Home » Eclipse Projects » Eclipse Platform » Urgent : Problem with importing resources
Urgent : Problem with importing resources [message #80832] Mon, 23 June 2003 12:52 Go to next message
Originally posted by: bharatkhatri2000.yahoo.com
Hi All,
I have created a view which shows all resources in workspace, rooted at
workspace root. The components of the view are objects of my own class.
Then I have a context menu on top of my view where I do normal operations
like copy/paste/delete/move/rename. To do these operations, I am using the
wprksapce api. I implement a resoucechangeListener, which updates my view
when any of these operations in my context menu is executed. So far so
good.
The next menu item I added is import, and implemented is using the class
ImportResourcesAction (all implementation is already provided, I just
added this action to my menu). When the action is executed, the import is
done successfully, but I get an error when I try to refresh my view after
updating it. The exception is as follows:
org.eclipse.swt.SWTException: Invalid thread access
at org.eclipse.swt.SWT.error(SWT.java:2332)
at org.eclipse.swt.SWT.error(SWT.java:2262)
at org.eclipse.swt.widgets.Widget.error(Widget.java:385)
at org.eclipse.swt.widgets.Widget.checkWidget(Widget.java:315)
at org.eclipse.swt.widgets.Tree.setSelection(Tree.java:996)
at org.eclipse.jface.viewers.TreeViewer.setSelection(TreeViewer .java:226)
org.eclipse.jface.viewers.AbstractTreeViewer.setSelectionToW idget(AbstractTreeViewer.java:1249)
org.eclipse.jface.viewers.StructuredViewer.setSelectionToWid get(StructuredViewer.java:1055)
org.eclipse.jface.viewers.StructuredViewer.preservingSelecti on(StructuredViewer.java:808)
org.eclipse.jface.viewers.StructuredViewer.refresh(Structure dViewer.java:859)
org.eclipse.jface.viewers.StructuredViewer.refresh(Structure dViewer.java:821)
at TreeViewer.AdaTreeView.refresh(AdaTreeView.java:357)
Actions.ResourceChangeListener.resourceChanged(ResourceChang eListener.java:54)
org.eclipse.core.internal.events.NotificationManager$1.run(N otificationManager.java:137)
org.eclipse.core.internal.runtime.InternalPlatform.run(Inter nalPlatform.java:889)
at org.eclipse.core.runtime.Platform.run(Platform.java:413)
org.eclipse.core.internal.events.NotificationManager.notify( NotificationManager.java:152)
org.eclipse.core.internal.events.NotificationManager.broadca stChanges(NotificationManager.java:67)
org.eclipse.core.internal.resources.Workspace.broadcastChang es(Workspace.java:161)
org.eclipse.core.internal.resources.Workspace.endOperation(W orkspace.java:892)
at org.eclipse.core.internal.resources.Workspace.run(Workspace. java:1600)
org.eclipse.ui.actions.WorkspaceModifyOperation.run(Workspac eModifyOperation.java:85)
org.eclipse.jface.operation.ModalContext$ModalContextThread. run(ModalContext.java:101)
Any help will be appreciated
Bharat
Re: Urgent : Problem with importing resources [message #80837 is a reply to message #80832] Mon, 23 June 2003 14:03 Go to previous messageGo to next message
Originally posted by: bider.pasdespam.online.fr
I am not an expert with Eclipse but I am writng JFace/SWT apps.
Your problem is in my opinion that you are accessing the SWT ressources from
a diffrerent thread from the one that created the UI.
SWT, you all know does native calls to the system, and the Windows GUI does
not allow display resources to be accessed from a thread other that the one
that created it. Hence the exception.
I believe you should run your plug-in in the debugger and check which thread
receives the RessourceChangeListener event.
I had to sort out similar things with JFace, but as I control most of the
process in my app, I could find easy ways to send back the message to the
correct thread.
Hope it works,
David Bidermanas
"bharat" <bharatkhatri2000@yahoo.com> a
Re: Urgent : Problem with importing resources [message #80841 is a reply to message #80837] Mon, 23 June 2003 14:22 Go to previous messageGo to next message
Hi David,
Thanks for the reply. I am not using multi-threading anywhere in my code.
Apart from that, as I said before, the same listener updates the view
alright when I do a copy/paste etc. It only fails for importing resources.
And this is my main cause of concern.
Bharat
David Bidermanas wrote:
> Hello,
> correct thread.
> Hope it works,
> David Bidermanas
> "bharat" <bharatkhatri2000@yahoo.com> a écrit dans le message de news:
> bd7b7v$pgl$1@rogue.oti.com...
> > Hi All,
> > good.
> > at
> eeViewer.java:1249)
> > at
> ewer.java:1055)
> > at
> wer.java:808)
> > at
> > at
> > at
> 4)
> > at
> er.java:137)
> > at
> :889)
> > at
> ger.java:152)
> > at
> > at
> a:161)
> > at
> 2)
> > at
> ..java:85)
> > at
> ..java:101)
> > Thanks
> > Bharat
Re: Urgent : Problem with importing resources [message #84307 is a reply to message #80841] Fri, 27 June 2003 17:47 Go to previous message
Originally posted by: John_Arthorne.oti.com_
It doesn't matter if you're doing any multi-threading yourself. Your
resource change listener can be called from any thread. Often, this
does not correspond to the UI thread. This is described in the "thread
safety" section of the article on writing resource change listeners:
http://www.eclipse.org/articles/Article-Resource-deltas/reso urce-deltas.html
bharat wrote:
> Hi David,
> Thanks
> Bharat
>>Hello,
>>correct thread.
>>Hope it works,
>>David Bidermanas
>>>Hi All,
>>>good.
>>>at
>>eeViewer.java:1249)
>>>at
>>ewer.java:1055)
>>>at
>>wer.java:808)
>>>at
>>>at
>>>at
>>4)
>>>at
>>er.java:137)
>>>at
>>:889)
>>>at
>>ger.java:152)
>>>at
>>>at
>>a:161)
>>>at
>>2)
>>>at
>>..java:85)
>>>at
>>..java:101)
>>>Thanks
>>>Bharat
Previous Topic:XDoclet configuration
Next Topic:adding ezternal builder programmatically and adding C nature to my project.
Current Time: Mon May 12 16:36:59 EDT 2025
Powered by FUDForum. Page generated in 0.02763 seconds
