save
Perspective As...
Michael
> Thanks in advance
> Michael Bauer
Re: Display other Files than .java files in java browsing perspective? [message #81447 is a reply to message #81302] Tue, 29 July 2003 11:51 Go to previous messageGo to next message
Originally posted by: richkulp.NOSPAM.us.ibm.com
I do the same thing each time I create a new workspace. :-)
To tell you the truth the Package Explorer is much more useful than the
Projects view. It should be made the default for Java Browsing instead
of the Projects view.
Michael Täge wrote:
> Hi Michael,
> has taps now.
> Perspective As...
> Regards
> Michael
>> view?
>> java-file.
>> Thanks in advance
>> Michael Bauer
Thanks, Rich Kulp
Re: Display other Files than .java files in java browsing perspective? [message #81461 is a reply to message #81447] Tue, 29 July 2003 12:07 Go to previous messageGo to next message
thanks for the numerous answers. But I need this to be done by a plugin, not
by the user. Is this possible?
Thanks in Advance
Michael
"Richard L. Kulp" <richkulp@NOSPAM.us.ibm.com> schrieb im Newsbeitrag
news:bg651f$ehp$2@eclipse.org...
> Michael T
Re: Display other Files than .java files in java browsing perspective? [message #81687 is a reply to message #81461] Wed, 30 July 2003 03:10 Go to previous message
>Hi,
Write a plug-in that provides its own perspective. Using Java Browsing
views but replaces Projects view with the Package Explorer.
Dani
>Thanks in Advance
>Michael
>>Michael Täge wrote:
>>>Hi Michael,
>>>has taps now.
>>>Perspective As...
>>>Regards
>>>Michael
>>>>Hi,
>>>>view?
>>>>java-file.
>>>>Thanks in advance
>>>>Michael Bauer
>>Thanks, Rich Kulp
Previous Topic:Eclipse Profiler Plugin
Next Topic:API for setting a project's javadoc location
Current Time: Sat Nov 08 16:02:52 EST 2025
Powered by FUDForum. Page generated in 0.04306 seconds
