Validation - constraintProvider - package [message #80847] |
Tue, 24 April 2007 07:33  |
I have a model divided to many packages. In one of my package I have defined
interface ExpressionHolder with feature Expression. In other packages I
implement this interface. I want to add constraint to check expression in
any place where someone use ExpressionHolder.
I create 'constraintProvider' and 'constraint' for type ExpressionHolder and
this works but I must list any packages that probably use my interface. Is
it possible to not include all that packages but only base package (I want
to someone may create own model for some extension in the future)?
Grzesiek
Re: Validation - constraintProvider - package [message #81176 is a reply to message #81147] |
Wed, 25 April 2007 10:24  |
I found that place few minutes ago. Like you said method resourceSetChanged
was not called in my second editor - I simply load second model outside of
EditingDomain (directly by ResourceSetImpl) ;D
Thanks for help
Grzesiek
Uzytkownik "Christian W. Damus" <cdamus@ca.ibm.com> napisal w wiadomosci
news:f0nlnh$d97$1@build.eclipse.org...
> Hi, Grzesiek,
> Your English is very good.
> I suspect that your WorkspaceCommandStack perhaps isn't being notified
when
> commands are executed in your second editor. Try putting a breakpoint at
> the beginning of the
> WorkspaceCommandStackImpl.DomainListener.resourceSetChanged( ...)
> method to see how it computes the affected resources and whether it
retains
> them. The resources should be stored in the affectedResources field and
> later converted to ResourceContexts in the historyNotification(...)
method.
> HTH,
> Christian
> Grzegorz Bialek wrote:
> > Thanks
> > I create request:
> > https://bugs.eclipse.org/bugs/show_bug.cgi?id=183917
> > I have one more question to you. I use your's pattern of workbench
> > integration from EXTLibraryEditor
> > (org.eclipse.emf.workspace.examples.library.editor).
> > Few days ago I migrate application from Eclipse 3.2 to 3.3 and I get
some
> > strange results.
> > I have two editors for different models (form different epackage) based
on
> > common parts (abstract editor). In my operationHistoryListener I use
code:
> > ResourceUndoContext.getAffectedResources(event.getOperation( ));
> > but for some reasons in one of my editors it returns empty set. I debug
> > this and discover that in first editor I have command with two
> > undoContexts:
> > org.eclipse.core.commands.operations.UndoContext
> > org.eclipse.emf.workspace.ResourceUndoContext
> > and in this not working I have only that first context. I don't
understand
> > why I have different contexts because both command is from shared page
of
> > editors.
> > I don't know where those contexts are set to commands. Do you know how
to
> > debug this sytuation?
> > Grzesiek
> > (sorry for my English ;> )
> <snip>
Re: Validation - constraintProvider - package [message #604986 is a reply to message #80847] |
Tue, 24 April 2007 09:36  |
Hi, Grzesiek,
I see that there is an early filter in the determination of the constraints
applicable to an EObject, that checks the EObject's EClass's EPackage
against the packages declared by the constraint provider (in the default
XML-based implementation, that is; custom providers can behave
differently). This will prevent the framework from consulting the
provider, which constraints would correctly determine (by EClass
inheritance) that they apply.
The EPackage filtering should account for the possibility that one package
"extends" another. Would you mind raising a bug?
https://bugs.eclipse.org/bugs/enter_bug.cgi?product=EMFT& ;version=1.1&component=Validation
Christian
Grzegorz Biaek wrote:
> Hello,
> defined interface ExpressionHolder with feature Expression. In other
> packages I implement this interface. I want to add constraint to check
> expression in any place where someone use ExpressionHolder.
> and this works but I must list any packages that probably use my
> interface. Is it possible to not include all that packages but only base
> package (I want to someone may create own model for some extension in the
> future)?
> Grzesiek
Re: Validation - constraintProvider - package [message #605042 is a reply to message #80848] |
Wed, 25 April 2007 09:17  |
I create request:
Few days ago I migrate application from Eclipse 3.2 to 3.3 and I get some
strange results.
I have two editors for different models (form different epackage) based on
common parts (abstract editor). In my operationHistoryListener I use code:
but for some reasons in one of my editors it returns empty set. I debug this
and discover that in first editor I have command with two undoContexts:
and in this not working I have only that first context. I don't understand
why I have different contexts because both command is from shared page of
editors.
I don't know where those contexts are set to commands. Do you know how to
Grzesiek
news:f0l15c$21c$1@build.eclipse.org...
> Hi, Grzesiek,
constraints
> Cheers,
> Christian
Re: Validation - constraintProvider - package [message #605045 is a reply to message #81132] |
Wed, 25 April 2007 09:40  |
Hi, Grzesiek,
I suspect that your WorkspaceCommandStack perhaps isn't being notified when
method to see how it computes the affected resources and whether it retains
later converted to ResourceContexts in the historyNotification(...) method.
HTH,
Christian
> Thanks
> I create request:
> strange results.
> undoContexts:
> editors.
> Grzesiek
<snip>
Re: Validation - constraintProvider - package [message #605051 is a reply to message #81147] |
Thanks for help
Grzesiek
> Hi, Grzesiek,
when
retains
method.
> HTH,
> Christian
> > Thanks
> > I create request:
some
> > strange results.
on
code:
> > undoContexts:
understand
of
> > editors.
to
> > Grzesiek
> <snip>
FUDForum. Page generated in 0.04071 seconds
