DataPool could not be loaded - urgent [message #80887] |
Wed, 16 August 2006 13:23  |
Originally posted by: mjayanthi.gmail.com
I have created a datapool in the text editor. I have the
testpool.datapool under my project directory under my workspace. This is
with Eclipse 3.2
I am getting the exception that the datapool could not be loaded. I have
put the required jar files in the classpath extensions as specified in
the help document.
I am getting the following exception
Exception in thread "main"
org.eclipse.hyades.execution.runtime.datapool.DatapoolExcept ion:
IWAT3056E Datapool could not be loaded from file
C:\DevTools\EclipseWTP1.5\workspace2\DPTest\test.datapool
org.eclipse.hyades.models.common.datapool.impl.Common_Datapo olFactoryImpl.loadForEdit(Common_DatapoolFactoryImpl.java:31 2)
org.eclipse.hyades.models.common.datapool.impl.Common_Datapo olFactoryImpl.load(Common_DatapoolFactoryImpl.java:439)
at TestDP.main(TestDP.java:26)
Example Code Snippet.
File dataFile = new
File(" C:\\DevTools\\EclipseWTP1.5\\workspace\\testproj\\TestPool.d atapool ");
IDatapoolFactory dpFactory = new Common_DatapoolFactoryImpl();
IDatapool datapool = dpFactory.load(dataFile,false);
Am I doing anything incorrect. The documentation says that we need to
provide the fully qualified path.
Can anyone please advise me on how to go about this issue
Murthy
Re: DataPool could not be loaded - urgent [message #104487 is a reply to message #80887] |
Thu, 12 July 2007 07:09  |
Hi Murthy,
Your code snippet sounds good.
Do you still have the issue with a recent TPTP build?
If yes, are the following JARs in your project's classpath:
tptp-models.jar, org.eclipse.emf.common_<VERSION>.jar,
org.eclipse.emf.ecore_<VERSION>, org.eclipse.core.runtime_<VERSION>?
Are you using the default deployment? Or your own one?
/Patrick
murthy a écrit :
> Hi
> with Eclipse 3.2
> the help document.
> at
> at
> File dataFile = new
> Thanks
> Murthy
FUDForum. Page generated in 0.09360 seconds
