| new Web service problem, pls help~ [message #80750] |
Mon, 07 March 2005 00:36  |
Originally posted by: calendarw.gmail.com
When I new a project, Click new -> web service -> web service, then a list
of log is generated. can anyone help me?
is anything I haven't done?
..log:
!SESSION 2005-03-07
13:32:05.602 -----------------------------------------------
eclipse.buildId=I20041216-2000
java.version=1.5.0
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=zh_HK
Command-line arguments: -os win32 -ws win32 -arch x86
!ENTRY org.eclipse.ui 4 4 2005-03-07 13:32:05.602
!MESSAGE Unhandled event loop exception
!ENTRY org.eclipse.ui 4 0 2005-03-07 13:32:05.602
!MESSAGE
org.eclipse.ui.IWorkbench.getHelpSystem()Lorg/eclipse/ui/hel p/IWorkbenchHelpSystem;
!STACK 0
java.lang.NoSuchMethodError:
org.eclipse.jst.ws.internal.creation.ui.widgets.ServerWizard Widget.addControls(ServerWizardWidget.java:90)
org.eclipse.wst.command.internal.env.ui.widgets.SimpleWizard Page.createControl(SimpleWizardPage.java:54)
org.eclipse.jface.wizard.WizardDialog.updateForPage(WizardDi alog.java:1014)
at org.eclipse.jface.wizard.WizardDialog.access$2(WizardDialog. java:1007)
at org.eclipse.jface.wizard.WizardDialog$4.run(WizardDialog.jav a:997)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:69)
at org.eclipse.jface.wizard.WizardDialog.showPage(WizardDialog. java:995)
at org.eclipse.jface.wizard.WizardDialog.nextPressed(WizardDial og.java:747)
org.eclipse.jface.wizard.WizardDialog.buttonPressed(WizardDi alog.java:338)
at org.eclipse.jface.dialogs.Dialog$2.widgetSelected(Dialog.jav a:543)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:89)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :82)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:833)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:2803)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2448)
at org.eclipse.jface.window.Window.runEventLoop(Window.java:718 )
at org.eclipse.jface.window.Window.open(Window.java:696)
at org.eclipse.ui.actions.NewWizardAction.run(NewWizardAction.j ava:172)
org.eclipse.ui.actions.NewWizardDropDownAction.run(NewWizard DropDownAction.java:149)
at org.eclipse.jface.action.Action.runWithEvent(Action.java:989 )
org.eclipse.jface.action.ActionContributionItem.handleWidget Selection(ActionContributionItem.java:555)
org.eclipse.jface.action.ActionContributionItem.access$2(Act ionContributionItem.java:505)
org.eclipse.jface.action.ActionContributionItem$7.handleEven t(ActionContributionItem.java:460)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1569)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1540)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:285)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:144)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:102)
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:220)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:273)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:129)
at org.eclipse.core.launcher.Main.basicRun(Main.java:185)
at org.eclipse.core.launcher.Main.run(Main.java:710)
at org.eclipse.core.launcher.Main.main(Main.java:694)
FUDForum. Page generated in 0.03397 seconds
