Unable to Get Libary.Editor/TENEO working [message #81252] |
Wed, 25 April 2007 16:52  |
I got a quick response from Martin but thought I'd enter this in the
forum. We are trying to integrate our use of eCore with TENEO still
running on eclipse 3.2.2 and are running into an issue that it only
partially works. We are not able to get the editor to create new
libraries/writers/books but it will display the data stored in the
database through the execution of QuickStart. Our sympton is simply
the that the menu items are disabled so that the action can not be
taken. Our screen looks like the following:
[For some reason the screen shots are not coming through but it shows a
greyed out Writer and Book from "New Child"]
You can see that the data from QuickStart is behind the New Child but
the menu is disabled and doesn’t allow us to create anything within the
editor. There is one section of the HOW-TO that we could not reconcile.
It deals with the following documentation. In our editor we get the
following with seemingly no way to map what you show below;
[ditto]
It doesn’t see
org.eclipse.emf.teneo.hibernate.emf.resource.HibernateResour ceFactory of
type: library. Therefore our parser ends up being from the Context Menu
of the extension for a New -> Generic and looks like the following:
[ditto]
which does not match the documentation on the site which shows the
following screen shot.
Anybody had the same problem?
Re: Unable to Get Libary.Editor/TENEO working [message #81328 is a reply to message #81313] |
Thu, 26 April 2007 11:30  |
The maintenance version with nr. 0.7.5, a new build was published a few days ago.
gr. Martin
wxlund wrote:
> If we're using eclipse 3.2.2 which teneo plugin should we be using?
> Martin Taal wrote:
>> Yes the strange thing is that the node under the extension_parser is
>> not parser but generic. I am not sure if this is a teneo issue btw,
>> the extensions and the generated editor should all work also without
>> Teneo.
>> gr. Martin
>>> a greyed out Writer and Book from "New Child"]
>>> the editor. There is one section of the HOW-TO that we could not
>>> reconcile. It deals with the following documentation. In our editor
>>> we get the following with seemingly no way to map what you show below;
>>> [ditto]
>>> It doesn’t see
>>> of type: library. Therefore our parser ends up being from the
>>> Context Menu of the extension for a New -> Generic and looks like
>>> the following:
>>> [ditto]
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: Unable to Get Libary.Editor/TENEO working [message #605075 is a reply to message #81252] |
Wed, 25 April 2007 17:21  |
Yes the strange thing is that the node under the extension_parser is not parser but generic. I am
not sure if this is a teneo issue btw, the extensions and the generated editor should all work also
without Teneo.
gr. Martin
> [ditto]
> It doesn’t see
> [ditto]
The Netherlands
Re: Unable to Get Libary.Editor/TENEO working [message #605089 is a reply to message #81267] |
Thu, 26 April 2007 11:19  |
> parser but generic. I am not sure if this is a teneo issue btw, the
> extensions and the generated editor should all work also without Teneo.
> gr. Martin
>> [ditto]
>> It doesn’t see
>> of type: library. Therefore our parser ends up being from the Context
>> Menu of the extension for a New -> Generic and looks like the following:
>> [ditto]
Re: Unable to Get Libary.Editor/TENEO working [message #605094 is a reply to message #81313] |
gr. Martin
>> Teneo.
>> gr. Martin
>>> [ditto]
>>> It doesn’t see
>>> the following:
>>> [ditto]
The Netherlands
FUDForum. Page generated in 0.07303 seconds
